SketchSolver_Group Class Reference
Keeps the group of constraints which placed in the same sketch. More...
#include <SketchSolver_Group.h>
 SketchSolver_Group (const CompositeFeaturePtr &theWorkplane)
 New group based on specified workplane. More...
bool isEmpty () const
 Returns true if the group has no constraints yet. More...
bool isWorkplaneValid () const
 Check for valid sketch data. More...
bool changeConstraint (std::shared_ptr< SketchPlugin_Constraint > theConstraint)
 Adds or updates a constraint in the group. More...
bool updateSketch (CompositeFeaturePtr theSketch)
 Updates the sketch feature. More...
bool updateFeature (FeaturePtr theFeature)
 Updates the data corresponding the specified feature. More...
bool moveFeature (FeaturePtr theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theFrom, const std::shared_ptr< GeomAPI_Pnt2d > &theTo)
 Updates the data corresponding the specified feature moved in GUI. More...
bool movePoint (AttributePtr thePointOrArray, const int thePointIndex, const std::shared_ptr< GeomAPI_Pnt2d > &theFrom, const std::shared_ptr< GeomAPI_Pnt2d > &theTo)
 Updates the data corresponding the specified point moved in GUI. More...
const CompositeFeaturePtr & getWorkplane () const
 Returns the current workplane. More...
void repairConsistency ()
 Searches invalid features and constraints in the group and removes them. More...
bool resolveConstraints ()
 Start solution procedure if necessary and update attributes of features. More...
void underconstrainedFeatures (std::set< ObjectPtr > &theFeatures) const
 Find the list of features, which are not fully constrained. More...
void blockEvents (bool isBlocked)
 Block or unblock events sent by features in this group. More...
◆ SketchSolver_Group()
SketchSolver_Group::SketchSolver_Group ( const CompositeFeaturePtr &  theWorkplane)
Throws an exception if theWorkplane is not an object of SketchPlugin_Sketch type
Remarks
Type of theSketch is not verified inside
◆ isEmpty()
bool SketchSolver_Group::isEmpty ( ) const
◆ isWorkplaneValid()
bool SketchSolver_Group::isWorkplaneValid ( ) const
◆ changeConstraint()
bool SketchSolver_Group::changeConstraint ( std::shared_ptr< SketchPlugin_Constraint >  theConstraint)
[in]theConstraintconstraint to be changed
true if the constraint added or updated successfully
◆ updateSketch()
bool SketchSolver_Group::updateSketch ( CompositeFeaturePtr  theSketch)
◆ updateFeature()
bool SketchSolver_Group::updateFeature ( FeaturePtr  theFeature)
[in]theFeaturethe feature to be updated
◆ moveFeature()
bool SketchSolver_Group::moveFeature ( FeaturePtr  theFeature,
const std::shared_ptr< GeomAPI_Pnt2d > &  theFrom,
const std::shared_ptr< GeomAPI_Pnt2d > &  theTo
Special kind of Fixed constraints is created.
[in]theFromstart point of the movement
[in]theTofinal point of the movement
true, if the feature is really moved
◆ movePoint()
bool SketchSolver_Group::movePoint ( AttributePtr  thePointOrArray,
[in]thePointOrArraythe attribute to be updated
[in]thePointIndexindex of moved point in array
[in]theTodestination point of the movement
true, if the attribute is really moved
◆ getWorkplane()
const CompositeFeaturePtr & SketchSolver_Group::getWorkplane ( ) const
◆ repairConsistency()
void SketchSolver_Group::repairConsistency ( )
false if the group several constraints were removed
◆ resolveConstraints()
bool SketchSolver_Group::resolveConstraints ( )
false when no need to solve constraints
◆ underconstrainedFeatures()
void SketchSolver_Group::underconstrainedFeatures ( std::set< ObjectPtr > &  theFeatures) const
◆ blockEvents()
void SketchSolver_Group::blockEvents ( bool  isBlocked)
