Tool converting SMESH engine calls into commands defined in smeshBuilder.py.
More...
#include <SMESH_PythonDump.hxx>
| static void | ConvertScript (std::list< TCollection_AsciiString > &theScriptLines, Resource_DataMapOfAsciiStringAsciiString &theEntry2AccessorMethod, Resource_DataMapOfAsciiStringAsciiString &theObjectNames, std::set< TCollection_AsciiString > &theRemovedObjIDs, const bool theHistoricalDump) |
| | Convert a python script using commands of smeshBuilder.py. More...
| static const char * | SmeshpyName () |
| | Return the name of the python file wrapping IDL API. More...
| static const char * | GenName () |
Implementation is in SMESH_2smeshpy.cxx
◆ ConvertScript()
| void SMESH_2smeshpy::ConvertScript |
std::list< TCollection_AsciiString > & |
theScriptLines, |
Resource_DataMapOfAsciiStringAsciiString & |
theEntry2AccessorMethod, |
theObjectNames, |
std::set< TCollection_AsciiString > & |
theRemovedObjIDs, |
const bool |
theToKeepAllCommands |
static |
- Parameters
| theScript | - the Input script to convert |
| theEntry2AccessorMethod | - returns method names to access to objects wrapped with python class |
| theObjectNames | - names of objects |
| theRemovedObjIDs | - entries of objects whose created commands were removed |
| theHistoricalDump | - true means to keep all commands, false means to exclude commands relating to objects removed from study |
- Return values
| TCollection_AsciiString | - Conversion result |
- Parameters
| theScriptLines | - Lines of the input script |
- Return values
References SMESH_NoteBook::AddCommand(), SMESH_NoteBook::GetResultLines(), Handle(), and SMESH_NoteBook::ReplaceVariables().
Referenced by SMESH_Gen_i::DumpPython_impl().
◆ GenName()
| static const char * SMESH_2smeshpy::GenName |
static |
◆ SmeshpyName()
| static const char * SMESH_2smeshpy::SmeshpyName |
static |
