SketcherPrs_Angle Class Reference
A class for representation of angle constraint. More...
#include <SketcherPrs_Angle.h>
Inheritance diagram for SketcherPrs_Angle:
 SketcherPrs_Angle (ModelAPI_Feature *theConstraint, SketchPlugin_Sketch *theSketcher)
 ~SketcherPrs_Angle ()
 DEFINE_STANDARD_RTTIEXT (SketcherPrs_Angle, PrsDim_AngleDimension) static bool IsReadyToDisplay(ModelAPI_Feature *theConstraint
 Returns true if the constraint feature arguments are correctly filled to build AIS presentation. More...
std::shared_ptr< GeomAPI_Ax3 > plane () const
 Returns sketcher plane. More...
Data Fields
const std::shared_ptr< GeomAPI_Ax3 > & thePlane
virtual void Compute (const Handle &thePresentationManager, const Handle &thePresentation, const Standard_Integer theMode=0)
 Redefinition of virtual function. More...
virtual void ComputeSelection (const Handle &aSelection, const Standard_Integer aMode)
bool isAnglePlaneReversedToSketchPlane ()
 Checks is the angle plane has inverted direction of normal to the plane of current sketcher Returns true if crossed product is negative. More...
double calculateDistanceToFlyoutPoint ()
 Calculates a distance between center of the angle presentation and the value of flyout point attribute. More...
static bool readyToDisplay (ModelAPI_Feature *theConstraint, const std::shared_ptr< GeomAPI_Ax3 > &thePlane, gp_Pnt &theFirstPoint, gp_Pnt &theSecondPoint, gp_Pnt &theCenterPoint)
◆ SketcherPrs_Angle()
SketcherPrs_Angle::SketcherPrs_Angle ( ModelAPI_Feature *  theConstraint,
SketchPlugin_Sketch *  theSketcher
theConstrainta constraint feature
thePlanea coordinate plane of current sketch
◆ ~SketcherPrs_Angle()
SketcherPrs_Angle::~SketcherPrs_Angle ( )
◆ DEFINE_STANDARD_RTTIEXT()
SketcherPrs_Angle::DEFINE_STANDARD_RTTIEXT ( SketcherPrs_Angle  ,
boolean result value
◆ plane()
std::shared_ptr< GeomAPI_Ax3 > SketcherPrs_Angle::plane ( ) const
◆ Compute()
void SketcherPrs_Angle::Compute ( const Handle &  thePresentationManager,
const Handle &  thePresentation,
const Standard_Integer  theMode = 0
it was not calculated yet
◆ ComputeSelection()
void SketcherPrs_Angle::ComputeSelection ( const Handle &  aSelection,
◆ isAnglePlaneReversedToSketchPlane()
bool SketcherPrs_Angle::isAnglePlaneReversedToSketchPlane ( )
boolean value
◆ calculateDistanceToFlyoutPoint()
double SketcherPrs_Angle::calculateDistanceToFlyoutPoint ( )
It should be used after setting measured geometry for the angle presentation as it uses calculated center/first/second point coordinates
real value
