XGUI_PropertyPanelSelector Class Reference
Processing selection by the property panel. More...
#include <XGUI_PropertyPanelSelector.h>
Inheritance diagram for XGUI_PropertyPanelSelector:
Signals
void activated ()
 control is activated More...
void deactivated ()
 control is deactivated More...
 XGUI_PropertyPanelSelector (XGUI_PropertyPanel *thePanel)
virtual ~XGUI_PropertyPanelSelector ()
virtual QString getType ()
 Returns name of the selector. More...
virtual void reset ()
 Clear need to be activated widget if it exists. More...
virtual void setActive (const bool &isActive)
 Sets control active. More...
virtual bool needToBeActivated () const
 Returns whether the selector should be activated as soon as possible (by deactivatate other) More...
virtual void processSelection ()
 Processes current selection of workshop. Reaction to selection change in workshop. More...
void setEnable (const bool &theEnabled)
 Sets enable/disable state of the selector. More...
bool isEnabled () const
 Returns whether the selector is enabled or not. More...
static QString Type ()
XGUI_PropertyPanel * myPanel
 processed panel More...
ModuleBase_ModelWidget * myWidgetToBeActivated
 used as need to be activated back More...
bool myIsEnabled
 enable state of the selector More...
◆ XGUI_PropertyPanelSelector()
XGUI_PropertyPanelSelector::XGUI_PropertyPanelSelector ( XGUI_PropertyPanel *  thePanel)
thePanelthe workshop property panel
◆ ~XGUI_PropertyPanelSelector()
virtual XGUI_PropertyPanelSelector::~XGUI_PropertyPanelSelector ( )
◆ Type()
static QString XGUI_PropertyPanelSelector::Type ( )
inlinestatic
◆ getType()
virtual QString XGUI_PropertyPanelSelector::getType ( )
Implements XGUI_ActiveControlSelector.
◆ reset()
void XGUI_PropertyPanelSelector::reset ( )
Reimplemented from XGUI_ActiveControlSelector.
◆ setActive()
void XGUI_PropertyPanelSelector::setActive ( const bool &  isActive)
It should activates/deactivates selection and selection filters.
isActiveif true, the control becomes active
◆ needToBeActivated()
bool XGUI_PropertyPanelSelector::needToBeActivated ( ) const
boolean result
◆ processSelection()
void XGUI_PropertyPanelSelector::processSelection ( )
◆ setEnable()
void XGUI_ActiveControlSelector::setEnable ( const bool &  theEnabled)
If disable, it will not react to selection
theEnabledif true, selector is enabled
◆ isEnabled()
bool XGUI_ActiveControlSelector::isEnabled ( ) const
boolean result
◆ activated
void XGUI_ActiveControlSelector::activated ( )
signalinherited
◆ deactivated
void XGUI_ActiveControlSelector::deactivated ( )
signalinherited
◆ myPanel
XGUI_PropertyPanel* XGUI_PropertyPanelSelector::myPanel
processed panel
◆ myWidgetToBeActivated
ModuleBase_ModelWidget* XGUI_PropertyPanelSelector::myWidgetToBeActivated
◆ myIsEnabled
bool XGUI_ActiveControlSelector::myIsEnabled
