interface of "ProjectionSource2D" hypothesis. More...
| void | SetSourceFace (in GEOM::GEOM_Object face) raises (SALOME::SALOME_Exception) |
| Sets a source <face> to take a mesh pattern from. More... | |
| GEOM::GEOM_Object | GetSourceFace () |
| Returns the source face. More... | |
| void | SetSourceMesh (in SMESH::SMESH_Mesh mesh) |
| Sets source <mesh> to take a mesh pattern from. More... | |
| SMESH::SMESH_Mesh | GetSourceMesh () |
| Return source mesh. More... | |
| void | SetVertexAssociation (in GEOM::GEOM_Object sourceVertex1, in GEOM::GEOM_Object sourceVertex2, in GEOM::GEOM_Object targetVertex1, in GEOM::GEOM_Object targetVertex2) raises (SALOME::SALOME_Exception) |
| Sets vertex association between the source face and the target one. More... | |
| GEOM::GEOM_Object | GetSourceVertex (in long i) raises (SALOME::SALOME_Exception) |
| Returns the -th source vertex associated with the -th target vertex. More... | |
| GEOM::GEOM_Object | GetTargetVertex (in long i) raises (SALOME::SALOME_Exception) |
| Returns the -th target vertex associated with the -th source vertex. More... | |
| string | GetName () |
| Get the Hypothesis typeName. More... | |
| string | GetLibName () |
| Get the Hypothesis plugin library Name. More... | |
| short | GetId () |
| Get the internal Id. More... | |
| void | SetVarParameter (in string parameter, in string method) |
| Set the variable parameter. More... | |
| string | GetVarParameter (in string methodName) |
| Return the variable parameter used for Hypothesis creation by name of method setting this parameter. More... | |
| void | SetHolderHypothesis (in SMESH::SMESH_Hypothesis hyp) |
| Store a hypothesis wrapping this not published one. More... | |
| boolean | IsDimSupported (in Dimension type) |
| Verify whether hypothesis supports given entity type. More... | |
| boolean | HasParameters () |
| Return true if a hypothesis has parameters. More... | |
This hypothesis specifies a meshed face to take a mesh pattern from and optionally association of vertices between the source face and a target one (where a hypothesis is assigned to)
| GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource2D::GetSourceFace | ( | ) |
| SMESH::SMESH_Mesh StdMeshers::StdMeshers_ProjectionSource2D::GetSourceMesh | ( | ) |
Return source mesh.
| GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource2D::GetSourceVertex | ( | in long | i | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
Result may be nil if association not set. Valid indices are 1 and 2
| GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource2D::GetTargetVertex | ( | in long | i | ) | |
| void StdMeshers::StdMeshers_ProjectionSource2D::SetSourceFace | ( | in GEOM::GEOM_Object | face | ) | |
| void StdMeshers::StdMeshers_ProjectionSource2D::SetSourceMesh | ( | in SMESH::SMESH_Mesh | mesh | ) |
| void StdMeshers::StdMeshers_ProjectionSource2D::SetVertexAssociation | ( | in GEOM::GEOM_Object | sourceVertex1, |
| in GEOM::GEOM_Object | sourceVertex2, | ||
| in GEOM::GEOM_Object | targetVertex1, | ||
| in GEOM::GEOM_Object | targetVertex2 | ||
This parameter is optional. Two vertices must belong to one edge of a face
