_pyStringFamily Class Reference
A container of strings grouped by prefix. More...
#include <SMESH_2smeshpy.hxx>
bool Add (const char *str)
bool IsInArgs (Handle(_pyCommand)&cmd, std::list< _AString > &subStr)
 Finds an object ID in the command. More...
void Print (int level=0)
 DEBUG. More...
int isIn (const char *str)
 Return remainder length of the object ID after my _prefix. More...
_AString _prefix
std::list< _pyStringFamily > _subFams
std::list< _AString > _strings
It is used for a faster search of objects requiring to KeepAgrCmds() in commands. A speed up is gained because only a common prefix (e.g. "aArea") of many object IDs is searched in a command and not every object ID
◆ Add()
bool _pyStringFamily::Add ( const char *  str)
Referenced by _pyGen::KeepAgrCmds().
◆ isIn()
int _pyStringFamily::isIn ( const char *  str)
[in]str- remainder of the command after my _prefix
int - length of the object ID or -1 if not found
References _strings, _subFams, and _pyCommand::IsIDChar().
◆ IsInArgs()
bool _pyStringFamily::IsInArgs ( Handle(_pyCommand)&  cmd,
std::list< _AString > &  subStr
[in]longStr- the command string
[out]subStr- the found object ID
bool - true if the object ID found
References _strings, _subFams, _pyCommand::GetArgBeginning(), _pyCommand::GetString(), and _pyCommand::IsIDChar().
Referenced by Handle().
◆ Print()
void _pyStringFamily::Print ( int  level = 0)
DEBUG.
References _prefix, _strings, and _subFams.
◆ _prefix
_AString _pyStringFamily::_prefix
Referenced by Print().
◆ _strings
std::list< _AString > _pyStringFamily::_strings
Referenced by isIn(), IsInArgs(), and Print().
◆ _subFams
std::list< _pyStringFamily > _pyStringFamily::_subFams
