XGUI_Tools Namespace Reference
Commonly used methods in XGUI package and higher. More...
QString dir (const QString &path, bool isAbs=true)
 Return directory part of the file path. More...
QString file (const QString &path, bool withExt=true)
 Return file name part of the file path. More...
QString addSlash (const QString &path)
 Add a slash (platform-specific) to the end of path if it is not already there. More...
QString unionOfObjectNames (const QObjectPtrList &theObjects, const QString &theSeparator)
bool isModelObject (FeaturePtr theFeature)
std::string featureInfo (FeaturePtr theFeature)
bool canRemoveOrRename (QWidget *theParent, const std::set< FeaturePtr > &theFeatures)
bool isAscii (const QString &theStr)
bool isValidName (const QString &theName)
bool canRename (const ObjectPtr &theObject, const QString &theName)
XGUI_Workshop * workshop (ModuleBase_IWorkshop *theWorkshop)
QString generateName (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
 Generates a presentation name in form: <object_name>/<face>_<face_index> More...
std::wstring strToWStr (const std::string &theStr)
std::string getTmpDirByPath (const std::string &theTmpPath)
std::string getTmpDirByEnv (const char *thePathEnv)
 Creates and returns the temporary directory (with random name) using the environment variable path to location of such directories,. More...
void removeTemporaryFiles (const std::string &theDirectory, const std::list< std::string > &theFiles)
 Removes files and directory where they are located. More...
◆ dir()
QString XGUI_Tools::dir ( const QString &  path,
bool  isAbs = true
If the file path does not include directory part (the file is in the current directory), null string is returned.
pathfile path
isAbsif true (default) path parameter is treated as absolute file path
◆ file()
QString XGUI_Tools::file ( const QString &  path,
bool  withExt = true
pathfile path
withExtif true (default) complete file name (with all extension except the last) is returned, otherwise only base name is returned
◆ addSlash()
QString XGUI_Tools::addSlash ( const QString &  path)
pathdirectory path
modified path (with slash added to the end)
◆ unionOfObjectNames()
QString XGUI_Tools::unionOfObjectNames ( const QObjectPtrList &  theObjects,
const QString &  theSeparator
Unite object names in one string using the separator between values
theObjectsa list of objects
theSeparatora separator
◆ isModelObject()
bool XGUI_Tools::isModelObject ( FeaturePtr  theFeature)
Returns true if the feature is a model object
theFeaturea feature
◆ featureInfo()
std::string XGUI_Tools::featureInfo ( FeaturePtr  theFeature)
Returns the string presentation of the given feature
theFeaturea feature
◆ canRemoveOrRename()
bool XGUI_Tools::canRemoveOrRename ( QWidget *  theParent,
const std::set< FeaturePtr > &  theFeatures
Returns true if there are no parts in the document, which are not activated or all objects in the list are not PartSet document. It shows the warning control if the result is false.
theParenta parent for the warning control
theFeaturesa list of checked features
a boolean value
◆ isAscii()
bool XGUI_Tools::isAscii ( const QString &  theStr)
Checks that the given string contains only ASCII symbols
theStra string to check
◆ canRename()
bool XGUI_Tools::canRename ( const ObjectPtr &  theObject,
const QString &  theName
Check possibility to rename object
theObjectan object to rename
theNamea name
◆ workshop()
XGUI_Workshop * XGUI_Tools::workshop ( ModuleBase_IWorkshop *  theWorkshop)
Returns converted workshop
theWorkshopan interface workshop
XGUI workshop instance
◆ generateName()
QString XGUI_Tools::generateName ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs)
thePrsa presentation
string value
◆ getTmpDirByEnv()
std::string XGUI_Tools::getTmpDirByEnv ( const char *  thePathEnv)
◆ removeTemporaryFiles()
void XGUI_Tools::removeTemporaryFiles ( const std::string &  theDirectory,
const std::list< std::string > &  theFiles
