SMESH_2smeshpy.cxx File Reference
#include "SMESH_2smeshpy.hxx"
#include "SMESH_NoteBook.hxx"
#include "SMESH_Filter_i.hxx"
#include <SALOMEDS_wrap.hxx>
#include <utilities.h>
#include <Basics_OCCTVersion.hxx>
#include <Resource_DataMapOfAsciiStringAsciiString.hxx>
#include <Resource_DataMapIteratorOfDataMapOfAsciiStringAsciiString.hxx>
#include "SMESH_Gen_i.hxx"
#include <LDOMParser.hxx>
#include <unistd.h>
Include dependency graph for SMESH_2smeshpy.cxx:
static Handle (_pyGen) theGen
 Container of commands into which the initial script is split. More...
 Handle (_pyCommand) _pyGen
 Convert a command using a specific converter. More...
 Handle (_pyHypothesis) _pyGen
 Find hypothesis by ID (entry) More...
 Handle (_pySubMesh) _pyGen
 Find subMesh by ID (entry) More...
 Handle (_pyCommand) &_pyGen
 Call _pyFilter.AddUser() if a filter is used as a command arg. More...
 Handle (_pyObject) _pyGen
 Finds a _pyObject by ID. More...
 Handle (_pyHypothesisReader) _pyGen
 Return reader of hypotheses of plugins. More...
static bool isWord (const char c, const bool dotIsWord)
 Check if char is a word part. More...
Variables
static TCollection_AsciiString theEmptyString
◆ Handle() [1/7]
Handle ( _pyCommand  ) &
Set command be last in list of commands
theCmd- Command to be last
◆ Handle() [2/7]
◆ Handle() [3/7]
static Handle ( _pyGen  )
It also contains data corresponding to SMESH_Gen contents
Referenced by SMESH_2smeshpy::ConvertScript(), and _pyCommand::SetDependentCmdsAfter().
◆ Handle() [4/7]
Handle ( _pyHypothesis  )
Returns a new hypothesis initialized according to the read information.
Creates algorithm or hypothesis.
Find algorithm able to create a hypothesis.
theHypID- The hypothesis ID
Handle(_pyHypothesis)- The found hypothesis
theGeom- The shape ID the algorithm was created on
theMesh- The mesh ID that created the algorithm
theHypothesis- The hypothesis the algorithm should be able to create
Handle(_pyHypothesis)- The found algo
theCreationCmd- The engine command creating a hypothesis
Handle(_pyHypothesis)- Result _pyHypothesis
Adds an object ID to some family of IDs with a common prefix
[in]str- the object ID
bool - false if str does not have the same prefix as this family (for internal usage)
References _pyGen::Handle(), and _pyGen::myHypos.
◆ Handle() [5/7]
Handle ( _pyHypothesisReader  )
Mesh created by SMESH_Gen
◆ Handle() [6/7]
Handle ( _pyObject  )
Check if a study entry is under GEOM component
Returns true if an object is not present in a study
Add an object to myRemovedObjIDs that leads to that SetName() for this object is not dumped
[in]theObjID- entry of the object whose creation command was eliminated
References _pyGen::Handle(), _pyGen::myMeshes, and _pyGen::myObjects.
◆ Handle() [7/7]
Handle ( _pySubMesh  )
theSubMeshID- The subMesh ID
Handle(_pySubMesh)- The found subMesh
References SMESH::DownCast(), _pyGen::Handle(), and _pyGen::myObjects.
◆ isWord()
static bool isWord ( const char  c,
c- The character to check
bool- The check result
Referenced by _pyCommand::GetWord().
Variable Documentation
◆ theEmptyString
