interface of "ProjectionSource1D" hypothesis. More...
| void | SetSourceEdge (in GEOM::GEOM_Object edge) raises (SALOME::SALOME_Exception) |
| Sets source <edge> to take a mesh pattern from. More... | |
| GEOM::GEOM_Object | GetSourceEdge () |
| Returns the source edge. More... | |
| void | SetSourceMesh (in SMESH::SMESH_Mesh mesh) |
| Sets source <mesh> to take a mesh pattern from. More... | |
| SMESH::SMESH_Mesh | GetSourceMesh () |
| Return source mesh. More... | |
| void | SetVertexAssociation (in GEOM::GEOM_Object sourceVertex, in GEOM::GEOM_Object targetVertex) raises (SALOME::SALOME_Exception) |
| Sets vertex association between the source edge and the target one. More... | |
| GEOM::GEOM_Object | GetSourceVertex () |
| Returns the vertex associated with the target vertex. More... | |
| GEOM::GEOM_Object | GetTargetVertex () |
| Returns the vertex associated with the source vertex. More... | |
| string | GetName () |
| Get the Hypothesis typeName. More... | |
| string | GetLibName () |
| Get the Hypothesis plugin library Name. More... | |
| short | GetId () |
| Get the internal Id. More... | |
| void | SetVarParameter (in string parameter, in string method) |
| Set the variable parameter. More... | |
| string | GetVarParameter (in string methodName) |
| Return the variable parameter used for Hypothesis creation by name of method setting this parameter. More... | |
| void | SetHolderHypothesis (in SMESH::SMESH_Hypothesis hyp) |
| Store a hypothesis wrapping this not published one. More... | |
| boolean | IsDimSupported (in Dimension type) |
| Verify whether hypothesis supports given entity type. More... | |
| boolean | HasParameters () |
| Return true if a hypothesis has parameters. More... | |
This hypothesis specifies a meshed edge to take a mesh pattern from and optionally association of vertices between the source edge and a target one (where a hypothesis is assigned to)
| GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource1D::GetSourceEdge | ( | ) |
| SMESH::SMESH_Mesh StdMeshers::StdMeshers_ProjectionSource1D::GetSourceMesh | ( | ) |
Return source mesh.
| GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource1D::GetSourceVertex | ( | ) |
Result may be nil if association not set
| GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource1D::GetTargetVertex | ( | ) |
| void StdMeshers::StdMeshers_ProjectionSource1D::SetSourceEdge | ( | in GEOM::GEOM_Object | edge | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
| void StdMeshers::StdMeshers_ProjectionSource1D::SetSourceMesh | ( | in SMESH::SMESH_Mesh | mesh | ) |
| void StdMeshers::StdMeshers_ProjectionSource1D::SetVertexAssociation | ( | in GEOM::GEOM_Object | sourceVertex, |
| in GEOM::GEOM_Object | targetVertex | ||
This parameter is optional
