_pyGen Class Reference
Class corresponding to SMESH_Gen. More...
#include <SMESH_2smeshpy.hxx>
Inheritance diagram for _pyGen:
 _pyGen (Resource_DataMapOfAsciiStringAsciiString &theEntry2AccessorMethod, Resource_DataMapOfAsciiStringAsciiString &theObjectNames, std::set< TCollection_AsciiString > &theRemovedObjIDs, const bool theToKeepAllCommands)
 _pyGen constructor More...
 Handle (_pyCommand) AddCommand(const _AString &theCommand)
void ExchangeCommands (Handle(_pyCommand) theCmd1, Handle(_pyCommand) theCmd2)
 Change order of commands in the script. More...
void SetCommandAfter (Handle(_pyCommand) theCmd, Handle(_pyCommand) theAfterCmd)
 Set one command after the other. More...
void SetCommandBefore (Handle(_pyCommand) theCmd, Handle(_pyCommand) theBeforeCmd)
 Set one command before the other. More...
 Handle (_pyCommand) &GetLastCommand()
std::list< Handle(_pyCommand) > & GetCommands ()
void PlaceSubmeshAfterItsCreation (Handle(_pyCommand) theCmdUsingSubmesh) const
 Prevent moving a command creating a sub-mesh to the end of the script if the sub-mesh is used in theCmdUsingSubmesh as argument. More...
_pyID GenerateNewID (const _pyID &theID)
 Generated new ID for object and assign with existing name. More...
bool AddObject (Handle(_pyObject)&theObj)
 Stores theObj in myObjects. More...
void CheckObjectIsReCreated (Handle(_pyObject)&theObj)
 Erases an existing object with the same ID. More...
void SetProxyObject (const _pyID &theID, Handle(_pyObject)&theObj)
 Re-register an object with other ID to make it Process() commands of other object having this ID. More...
 Handle (_pyObject) FindObject(const _pyID &theObjID) const
 Handle (_pySubMesh) FindSubMesh(const _pyID &theSubMeshID)
 Handle (_pyHypothesis) FindHyp(const _pyID &theHypID)
 Handle (_pyHypothesis) FindAlgo(const _pyID &theGeom
const _pyID const Handle (_pyHypothesis) &theHypothesis)
void SetAccessorMethod (const _pyID &theID, const char *theMethod)
 Set method to access to object wrapped with python class. More...
bool AddMeshAccessorMethod (Handle(_pyCommand) theCmd) const
 Add access method to mesh that is an argument. More...
bool AddAlgoAccessorMethod (Handle(_pyCommand) theCmd) const
 Add access method to algo that is an object or an argument. More...
virtual const char * AccessorMethod () const
 name of SMESH_Gen in smeshBuilder.py More...
bool IsGeomObject (const _pyID &theObjID) const
bool IsNotPublished (const _pyID &theObjID) const
void ObjectCreationRemoved (const _pyID &theObjID)
void KeepAgrCmds (const _pyID &theObjID)
bool IsToKeepAllCommands () const
void AddExportedMesh (const _AString &file, const ExportedMeshData &mesh)
ExportedMeshData & FindExportedMesh (const _AString &file)
virtual void Process (const Handle(_pyCommand)&theCommand)
 Convert the command or remember it for later conversion. More...
virtual void Flush ()
 Convert the remembered commands. More...
virtual void ClearCommands ()
 Clean commands of removed objects depending on myIsPublished flag. More...
virtual void Free ()
 Release mutual handles of objects. More...
 Handle (_pyHypothesisReader) GetHypothesisReader() const
const _pyID & GetID ()
int GetNbCalls () const
bool IsInStudy () const
virtual void SetRemovedFromStudy (const bool isRemoved)
void SetCreationCmd (Handle(_pyCommand) cmd)
int GetCommandNb ()
void AddProcessedCmd (const Handle(_pyCommand) &cmd)
std::list< Handle(_pyCommand) > & GetProcessedCmds ()
void AddArgCmd (const Handle(_pyCommand) &cmd)
virtual void Process (const Handle(_pyCommand) &cmd)
virtual bool CanClear ()
 Return true if all my users can be cleared. More...
static _pyID FatherID (const _pyID &childID)
 Return ID of a father. More...
Data Fields
const _pyID & theMesh
void setID (const _pyID &theID)
 Set up myID and myIsPublished. More...
_pyID myID
std::list< Handle(_pyCommand) > myProcessedCmds
std::list< Handle(_pyCommand) > myArgCmds
bool myIsPublished
void setNeighbourCommand (Handle(_pyCommand)&theCmd, Handle(_pyCommand)&theOtherCmd, const bool theIsAfter)
 Set one command before or after the other. More...
 Handle (_pyCommand) myLastCommand
 Handle (_pyHypothesisReader) myHypReader
std::map< _pyID, Handle(_pyMesh) > myMeshes
std::map< _pyID, Handle(_pyMeshEditor) > myMeshEditors
std::map< _pyID, Handle(_pyHypothesis) > myHypos
std::map< _pyID, Handle(_pyObject) > myObjects
std::list< Handle(_pyObject) > myOrderedObjects
_pyStringFamily myKeepAgrCmdsIDs
std::list< Handle(_pyCommand) > myCommands
int myNbCommands
Resource_DataMapOfAsciiStringAsciiString & myID2AccessorMethod
Resource_DataMapOfAsciiStringAsciiString & myObjectNames
std::set< TCollection_AsciiString > & myRemovedObjIDs
int myNbFilters
bool myToKeepAllCommands
int myGeomIDNb
int myGeomIDIndex
int myShaperIDNb
int myShaperIDIndex
std::map< _AString, ExportedMeshData > myFile2ExportedMesh
It holds info on existing meshes and hypotheses
◆ _pyGen()
_pyGen::_pyGen ( Resource_DataMapOfAsciiStringAsciiString &  theEntry2AccessorMethod,
Resource_DataMapOfAsciiStringAsciiString &  theObjectNames,
std::set< TCollection_AsciiString > &  theRemovedObjIDs,
◆ AccessorMethod()
const char * _pyGen::AccessorMethod ( ) const
Reimplemented from _pyObject.
References SMESH_2smeshpy::GenName().
◆ AddAlgoAccessorMethod()
bool _pyGen::AddAlgoAccessorMethod ( Handle(_pyCommand)  theCmd) const
theCmd- command to add access method
bool- true if added
References _pyCommand::AddAccessorMethod(), Handle(), and myHypos.
◆ AddArgCmd()
void _pyObject::AddArgCmd ( const Handle(_pyCommand) &  cmd)
References _pyObject::myArgCmds.
◆ AddExportedMesh()
void _pyGen::AddExportedMesh ( const _AString &  file,
const ExportedMeshData &  mesh
References myFile2ExportedMesh.
◆ AddMeshAccessorMethod()
bool _pyGen::AddMeshAccessorMethod ( Handle(_pyCommand)  theCmd) const
bool- true if added
References _pyCommand::AddAccessorMethod(), Handle(), and myMeshes.
Referenced by Handle(), and Process().
◆ AddObject()
bool _pyGen::AddObject ( Handle(_pyObject)&  theObj)
◆ AddProcessedCmd()
void _pyObject::AddProcessedCmd ( const Handle(_pyCommand) &  cmd)
◆ CanClear()
bool _pyObject::CanClear ( )
Reimplemented in _pyMesh, _pyMeshEditor, _pyHypothesis, _pySelfEraser, and _pyGroup.
References _pyObject::Handle(), _pyObject::myArgCmds, and _pyObject::myIsPublished.
Referenced by _pyObject::ClearCommands().
◆ CheckObjectIsReCreated()
void _pyGen::CheckObjectIsReCreated ( Handle(_pyObject)&  theObj)
This method should be called before storing theObj in _pyGen
References _pyObject::GetID(), Handle(), _pyCommand::IsStudyEntry(), myHypos, myMeshes, and myObjects.
Referenced by AddObject(), Handle(), and Process().
◆ ClearCommands()
void _pyGen::ClearCommands ( )
References Handle(), myHypos, myMeshes, and myOrderedObjects.
◆ ExchangeCommands()
void _pyGen::ExchangeCommands ( Handle(_pyCommand)  theCmd1,
theCmd1- One command
theCmd2- Another command
References _pyCommand::GetOrderNb(), Handle(), myCommands, and _pyCommand::SetOrderNb().
◆ FatherID()
_pyID _pyObject::FatherID ( const _pyID &  childID)
Referenced by _pySegmentLengthAroundVertexHyp::Addition2Creation().
◆ FindExportedMesh()
ExportedMeshData & _pyGen::FindExportedMesh ( const _AString &  file)
◆ Flush()
void _pyGen::Flush ( )
◆ Free()
void _pyGen::Free ( )
References Handle(), myFile2ExportedMesh, myHypos, myMeshEditors, myMeshes, and myObjects.
◆ GenerateNewID()
_pyID _pyGen::GenerateNewID ( const _pyID &  theID)
theID- ID of existing object
References myObjectNames.
◆ GetCommandNb()
int _pyObject::GetCommandNb ( )
◆ GetCommands()
std::list< Handle(_pyCommand) > & _pyGen::GetCommands ( )
References myCommands.
◆ GetID()
◆ GetNbCalls()
int _pyObject::GetNbCalls ( ) const
◆ GetProcessedCmds()
std::list< Handle(_pyCommand) > & _pyObject::GetProcessedCmds ( )
◆ Handle() [1/10]
_pyGen::Handle ( _pyCommand  ) &
◆ Handle() [2/10]
◆ Handle() [3/10]
◆ Handle() [4/10]
const _pyID const _pyGen::Handle ( _pyHypothesis  ) &
◆ Handle() [5/10]
_pyGen::Handle ( _pyHypothesis  ) const &
◆ Handle() [6/10]
◆ Handle() [7/10]
_pyGen::Handle ( _pyHypothesisReader  ) const
◆ Handle() [8/10]
◆ Handle() [9/10]
_pyGen::Handle ( _pyObject  ) const &
◆ Handle() [10/10]
_pyGen::Handle ( _pySubMesh  ) const &
◆ IsGeomObject()
bool _pyGen::IsGeomObject ( const _pyID &  theObjID) const
◆ IsInStudy()
◆ IsNotPublished()
bool _pyGen::IsNotPublished ( const _pyID &  theObjID) const
◆ IsToKeepAllCommands()
bool _pyGen::IsToKeepAllCommands ( ) const
References myToKeepAllCommands.
Referenced by Flush().
◆ KeepAgrCmds()
void _pyGen::KeepAgrCmds ( const _pyID &  theObjID)
◆ ObjectCreationRemoved()
void _pyGen::ObjectCreationRemoved ( const _pyID &  theObjID)
◆ PlaceSubmeshAfterItsCreation()
void _pyGen::PlaceSubmeshAfterItsCreation ( Handle(_pyCommand)  theCmdUsingSubmesh) const
◆ Process() [1/2]
virtual void _pyObject::Process ( const Handle(_pyCommand) &  cmd)
◆ Process() [2/2]
◆ SetAccessorMethod()
void _pyGen::SetAccessorMethod ( const _pyID &  theID,
const char *  theMethod
theID- The wrapped object entry
theMethod- The accessor method
References myID2AccessorMethod.
◆ SetCommandAfter()
void _pyGen::SetCommandAfter ( Handle(_pyCommand)  theCmd,
theCmd- Command to move
theAfterCmd- Command ater which to insert the first one
References setNeighbourCommand().
◆ SetCommandBefore()
void _pyGen::SetCommandBefore ( Handle(_pyCommand)  theCmd,
theBeforeCmd- Command before which to insert the first one
◆ SetCreationCmd()
void _pyObject::SetCreationCmd ( Handle(_pyCommand)  cmd)
◆ setID()
void _pyObject::setID ( const _pyID &  theID)
References _pyObject::GetID(), _pyObject::myID, and _pyObject::myIsPublished.
Referenced by _pyGroup::_pyGroup(), and _pyObject::_pyObject().
◆ setNeighbourCommand()
void _pyGen::setNeighbourCommand ( Handle(_pyCommand)&  theCmd,
Handle(_pyCommand)&  theOtherCmd,
theOtherCmd- Command ater or before which to insert the first one
References Handle(), and myCommands.
Referenced by SetCommandAfter(), and SetCommandBefore().
◆ SetProxyObject()
void _pyGen::SetProxyObject ( const _pyID &  theID,
References SMESH::DownCast(), Handle(), myMeshEditors, myMeshes, and myObjects.
◆ SetRemovedFromStudy()
virtual void _pyObject::SetRemovedFromStudy ( const bool  isRemoved)
Reimplemented in _pyMesh.
References _pyObject::myIsPublished.
Referenced by _pyMesh::SetRemovedFromStudy().
◆ myArgCmds
std::list< Handle(_pyCommand) > _pyObject::myArgCmds
◆ myCommands
std::list< Handle(_pyCommand) > _pyGen::myCommands
◆ myFile2ExportedMesh
std::map< _AString, ExportedMeshData > _pyGen::myFile2ExportedMesh
◆ myGeomIDIndex
int _pyGen::myGeomIDIndex
Referenced by _pyGen().
◆ myGeomIDNb
int _pyGen::myGeomIDNb
◆ myHypos
◆ myID
_pyID _pyObject::myID
◆ myID2AccessorMethod
Resource_DataMapOfAsciiStringAsciiString& _pyGen::myID2AccessorMethod
Referenced by SetAccessorMethod().
◆ myIsPublished
◆ myKeepAgrCmdsIDs
_pyStringFamily _pyGen::myKeepAgrCmdsIDs
Referenced by Handle(), and KeepAgrCmds().
◆ myMeshEditors
std::map< _pyID, Handle(_pyMeshEditor) > _pyGen::myMeshEditors
◆ myMeshes
◆ myNbCommands
int _pyGen::myNbCommands
Referenced by Flush(), and Handle().
◆ myNbFilters
int _pyGen::myNbFilters
Referenced by Handle().
◆ myObjectNames
Resource_DataMapOfAsciiStringAsciiString& _pyGen::myObjectNames
Referenced by GenerateNewID(), and Process().
◆ myObjects
std::map< _pyID, Handle(_pyObject) > _pyGen::myObjects
◆ myOrderedObjects
std::list< Handle(_pyObject) > _pyGen::myOrderedObjects
Referenced by AddObject(), ClearCommands(), and Flush().
◆ myProcessedCmds
std::list< Handle(_pyCommand) > _pyObject::myProcessedCmds
◆ myRemovedObjIDs
std::set< TCollection_AsciiString >& _pyGen::myRemovedObjIDs
◆ myShaperIDIndex
int _pyGen::myShaperIDIndex
◆ myShaperIDNb
int _pyGen::myShaperIDNb
◆ myToKeepAllCommands
bool _pyGen::myToKeepAllCommands
Referenced by IsToKeepAllCommands().
◆ theMesh
const _pyID& _pyGen::theMesh
