_pyCommand Class Reference
Class operating on a command string looking like ResultValue = Object.Method( Arg1, Arg2,...) More...
#include <SMESH_2smeshpy.hxx>
Inheritance diagram for _pyCommand:
typedef void * TAddr
 _pyCommand ()
 _pyCommand (const _AString &theString, int theNb=-1)
_AString & GetString ()
int GetOrderNb () const
void SetOrderNb (int theNb)
TAddr GetAddress () const
int Length () const
void Clear ()
bool IsEmpty () const
_AString GetIndentation ()
 Returns whitespace symbols at the line beginning. More...
const _AString & GetResultValue ()
 Return substring of python command looking like ResultValue = Obj.Meth() More...
int GetNbResultValues ()
 Return number of python command result value ResultValue = Obj.Meth() More...
const _AString & GetResultValue (int res)
 Return substring of python command looking like ResultValue1 , ResultValue2,... = Obj.Meth() with res index. More...
const _AString & GetObject ()
 Return substring of python command looking like ResVal = Object.Meth() More...
const _AString & GetMethod ()
 Return substring of python command looking like ResVal = Obj.Method() More...
const _AString & GetArg (int index)
 Return substring of python command looking like ResVal = Obj.Meth(Arg1,...) More...
int GetNbArgs ()
int GetArgBeginning () const
 Return position where arguments begin. More...
bool IsMethodCall ()
 Returns true if there are brackets after the method. More...
bool MethodStartsFrom (const _AString &beg)
void SetResultValue (const _AString &theResult)
void SetObject (const _AString &theObject)
void SetMethod (const _AString &theMethod)
void SetArg (int index, const _AString &theArg)
 Set argument. More...
void RemoveArgs ()
 Empty arg list. More...
void Comment ()
 Comment a python command. More...
void AddDependantCmd (Handle(_pyCommand) cmd, bool prepend=false)
bool SetDependentCmdsAfter () const
 Set dependent commands after this one. More...
bool AddAccessorMethod (_pyID theObjectID, const char *theAcsMethod)
 Insert accessor method after theObjectID. More...
static bool SkipSpaces (const _AString &theSring, int &thePos)
 Look for position where not space char is. More...
static _AString GetWord (const _AString &theSring, int &theStartPos, const bool theForward, const bool dotIsWord=false)
 Looks for a word in the string and returns word's beginning. More...
static bool IsStudyEntry (const _AString &str)
 Returns true if the string looks like a study entry. More...
static bool IsID (const _AString &str)
 Returns true if the string looks like an object ID but not like a list, string, command etc. More...
static bool IsIDChar (char c)
static std::list< _pyID > GetStudyEntries (const _AString &str)
 Finds entries in a string. More...
Private Types
enum  {
  UNKNOWN =-1 , EMPTY =0 , RESULT_IND , OBJECT_IND ,
  METHOD_IND , ARG1_IND
int GetBegPos (int thePartIndex) const
 Return starting position of a part of python command. More...
void SetBegPos (int thePartIndex, int thePosition)
 Store starting position of a part of python command. More...
void SetPart (int thePartIndex, const _AString &theNewPart, _AString &theOldPart)
 Modify a part of the command. More...
void FindAllArgs ()
int myOrderNb
 position within the script More...
_AString myString
 command text More...
_AString myRes
_AString myObj
_AString myMeth
 found parts of command More...
TColStd_SequenceOfAsciiString myArgs
 found arguments More...
TColStd_SequenceOfAsciiString myResults
 found results More...
TColStd_SequenceOfInteger myBegPos
 where myRes, myObj, ... begin More...
std::list< Handle(_pyCommand) > myDependentCmds
 commands that should follow me in the script More...
◆ TAddr
typedef void* _pyCommand::TAddr
◆ anonymous enum
anonymous enum
UNKNOWN
EMPTY
RESULT_IND
OBJECT_IND
METHOD_IND
ARG1_IND
◆ _pyCommand() [1/2]
_pyCommand::_pyCommand ( )
◆ _pyCommand() [2/2]
_pyCommand::_pyCommand ( const _AString &  theString,
int  theNb = -1
◆ AddAccessorMethod()
bool _pyCommand::AddAccessorMethod ( _pyID  theObjectID,
const char *  theAcsMethod
theObjectID- id of the accessed object
theAcsMethod- name of the method giving access to the object
bool- false if theObjectID is not found in the command string
References GetBegPos(), GetObject(), IsIDChar(), Length(), myBegPos, myString, and OBJECT_IND.
Referenced by _pyGen::AddAlgoAccessorMethod(), and _pyGen::AddMeshAccessorMethod().
◆ AddDependantCmd()
void _pyCommand::AddDependantCmd ( Handle(_pyCommand)  cmd,
bool  prepend = false
◆ Clear()
◆ Comment()
void _pyCommand::Comment ( )
References EMPTY, GetBegPos(), IsEmpty(), Length(), myBegPos, myString, SetBegPos(), and UNKNOWN.
◆ FindAllArgs()
void _pyCommand::FindAllArgs ( )
Referenced by SetArg().
◆ GetAddress()
TAddr _pyCommand::GetAddress ( ) const
◆ GetArg()
◆ GetArgBeginning()
int _pyCommand::GetArgBeginning ( ) const
References ARG1_IND, GetBegPos(), Length(), METHOD_IND, myMeth, myString, and UNKNOWN.
Referenced by _pyStringFamily::IsInArgs().
◆ GetBegPos()
int _pyCommand::GetBegPos ( int  thePartIndex) const
thePartIndex- The index of command part
int- Part position
References EMPTY, IsEmpty(), myBegPos, and UNKNOWN.
Referenced by AddAccessorMethod(), Comment(), GetArg(), GetArgBeginning(), GetMethod(), GetObject(), GetResultValue(), IsMethodCall(), RemoveArgs(), SetArg(), and SetPart().
◆ GetIndentation()
TCollection_AsciiString _pyCommand::GetIndentation ( )
TCollection_AsciiString- result
References end(), Length(), and myString.
◆ GetMethod()
◆ GetNbArgs()
◆ GetNbResultValues()
int _pyCommand::GetNbResultValues ( )
References GetResultValue(), and myResults.
Referenced by _pyGroup::_pyGroup().
◆ GetObject()
const TCollection_AsciiString & _pyCommand::GetObject ( )
constTCollection_AsciiString & - Object substring
References EMPTY, GetBegPos(), GetWord(), Length(), myObj, myRes, myString, OBJECT_IND, RESULT_IND, SetBegPos(), and UNKNOWN.
Referenced by _pyMesh::_pyMesh(), _pyMeshEditor::_pyMeshEditor(), _pySubMesh::_pySubMesh(), AddAccessorMethod(), _pyMesh::AddMeshAccess(), _pySelfEraser::IsAliveCmd(), and _pyFilter::Process().
◆ GetOrderNb()
int _pyCommand::GetOrderNb ( ) const
◆ GetResultValue() [1/2]
const TCollection_AsciiString & _pyCommand::GetResultValue ( )
constTCollection_AsciiString & - ResultValue substring
References EMPTY, GetBegPos(), Length(), myRes, myString, RESULT_IND, SetBegPos(), and UNKNOWN.
Referenced by GetNbResultValues(), GetResultValue(), _pyGen::Process(), _pyMesh::Process(), _pyMeshEditor::Process(), and _pyGroup::Process().
◆ GetResultValue() [2/2]
const _AString & _pyCommand::GetResultValue ( int  res)
constTCollection_AsciiString & - ResultValue with res index substring
References GetResultValue(), GetWord(), IsEmpty(), myRes, myResults, SkipSpaces(), and theEmptyString.
◆ GetString()
◆ GetStudyEntries()
std::list< _pyID > _pyCommand::GetStudyEntries ( const _AString &  str)
◆ GetWord()
TCollection_AsciiString _pyCommand::GetWord ( const _AString &  theString,
int &  theStartPos,
const bool  dotIsWord = false
theString- The input string
theStartPos- The position to start the search, returning word's beginning
theForward- The search direction
TCollection_AsciiString- The found word
References EMPTY, end(), isWord(), and theEmptyString.
Referenced by _pyHypothesisReader::_pyHypothesisReader(), GetMethod(), GetObject(), and GetResultValue().
◆ IsEmpty()
◆ IsID()
bool _pyCommand::IsID ( const _AString &  str)
References IsIDChar().
◆ IsIDChar()
static bool _pyCommand::IsIDChar ( char  c)
◆ IsMethodCall()
bool _pyCommand::IsMethodCall ( )
References GetBegPos(), GetMethod(), IsEmpty(), METHOD_IND, myMeth, and myString.
◆ IsStudyEntry()
bool _pyCommand::IsStudyEntry ( const _AString &  str)
Referenced by _pyGen::_pyGen(), _pyGen::CheckObjectIsReCreated(), GetStudyEntries(), and _pyMesh::Process().
◆ Length()
◆ MethodStartsFrom()
bool _pyCommand::MethodStartsFrom ( const _AString &  beg)
◆ RemoveArgs()
◆ SetArg()
void _pyCommand::SetArg ( int  index,
const _AString &  theArg
◆ SetBegPos()
void _pyCommand::SetBegPos ( int  thePartIndex,
int  thePosition
thePosition- Part position
References myBegPos, and UNKNOWN.
Referenced by Comment(), GetArg(), GetMethod(), GetObject(), GetResultValue(), and SetArg().
◆ SetDependentCmdsAfter()
bool _pyCommand::SetDependentCmdsAfter ( ) const
References GetOrderNb(), Handle(), and myDependentCmds.
◆ SetMethod()
◆ SetObject()
◆ SetOrderNb()
void _pyCommand::SetOrderNb ( int  theNb)
◆ SetPart()
void _pyCommand::SetPart ( int  thePartIndex,
const _AString &  theNewPart,
_AString &  theOldPart
thePartIndex- The index of the part
thePart- The new part string
theOldPart- The old part
References GetBegPos(), Length(), METHOD_IND, myBegPos, myString, OBJECT_IND, and RESULT_IND.
◆ SetResultValue()
void _pyCommand::SetResultValue ( const _AString &  theResult)
◆ SkipSpaces()
bool _pyCommand::SkipSpaces ( const _AString &  theSring,
int &  thePos
theString- The string
thePos- The position to search from and which returns result
bool- false if there are only space after thePos in theString
Referenced by GetResultValue().
◆ myArgs
TColStd_SequenceOfAsciiString _pyCommand::myArgs
found arguments
Referenced by GetArg(), RemoveArgs(), and SetArg().
◆ myBegPos
TColStd_SequenceOfInteger _pyCommand::myBegPos
Referenced by AddAccessorMethod(), Comment(), GetBegPos(), RemoveArgs(), SetBegPos(), and SetPart().
◆ myDependentCmds
std::list< Handle(_pyCommand) > _pyCommand::myDependentCmds
Referenced by SetDependentCmdsAfter().
◆ myMeth
_AString _pyCommand::myMeth
Referenced by GetArg(), GetArgBeginning(), GetMethod(), and IsMethodCall().
◆ myObj
_AString _pyCommand::myObj
Referenced by GetMethod(), and GetObject().
◆ myOrderNb
int _pyCommand::myOrderNb
◆ myRes
_AString _pyCommand::myRes
Referenced by GetObject(), and GetResultValue().
◆ myResults
TColStd_SequenceOfAsciiString _pyCommand::myResults
found results
Referenced by GetNbResultValues(), and GetResultValue().
◆ myString
