SketchAPI_Constraint Class Reference
Interface for Constraint feature. More...
#include <SketchAPI_Constraint.h>
Inheritance diagram for SketchAPI_Constraint:
 SketchAPI_Constraint (const std::shared_ptr< ModelAPI_Feature > &theFeature)
virtual ~SketchAPI_Constraint ()
virtual std::string getID ()
bool initialize ()
void setEntityA (const ModelHighAPI_RefAttr &theEntity)
void setEntityB (const ModelHighAPI_RefAttr &theEntity)
void setEntityC (const ModelHighAPI_RefAttr &theEntity)
void setEntityD (const ModelHighAPI_RefAttr &theEntity)
void setValue (const ModelHighAPI_Double &theValue)
double value () const
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool areAllAttributesDumped (ModelHighAPI_Dumper &theDumper) const
◆ SketchAPI_Constraint()
SketchAPI_Constraint::SketchAPI_Constraint ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ~SketchAPI_Constraint()
SketchAPI_Constraint::~SketchAPI_Constraint ( )
◆ dump()
void SketchAPI_Constraint::dump ( ModelHighAPI_Dumper &  theDumper) const
Reimplemented in SketchAPI_ConstraintAngle.
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
