StdMeshers_Cartesian_3D: interface of "ViscousLayerBuilder" algorithm.
More...
◆ AddLayers()
| boolean StdMeshers::StdMeshers_ViscousLayerBuilder::AddLayers |
in SMESH::SMESH_Mesh |
sourceMesh, |
finalMesh, |
in GEOM::GEOM_Object |
theObject |
| raises | ( | SALOME::SALOME_Exception |
Build the prismatic layer from the shrink mesh.
◆ GetCompatibleHypothesis()
| ListOfHypothesisName SMESH::SMESH_Algo::GetCompatibleHypothesis |
Get list of hypothesis that can be used with this algorithm.
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetShrinkGeometry()
| GEOM::GEOM_Object StdMeshers::StdMeshers_ViscousLayerBuilder::GetShrinkGeometry |
finalMesh, |
theObject |
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetFaces()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetFaces |
in SMESH::long_array |
faceIDs, |
in boolean |
toIgnore |
Set faces either to exclude from treatment or to make the offset geometry on.
◆ SetGroupName()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetGroupName |
in string |
name | ) |
◆ SetHolderHypothesis()
◆ SetIgnoreFaces()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetIgnoreFaces |
faceIDs | ) |
Set faces to exclude from the definition of face to shrink.
◆ SetMethod()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetMethod |
in VLExtrusionMethod |
how | ) |
◆ SetNumberLayers()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetNumberLayers |
in short |
numberOfLayers | ) |
◆ SetStretchFactor()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetStretchFactor |
in double |
strechFactor | ) |
◆ SetTotalThickness()
| void StdMeshers::StdMeshers_ViscousLayerBuilder::SetTotalThickness |
in double |
thickness | ) |
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
