Selector_WeakName Class Reference
Kind of selection algorithm: if other algorithms fail, this stores the geometrical index of the selected shape. More...
#include <Selector_WeakName.h>
Inheritance diagram for Selector_WeakName:
enum  Selector_Type {
  SELTYPE_CONTAINER , SELTYPE_INTERSECT , SELTYPE_PRIMITIVE , SELTYPE_MODIFICATION ,
  SELTYPE_FILTER_BY_NEIGHBOR , SELTYPE_WEAK_NAMING
 Type of a selector algorithm: on this type depends what is stored in this label and how to restore it on update. More...
bool select (const TopoDS_Shape theContext, const TopoDS_Shape theValue)
 Initializes the selection of this kind. More...
virtual void store () override
 Stores the name to the label and sub-labels tree. More...
virtual bool restore () override
 Restores the selected shape by the topological naming kept in the data structure Returns true if it can restore structure correctly. More...
virtual TDF_Label restoreByName (std::wstring theName, const TopAbs_ShapeEnum theShapeType, Selector_NameGenerator *theNameGenerator) override
 Restores the selected shape by the topological name string. More...
virtual bool solve (const TopoDS_Shape &theContext) override
 Updates the current shape by the stored topological name. More...
virtual std::wstring name (Selector_NameGenerator *theNameGenerator) override
 Returns the naming name of the selection. More...
TopoDS_Shape value ()
 Returns the current sub-shape value (null if can not resolve) More...
void setGeometricalNaming ()
 Sets geometrical naming flag to true. More...
static Selector_Algo * select (const TopoDS_Shape theContext, const TopoDS_Shape theValue, const TDF_Label theAccess, const TDF_Label theBaseDocument, const bool theGeometricalNaming=false, const bool theUseNeighbors=true, const bool theUseIntersections=true, const bool theAlwaysGeometricalNaming=false)
 Initializes the selector structure on the label. More...
static Selector_Algo * restoreByName (TDF_Label theLab, TDF_Label theBaseDocLab, std::wstring theName, const TopAbs_ShapeEnum theShapeType, const bool theGeomNaming, Selector_NameGenerator *theNameGenerator, TDF_Label &theContextLab)
 Restores the selected sub-algorithm by the naming name. More...
static Selector_Algo * restoreByLab (TDF_Label theLab, TDF_Label theBaseDocLab)
 Restores sub-algorithm of a given type by the storage-label. More...
static bool sameGeometry (const TopoDS_Shape theShape1, const TopoDS_Shape theShape2)
 Returns true if the given shapes are based on the same geometry. More...
static Selector_Algo * relesectWithAllGeometry (Selector_Algo *theOldAlgo, const TopoDS_Shape theContext)
 Creates a new selection algorithm for selection of all topology based on the same geometry. More...
void store (const TopoDS_Shape theShape)
 Stores result of selection at the given label. More...
const TDF_Label & label () const
 Returns label where this algorithm is attached to, or just an access label to the document. More...
void storeBaseArray (const TDF_LabelList &theRef, const TDF_Label &theLast)
 Stores the array of references to theLab: references to elements of ref-list, then the last. More...
bool restoreBaseArray (TDF_LabelList &theRef, TDF_Label &theLast)
 Restores references to the labels: references to elements of ref-list, then the last. More...
const TDF_Label & baseDocument () const
 Returns an access-label of the document that may contain initial shapes. More...
bool geometricalNaming () const
 Returns the geometrical naming flag. More...
bool alwaysGeometricalNaming () const
 Returns always geometrical naming flag. More...
bool useNeighbors () const
 Returns use neighbors flag. More...
bool useIntersections () const
 Returns use intersections flag. More...
void storeType (const Selector_Type theType)
 Stores the type of an algorithm in the data tree (in myLab) More...
bool findNewVersion (const TopoDS_Shape &theContext, TopoDS_Shape &theResult) const
 Searches the newer version of the shape in the document if the base shape does not belong to context. More...
static const Standard_GUID & weakID ()
 Returns GUID for the weak index (integer attribute) of the sub-shape. More...
static const Standard_GUID & shapeTypeID ()
 Returns GUID for the type of the shape, stored in case it is intersection or container. More...
static const std::wstring & oldWeakNameID ()
 old string identifier of the weak name in modification or intersection types of algorithm More...
static const std::wstring & oldPureWeakNameID ()
 old string identifier of the pure weak name More...
static const std::wstring & weakNameID ()
static const std::wstring & pureWeakNameID ()
Friends
class Selector_Algo
Pure weak naming approach.
◆ Selector_Type
SELTYPE_CONTAINER
just a container of sub-elements, keeps the shape type of container
SELTYPE_INTERSECT
sub-shape is intersection of higher level objects
SELTYPE_PRIMITIVE
sub-shape found as a primitive on some label
modification of base shapes to the final label
identification by neighbor shapes in context
SELTYPE_WEAK_NAMING
pure weak naming by weak index in context
◆ select() [1/2]
bool Selector_WeakName::select ( const TopoDS_Shape  theContext,
◆ store() [1/2]
void Selector_WeakName::store ( )
overridevirtual
Implements Selector_Algo.
◆ restore()
bool Selector_WeakName::restore ( )
overridevirtual
◆ restoreByName() [1/2]
TDF_Label Selector_WeakName::restoreByName ( std::wstring  theName,
Selector_NameGenerator *  theNameGenerator
overridevirtual
Returns not empty label of the context.
◆ solve()
bool Selector_WeakName::solve ( const TopoDS_Shape &  theContext)
overridevirtual
std::wstring Selector_WeakName::name ( Selector_NameGenerator *  theNameGenerator)
overridevirtual
◆ select() [2/2]
Selector_Algo * Selector_Algo::select ( const TopoDS_Shape  theContext,
const bool  theGeometricalNaming = false,
const bool  theUseNeighbors = true,
const bool  theUseIntersections = true,
const bool  theAlwaysGeometricalNaming = false
Stores the name data to restore after modification.
theContextwhole shape that contains the selected sub-shape
theValueselected subshape
theGeometricalNamingtreats selection with equal surfaces as one
theUseNeighborsenables searching algorithm by neighbors
theUseIntersectionsenables searching algorithm by intersection of higher level shapes
◆ store() [2/2]
void Selector_Algo::store ( const TopoDS_Shape  theShape)
◆ restoreByName() [2/2]
Selector_Algo * Selector_Algo::restoreByName ( TDF_Label  theLab,
Selector_NameGenerator *  theNameGenerator,
TDF_Label &  theContextLab
◆ value()
TopoDS_Shape Selector_Algo::value ( )
◆ restoreByLab()
Selector_Algo * Selector_Algo::restoreByLab ( TDF_Label  theLab,
◆ sameGeometry()
bool Selector_Algo::sameGeometry ( const TopoDS_Shape  theShape1,
◆ relesectWithAllGeometry()
Selector_Algo * Selector_Algo::relesectWithAllGeometry ( Selector_Algo *  theOldAlgo,
◆ setGeometricalNaming()
void Selector_Algo::setGeometricalNaming ( )
◆ label()
const TDF_Label & Selector_Algo::label ( ) const
inlineprotectedinherited
◆ storeBaseArray()
void Selector_Algo::storeBaseArray ( const TDF_LabelList &  theRef,
const TDF_Label &  theLast
◆ restoreBaseArray()
bool Selector_Algo::restoreBaseArray ( TDF_LabelList &  theRef,
TDF_Label &  theLast
◆ baseDocument()
const TDF_Label & Selector_Algo::baseDocument ( ) const
◆ geometricalNaming()
bool Selector_Algo::geometricalNaming ( ) const
◆ alwaysGeometricalNaming()
bool Selector_Algo::alwaysGeometricalNaming ( ) const
◆ useNeighbors()
bool Selector_Algo::useNeighbors ( ) const
◆ useIntersections()
bool Selector_Algo::useIntersections ( ) const
◆ weakID()
static const Standard_GUID & Selector_Algo::weakID ( )
inlinestaticprotectedinherited
◆ shapeTypeID()
static const Standard_GUID & Selector_Algo::shapeTypeID ( )
◆ oldWeakNameID()
static const std::wstring & Selector_Algo::oldWeakNameID ( )
◆ oldPureWeakNameID()
static const std::wstring & Selector_Algo::oldPureWeakNameID ( )
◆ weakNameID()
static const std::wstring & Selector_Algo::weakNameID ( )
◆ pureWeakNameID()
static const std::wstring & Selector_Algo::pureWeakNameID ( )
◆ storeType()
void Selector_Algo::storeType ( const Selector_Type  theType)
◆ findNewVersion()
bool Selector_Algo::findNewVersion ( const TopoDS_Shape &  theContext,
TopoDS_Shape &  theResult
Returns it in theResult (if any). Returns true is theResult is changed.
