StdMeshers::StdMeshers_ProjectionSource3D Interface Reference
interface of "ProjectionSource3D" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_ProjectionSource3D:
void SetSource3DShape (in GEOM::GEOM_Object shape) raises (SALOME::SALOME_Exception)
 Sets a source <shape> to take a mesh pattern from. More...
GEOM::GEOM_Object GetSource3DShape ()
 Returns the source shape. More...
void SetSourceMesh (in SMESH::SMESH_Mesh mesh)
 Sets source <mesh> to take a mesh pattern from. More...
SMESH::SMESH_Mesh GetSourceMesh ()
 Return source mesh. More...
void SetVertexAssociation (in GEOM::GEOM_Object sourceVertex1, in GEOM::GEOM_Object sourceVertex2, in GEOM::GEOM_Object targetVertex1, in GEOM::GEOM_Object targetVertex2) raises (SALOME::SALOME_Exception)
 Sets vertex association between the source shape and the target one. More...
GEOM::GEOM_Object GetSourceVertex (in long i) raises (SALOME::SALOME_Exception)
 Returns the -th source vertex associated with the -th target vertex. More...
GEOM::GEOM_Object GetTargetVertex (in long i) raises (SALOME::SALOME_Exception)
 Returns the -th target vertex associated with the -th source vertex. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
This hypothesis specifies a meshed shell or solid to take a mesh pattern from and optionally association of vertices between the source shape and a target one (where a hypothesis is assigned to)
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetSource3DShape()
GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource3D::GetSource3DShape ( )
◆ GetSourceMesh()
SMESH::SMESH_Mesh StdMeshers::StdMeshers_ProjectionSource3D::GetSourceMesh ( )
Return source mesh.
◆ GetSourceVertex()
GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource3D::GetSourceVertex ( in long  i)
Result may be nil if association not set. Valid indices are 1 and 2
◆ GetTargetVertex()
GEOM::GEOM_Object StdMeshers::StdMeshers_ProjectionSource3D::GetTargetVertex ( in long  i)
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetSource3DShape()
void StdMeshers::StdMeshers_ProjectionSource3D::SetSource3DShape ( in GEOM::GEOM_Object  shape)
◆ SetSourceMesh()
void StdMeshers::StdMeshers_ProjectionSource3D::SetSourceMesh ( in SMESH::SMESH_Mesh  mesh)
◆ SetVarParameter()
in string  method
◆ SetVertexAssociation()
void StdMeshers::StdMeshers_ProjectionSource3D::SetVertexAssociation ( in GEOM::GEOM_Object  sourceVertex1,
This parameter is optional. Two vertices must belong to one edge of a shape
