_pyComplexParamHypo Class Reference
Class for hypotheses having several parameters modified by one method. More...
#include <SMESH_2smeshpy.hxx>
Inheritance diagram for _pyComplexParamHypo:
 _pyComplexParamHypo (const Handle(_pyCommand)&theCreationCmd)
virtual void Process (const Handle(_pyCommand)&theCommand)
 Remember hypothesis parameter values. More...
virtual void Flush ()
 Clear SetObjectEntry() as it is called by methods of Mesh_Segment. More...
void SetConvMethodAndType (const _AString &creationMethod, const _AString &type)
void AddArgMethod (const _AString &method, const int argNb=1)
void AddAccumulativeMethod (const _AString &method)
const std::list< Handle(_pyCommand)> & GetArgCommands () const
void ClearAllCommands ()
 clear creation, arg and unknown commands More...
virtual bool IsAlgo () const
bool IsValid () const
bool IsWrapped () const
const _pyID & GetGeom () const
void SetMesh (const _pyID &theMeshId)
const _pyID & GetMesh () const
const _AString & GetAlgoType () const
const _AString & GetAlgoCreationMethod () const
bool CanBeCreatedBy (const _AString &algoType) const
const _AString & GetCreationMethod (const _AString &algoType)
const Handle (_pyCommand) &GetCreationCmd()
virtual bool IsWrappable (const _pyID &theMesh) const
 Returns true if addition of this hypothesis to a given mesh can be wrapped into hypothesis creation. More...
virtual bool Addition2Creation (const Handle(_pyCommand)&theAdditionCmd, const _pyID &theMesh)
 Convert the command adding a hypothesis to mesh into a smesh command. More...
virtual void Process (const Handle(_pyCommand) &cmd)
virtual void Free ()
virtual void Assign (const Handle(_pyHypothesis)&theOther, const _pyID &theMesh)
 Assign fields of theOther to me except myIsWrapped. More...
virtual bool CanClear ()
 Analyze my erasability depending on myReferredObjs. More...
virtual void ClearCommands ()
 Clear my commands depending on usage by meshes. More...
virtual bool GetReferredMeshesAndGeom (std::list< Handle(_pyMesh) > &meshes)
 Find arguments that are objects like mesh, group, geometry. More...
void MeshComputed (const Handle(_pyCommand)&theComputeCommand)
 Save commands setting parameters as they are used for a mesh computation. More...
void ComputeDiscarded (const Handle(_pyCommand)&theComputeCommand)
 Clear commands setting parameters as a mesh computed using them is cleared. More...
const _pyID & GetID ()
int GetNbCalls () const
bool IsInStudy () const
virtual void SetRemovedFromStudy (const bool isRemoved)
void SetCreationCmd (Handle(_pyCommand) cmd)
int GetCommandNb ()
void AddProcessedCmd (const Handle(_pyCommand) &cmd)
std::list< Handle(_pyCommand) > & GetProcessedCmds ()
void AddArgCmd (const Handle(_pyCommand) &cmd)
virtual const char * AccessorMethod () const
 Return method name giving access to an interaface object wrapped by python class. More...
static Handle (_pyHypothesis) NewHypothesis(const Handle(_pyCommand) &theCreationCmd)
static _pyID FatherID (const _pyID &childID)
 Return ID of a father. More...
Protected Types
typedef std::map< _AString, CreationMethod > TType2CrMethod
void setCreationArg (const int argNb, const _AString &arg)
 Sets an argNb-th argument of current creation command. More...
void rememberCmdOfParameter (const Handle(_pyCommand) &cmd)
 Remember theCommand setting a parameter. More...
bool isCmdUsedForCompute (const Handle(_pyCommand) &cmd, _pyCommand::TAddr avoidComputeAddr=NULL) const
 Return true if a setting parameter command has been used to compute mesh. More...
 Handle (_pyCommand) myCreationCmd
void setID (const _pyID &theID)
 Set up myID and myIsPublished. More...
bool myIsAlgo
bool myIsWrapped
_pyID myGeom
_pyID myMesh
TType2CrMethod myAlgoType2CreationMethod
std::set< _AString > myAccumulativeMethods
CreationMethod * myCurCrMethod
std::list< Handle(_pyCommand)> myArgCommands
std::list< Handle(_pyCommand)> myUnusedCommands
std::list< Handle(_pyObject) > myReferredObjs
std::map< _AString, std::list< Handle(_pyCommand)> > myMeth2Commands
std::map< _pyCommand::TAddr, std::list< Handle(_pyCommand) > > myComputeAddr2Cmds
std::list< Handle(_pyCommand) > myComputeCmds
_pyID myID
std::list< Handle(_pyCommand) > myProcessedCmds
std::list< Handle(_pyCommand) > myArgCmds
bool myIsPublished
◆ TType2CrMethod
typedef std::map<_AString, CreationMethod > _pyHypothesis::TType2CrMethod
◆ _pyComplexParamHypo()
_pyComplexParamHypo::_pyComplexParamHypo ( const Handle(_pyCommand)&  theCreationCmd)
◆ AccessorMethod()
const char * _pyObject::AccessorMethod ( ) const
constchar* - method name
Reimplemented in _pyGen, _pyMesh, and _pyAlgorithm.
◆ AddAccumulativeMethod()
void _pyHypothesis::AddAccumulativeMethod ( const _AString &  method)
◆ AddArgCmd()
void _pyObject::AddArgCmd ( const Handle(_pyCommand) &  cmd)
References _pyObject::myArgCmds.
◆ AddArgMethod()
void _pyHypothesis::AddArgMethod ( const _AString &  method,
const int  argNb = 1
◆ Addition2Creation()
◆ AddProcessedCmd()
void _pyObject::AddProcessedCmd ( const Handle(_pyCommand) &  cmd)
◆ Assign()
void _pyHypothesis::Assign ( const Handle(_pyHypothesis)&  theOther,
const _pyID &  theMesh
◆ CanBeCreatedBy()
bool _pyHypothesis::CanBeCreatedBy ( const _AString &  algoType) const
◆ CanClear()
bool _pyHypothesis::CanClear ( )
Reimplemented from _pyObject.
References _pyHypothesis::Handle(), _pyObject::IsInStudy(), and _pyHypothesis::myReferredObjs.
◆ ClearAllCommands()
void _pyHypothesis::ClearAllCommands ( )
References _pyHypothesis::Handle(), _pyHypothesis::myArgCommands, and _pyHypothesis::myUnusedCommands.
◆ ClearCommands()
void _pyHypothesis::ClearCommands ( )
References _pyObject::ClearCommands().
◆ ComputeDiscarded()
void _pyHypothesis::ComputeDiscarded ( const Handle(_pyCommand)&  theComputeCommand)
References _pyCommand::GetAddress(), _pyHypothesis::Handle(), _pyHypothesis::isCmdUsedForCompute(), _pyHypothesis::myComputeAddr2Cmds, and _pyHypothesis::myMeth2Commands.
◆ FatherID()
_pyID _pyObject::FatherID ( const _pyID &  childID)
Referenced by _pySegmentLengthAroundVertexHyp::Addition2Creation().
◆ Flush()
void _pyComplexParamHypo::Flush ( )
Reimplemented from _pyHypothesis.
References _pyHypothesis::Handle(), _pyHypothesis::IsWrapped(), and _pyHypothesis::myUnusedCommands.
◆ Free()
virtual void _pyHypothesis::Free ( )
Reimplemented in _pyLayerDistributionHypo.
References _pyHypothesis::myReferredObjs.
◆ GetAlgoCreationMethod()
const _AString & _pyHypothesis::GetAlgoCreationMethod ( ) const
◆ GetAlgoType()
const _AString & _pyHypothesis::GetAlgoType ( ) const
◆ GetArgCommands()
const std::list< Handle(_pyCommand)> & _pyHypothesis::GetArgCommands ( ) const
◆ GetCommandNb()
int _pyObject::GetCommandNb ( )
◆ GetCreationMethod()
const _AString & _pyHypothesis::GetCreationMethod ( const _AString &  algoType)
◆ GetGeom()
const _pyID & _pyHypothesis::GetGeom ( ) const
References _pyHypothesis::myGeom.
◆ GetID()
◆ GetMesh()
const _pyID & _pyHypothesis::GetMesh ( ) const
References _pyHypothesis::myMesh.
◆ GetNbCalls()
int _pyObject::GetNbCalls ( ) const
◆ GetProcessedCmds()
std::list< Handle(_pyCommand) > & _pyObject::GetProcessedCmds ( )
◆ GetReferredMeshesAndGeom()
bool _pyHypothesis::GetReferredMeshesAndGeom ( std::list< Handle(_pyMesh) > &  meshes)
meshes- referred meshes (directly or indirrectly)
bool- false if a referred geometry is not in the study
References _pyCommand::GetStudyEntries(), _pyHypothesis::Handle(), _pyHypothesis::IsAlgo(), _pyObject::IsInStudy(), _pyHypothesis::myAlgoType2CreationMethod, _pyHypothesis::CreationMethod::myArgs, _pyHypothesis::myReferredObjs, and _pyHypothesis::myUnusedCommands.
◆ Handle() [1/3]
const _pyObject::Handle ( _pyCommand  ) &
◆ Handle() [2/3]
◆ Handle() [3/3]
◆ IsAlgo()
virtual bool _pyHypothesis::IsAlgo ( ) const
◆ isCmdUsedForCompute()
bool _pyHypothesis::isCmdUsedForCompute ( const Handle(_pyCommand) &  cmd,
_pyCommand::TAddr  avoidComputeAddr = NULL
References _pyHypothesis::Handle(), and _pyHypothesis::myComputeAddr2Cmds.
Referenced by _pyHypothesis::ComputeDiscarded(), and _pyHypothesis::rememberCmdOfParameter().
◆ IsInStudy()
◆ IsValid()
bool _pyHypothesis::IsValid ( ) const
◆ IsWrappable()
bool _pyHypothesis::IsWrappable ( const _pyID &  theMesh) const
References _pyHypothesis::Handle(), _pyObject::IsInStudy(), _pyHypothesis::myIsWrapped, and _pyHypothesis::myMesh.
Referenced by _pyHypothesis::Addition2Creation(), _pyNumberOfSegmentsHyp::Addition2Creation(), and _pySegmentLengthAroundVertexHyp::Addition2Creation().
◆ IsWrapped()
bool _pyHypothesis::IsWrapped ( ) const
◆ MeshComputed()
void _pyHypothesis::MeshComputed ( const Handle(_pyCommand)&  theComputeCommand)
References _pyCommand::GetAddress(), _pyHypothesis::Handle(), _pyHypothesis::myComputeAddr2Cmds, _pyHypothesis::myComputeCmds, and _pyHypothesis::myMeth2Commands.
◆ Process() [1/2]
virtual void _pyObject::Process ( const Handle(_pyCommand) &  cmd)
◆ Process() [2/2]
void _pyComplexParamHypo::Process ( const Handle(_pyCommand)&  theCommand)
◆ rememberCmdOfParameter()
◆ SetConvMethodAndType()
void _pyHypothesis::SetConvMethodAndType ( const _AString &  creationMethod,
const _AString &  type
◆ setCreationArg()
void _pyHypothesis::setCreationArg ( const int  argNb,
const _AString &  arg
argNb- argument index countered from 1
References _pyHypothesis::CreationMethod::myArgs, and _pyHypothesis::myCurCrMethod.
Referenced by Process().
◆ SetCreationCmd()
void _pyObject::SetCreationCmd ( Handle(_pyCommand)  cmd)
◆ setID()
void _pyObject::setID ( const _pyID &  theID)
References _pyObject::GetID(), _pyObject::myID, and _pyObject::myIsPublished.
Referenced by _pyGroup::_pyGroup(), and _pyObject::_pyObject().
◆ SetMesh()
void _pyHypothesis::SetMesh ( const _pyID &  theMeshId)
◆ SetRemovedFromStudy()
virtual void _pyObject::SetRemovedFromStudy ( const bool  isRemoved)
Reimplemented in _pyMesh.
References _pyObject::myIsPublished.
Referenced by _pyMesh::SetRemovedFromStudy().
◆ myAccumulativeMethods
std::set< _AString > _pyHypothesis::myAccumulativeMethods
◆ myAlgoType2CreationMethod
◆ myArgCmds
std::list< Handle(_pyCommand) > _pyObject::myArgCmds
◆ myArgCommands
◆ myComputeAddr2Cmds
std::map< _pyCommand::TAddr, std::list<Handle(_pyCommand) > > _pyHypothesis::myComputeAddr2Cmds
◆ myComputeCmds
std::list<Handle(_pyCommand) > _pyHypothesis::myComputeCmds
◆ myCurCrMethod
◆ myGeom
_pyID _pyHypothesis::myGeom
◆ myID
_pyID _pyObject::myID
◆ myIsAlgo
◆ myIsPublished
◆ myIsWrapped
◆ myMesh
◆ myMeth2Commands
std::map<_AString, std::list<Handle(_pyCommand)> > _pyHypothesis::myMeth2Commands
◆ myProcessedCmds
std::list< Handle(_pyCommand) > _pyObject::myProcessedCmds
◆ myReferredObjs
std::list<Handle(_pyObject) > _pyHypothesis::myReferredObjs
◆ myUnusedCommands
