Fields
Create
Standard build of a tensor field on cells with no time attached
fieldOnCells->
setName(
"MyTensorFieldOnCellNoTime");
mesh->decrRef();
Definition: MEDCouplingMemArray.hxx:616
static DataArrayDouble * New()
Definition: MEDCouplingMemArray.cxx:878
void alloc(std::size_t nbOfTuple, std::size_t nbOfCompo=1)
Definition: MEDCouplingMemArray.txx:819
void fillWithValue(T val)
Definition: MEDCouplingMemArray.txx:1104
Definition: MEDCouplingFieldDouble.hxx:35
static MEDCouplingFieldDouble * New(TypeOfField type, TypeOfTimeDiscretization td=ONE_TIME)
Definition: MEDCouplingFieldDouble.cxx:67
void setArray(typename Traits< T >::ArrayType *array)
Definition: MEDCouplingFieldT.hxx:60
const MEDCoupling::MEDCouplingMesh * getMesh() const
Definition: MEDCouplingField.hxx:53
void setMesh(const MEDCoupling::MEDCouplingMesh *mesh)
Definition: MEDCouplingField.cxx:304
Definition: MEDCouplingField.hxx:55
virtual mcIdType getNumberOfCells() const =0
bool decrRef() const
Definition: MEDCouplingRefCountObject.cxx:290
@ NO_TIME
Definition: MEDCouplingRefCountObject.hxx:55
@ ON_CELLS
Definition: MEDCouplingRefCountObject.hxx:44
Standard build of a scalar field on nodes with no time attached
fieldOnNodes->
setName(
"MyScalarFieldOnNodeNoTime");
mesh->decrRef();
virtual mcIdType getNumberOfNodes() const =0
@ ON_NODES
Definition: MEDCouplingRefCountObject.hxx:45
Standard build of a vector field on cells with one time attached and no time interval
fieldOnCells->
setName(
4.22, 2, -1
mesh->decrRef();
void setTimeUnit(const std::string &unit)
Definition: MEDCouplingFieldT.hxx:73
void setTime(double val, int iteration, int order)
Definition: MEDCouplingFieldT.hxx:83
@ ONE_TIME
Definition: MEDCouplingRefCountObject.hxx:56
Standard build of a vector field on nodes defined on a time interval with a constant value during this interval
fieldOnNodes->
setName(
"MyVecFieldOnNodeWithConstTime");
mesh->decrRef();
void setStartTime(double val, int iteration, int order)
Definition: MEDCouplingFieldT.hxx:85
void setEndTime(double val, int iteration, int order)
Definition: MEDCouplingFieldT.hxx:86
@ CONST_ON_TIME_INTERVAL
Definition: MEDCouplingRefCountObject.hxx:58
Getting maximal and minimal fields
In this example we
- create two fields with two tuples per two components,
- use MaxFields() to get a field holding maximal values of the two fields.
- use MinFields() to get a field holding minimal values of the two fields.
const double vals1[4] = {0., 2., 4., 6.};
const double vals2[4] = {2., 0., 6., 4.};
const double valsMax[4] = {2., 2., 6., 6.};
const double valsMin[4] = {0., 0., 4., 4.};
MCAuto<DataArrayDouble> valsArr1 = DataArrayDouble::New();
valsArr1->useExternalArrayWithRWAccess(vals1, 2, 2);
MCAuto<MEDCouplingFieldDouble> field1 = MEDCouplingFieldDouble::New(
ON_NODES);
field1->setArray(valsArr1);
MCAuto<DataArrayDouble> valsArr2 = DataArrayDouble::New();
valsArr2->useExternalArrayWithRWAccess(vals2, 2, 2);
MCAuto<MEDCouplingFieldDouble> field2 = MEDCouplingFieldDouble::New(
ON_NODES);
field2->setArray(valsArr2);
MCAuto<MEDCouplingFieldDouble> fieldMax = MEDCouplingFieldDouble::MaxFields(field1, field2);
CPPUNIT_ASSERT(std::equal(valsMax, valsMax + 4, fieldMax->getArray()->getConstPointer()));
MCAuto<MEDCouplingFieldDouble> fieldMin = MEDCouplingFieldDouble::MinFields(field1, field2);
CPPUNIT_ASSERT(std::equal(valsMin, valsMin + 4, fieldMin->getArray()->getConstPointer()));
Concatenating fields
In this example we
- create an 1D mesh and a field on it,
- make a deep copy of the mesh and the field,
- translate the mesh and the field,
- use two variants of MergeFields() to create one field from the two by concatenating them and their meshes.
const double coords[3] = {0., 2., 4.};
MCAuto<DataArrayDouble> coordsArr = DataArrayDouble::New();
coordsArr->useExternalArrayWithRWAccess(coords, 3, 1);
MCAuto<MEDCouplingCMesh> mesh1 = MEDCouplingCMesh::New();
mesh1->setCoords(coordsArr);
MCAuto<MEDCouplingFieldDouble> field1 = mesh1->fillFromAnalytic(
ON_CELLS, 1,
"x");
MCAuto<MEDCouplingFieldDouble> field2 = field1->cloneWithMesh(true);
double vec[1] = {5.};
field2->applyFunc("x + 5");
MCAuto<MEDCouplingFieldDouble> field3 = MEDCouplingFieldDouble::MergeFields(field1, field2);
std::vector<const MEDCouplingFieldDouble *> fields(2);
fields[0] = field1;
fields[1] = field2;
MCAuto<MEDCouplingFieldDouble> field4 = MEDCouplingFieldDouble::MergeFields(fields);
Definition: MEDCouplingMesh.hxx:57
The result field is twice "longer" than field1.
Getting a field copy with different time discretization
First, we create a supporting 2D mesh and a field on it got using fillFromAnalytic(). Time discretization of this field is ONE_TIME.
const double coords[4] = {0., 2., 4.};
MCAuto<MEDCouplingCMesh> mesh = MEDCouplingCMesh::New();
mesh->setCoords(coordsArr, coordsArr);
Now we use buildNewTimeReprFromThis() to get a copy of field1 whose time discretization is NO_TIME.
MCAuto<MEDCouplingFieldDouble> field2 = field1->buildNewTimeReprFromThis(
MEDCoupling::NO_TIME,
false);
Creating a field using an expression
First, we create a 2D Cartesian mesh constituted by 2 cells.
const double coords[4] = {0., 2., 4., 6.};
MCAuto<DataArrayDouble> x = DataArrayDouble::New();
x->useExternalArrayWithRWAccess(coords, 3, 1);
MCAuto<DataArrayDouble> y = DataArrayDouble::New();
y->useExternalArrayWithRWAccess(coords, 2, 1);
mesh->setCoords(x, y);
Now we use fillFromAnalytic3() to get a MEDCouplingFieldDouble on cells filled with values computed using an expression func. This expression is applied to coordinates of each point (barycenter) for which the field value is computed. We want to get the field on cells, with 3 components computed as follows. (In func, we refer to the first component of a point using the variable "a", and to the second component, using the variable "b").
- Component #0 = the second coordinate of the point hence "IVec * b" in func.
- Component #1 = the first coordinate of the point hence "JVec * a".
- Component #2 = distance between the point and SC origin (0.,0.) hence "KVec * sqrt( a*a + b*b )".
In addition we want to add 10.0 to each component computed as described above, hence "10" in func.
const char func[] = "IVec * b + JVec * a + KVec * sqrt( a*a + b*b ) + 10";
const char *varNames[2] = {"a", "b"};
std::vector<std::string> varNamesVec(varNames, varNames + 2);
MCAuto<MEDCouplingFieldDouble> field =
Now we ascertain that the result field is as we expect. We check the second tuple of the field. We get barycenter of the cell #1 and checks that values of the second tuple are computed as we want.
double val1[3];
CPPUNIT_ASSERT(field->getNumberOfComponents() == 3);
field->getArray()->getTuple(1, val1);
MCAuto<DataArrayDouble> bc = mesh->computeCellCenterOfMass();
double bc1[2];
bc->getTuple(1, bc1);
double dist = sqrt(bc1[0] * bc1[0] + bc1[1] * bc1[1]);
CPPUNIT_ASSERT_DOUBLES_EQUAL(val1[0], 10 + bc1[1], 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(val1[1], 10 + bc1[0], 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(val1[2], 10 + dist, 13);
First, we create a 2D Cartesian mesh constituted by 2 cells. Note that we set names to coordinates arrays ("a" and "b" ) which will be used to refer to corresponding coordinates within a function.
x->setInfoOnComponent(0, "a");
y->setInfoOnComponent(0, "b");
Now we use fillFromAnalytic2() to get a MEDCouplingFieldDouble on cells filled with values computed using an expression func. This expression is applied to coordinates of each point (barycenter) for which the field value is computed. We want to get the field on cells, with 3 components computed as follows. (In func, we refer to the first component of a point using the variable "a", and to the second component, using the variable "b").
double val1[3];
double bc1[2];
Now we use fillFromAnalytic() to get a MEDCouplingFieldDouble on cells filled with values computed using an expression func. This expression is applied to coordinates of each point (barycenter) for which the field value is computed. We want to get the field on cells, with 3 components computed as follows. (In func, we refer to the first component of a point using the variable "a", and to the second component, using the variable "b").
double val1[3];
double bc1[2];
Creation of a sub part of a field
Creation of a sub part of a field on cells
const double arr1[10] = {3., 103., 4., 104., 5., 105., 6., 106., 7., 107.};
T * getPointer()
Definition: MEDCouplingMemArray.hxx:341
Definition: MEDCouplingUMesh.hxx:40
Definition: MEDCouplingUMesh.cxx:4183
The field on cells f1 lies on a mesh containing 5 cells and 9 nodes. So this field f1 contains 5 tuples of 2 components each (10 values). Now let's create a subfield on cells f2 from f1.
const mcIdType part1[3] = {2, 1, 4};
Traits< T >::FieldType * buildSubPart(const DataArrayIdType *part) const
Definition: MEDCouplingFieldT.txx:598
f1 is a field on cells, buildSubPart method performs an extraction on cells too.
So the array part1 lists ids on cells.
- cell #0 of f2 is the same cell of cell #2 of f1
- cell #1 of f2 is the same cell of cell #1 of f1
- cell #2 of f2 is the same cell of cell #4 of f1
So f2 contains 3 tuples with 2 components.
The underlying mesh of f2 contains a newly created mesh with 3 cells (not as mesh1 in f1) and 9 nodes (as mesh1 in f1).
For fields on cells the number of tuples of the returned field is always equal to the number of ids given in input (here part1).
Only fields on cells have this particular behaviour.
Creation of a sub part of a field on nodes
const double arr2[18] = {
3., 103., 4., 104., 5., 105., 6., 106., 7., 107., 8., 108., 9., 109., 10., 110., 11., 111.
Definition: MEDCouplingPointSet.cxx:55
The field on nodes f1 lies on a mesh containing 5 cells and 9 nodes. So this field f1 contains 9 tuples of 2 components each (18 values). Now let's create a subfield on nodes f2 from f1.
const mcIdType part2[2] = {1, 2};
f1 is a field on nodes, but buildSubPart method performs an extraction on cells.
After the call of buildSubPart on node field f1, f1 will be reduced on a submesh of mesh1 containing cells whose ids are in part2. So here the number of cells of f2 is 2 and the number of nodes is 4.
So contrary to fields on cells, it is normal for fields on nodes that number of tuples of the returned field of buildSubPart method does not match the size of the input array (here part2).
Modify
Subtracting field on different meshes
We make two meshes in 1D space with no cells and 4 nodes. Nodes #0 and #2 are swapped in the two meshes.
And we make two fields on these meshes, so that fields values to equal to node coordinates of the underlying meshes.
const double coords1[4] = {0., 1., 2., 3.};
const double coords2[4] = {2., 1., 0., 3.};
MCAuto<MEDCouplingUMesh> mesh1 = MEDCouplingUMesh::New();
coordsArr->useExternalArrayWithRWAccess(coords1, 4, 1);
mesh1->setMeshDimension(0);
mesh1->allocateCells(0);
mesh1->finishInsertingCells();
MCAuto<MEDCouplingUMesh> mesh2 = (MEDCouplingUMesh *)mesh1->deepCopy();
mesh2->getCoords()->useExternalArrayWithRWAccess(coords2, 4, 1);
We are going to subtract field2 from field1, though they are on different meshes. substractInPlaceDM() allows us doing this. We use a mesh comparison level levOfCheck = 10 that allows subtracting fields on meshes with different node arrays.
const int levOfCheck = 10;
field1->substractInPlaceDM(field2, levOfCheck, 1e-13, 0);
After applying substractInPlaceDM() the both fields lie on mesh2. As substractInPlaceDM() permutes values of field1 before value subtraction, and thus field1 becomes equal to field2, hence their subtraction results in a zero field.
field2->applyFunc(1, 0.0);
CPPUNIT_ASSERT(field1->isEqual(field2, 1e-13, 1e-13));
Changing the underlying mesh
We are going to use changeUnderlyingMesh() to set mesh2 instead of mesh1 as a support of a field.
We use fillFromAnalytic() to make a field on nodes of mesh1, so that its values to equal to node coordinates. Then we use changeUnderlyingMesh() to change the underlying mesh of the field. (We use a mesh comparison level levOfCheck = 10 that allows substituting meshes with different node arrays.) As a result, we expect that values of the field are also permuted same as nodes of the two meshes, and thus its values become equal to the array coords2.
field->changeUnderlyingMesh(mesh2, levOfCheck, 1e-13, 0);
CPPUNIT_ASSERT(std::equal(coords2, coords2 + 4, field->getArray()->getConstPointer()));
Changing a field using an expression
We create a 2D vector field with 2 tuples and we want to transform this field using an expression using applyFunc(). The expression func is applied to each atomic value of the field. We want to change the field as follows. (In func, we use the variable "v" to refer to an atomic field value).
- Component #0 = component #0 (remains the same) hence "IVec * v" in func.
- Component #1 = component #1 ^ 2 hence "JVec * v*v".
const double v[4] = {1., 2., 3., 4.};
MCAuto<DataArrayDouble> array = DataArrayDouble::New();
array->useExternalArrayWithRWAccess(v, 2, 2);
field->setArray(array);
const char func[] = "IVec * v + JVec * w*w + 10";
field->applyFunc(2, func);
CPPUNIT_ASSERT(field->getNumberOfComponents() == 2);
const double *v2 = field->getArray()->getConstPointer();
CPPUNIT_ASSERT_DOUBLES_EQUAL(v2[0], 10 + v[0], 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(v2[1], 10 + v[1] * v[1], 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(v2[2], 10 + v[2], 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(v2[3], 10 + v[3] * v[3], 13);
We create a 2D vector field with 2 values (vectors) and then we transform this field into a 3D vector field by applying an expression to values of the 2D field using applyFunc3(). The expression func is applied to components of each vector of the field. We want the field to have 3 components computed as follows. (In func, we refer to the first component of a field value using the variable "a", and to the second component, using the variable "b", as we define it by varNamesVec).
- Component #0 = the second vector component hence "IVec * b" in func.
- Component #1 = the first vector component hence "JVec * a".
- Component #2 = a vector magnitude hence "KVec * sqrt( a*a + b*b )".
const double values[4] = {1., 1., 2., 1.};
array->useExternalArrayWithRWAccess(values, 2, 2);
field->applyFuncNamedCompo(3, varNamesVec, func);
Now we ascertain that the result field is as we expect. We check the second vector of the field.
double vec1[3];
field->getArray()->getTuple(1, vec1);
const double a = values[2], b = values[3];
CPPUNIT_ASSERT_DOUBLES_EQUAL(vec1[0], 10 + b, 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(vec1[1], 10 + a, 13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(vec1[2], 10 + sqrt(a * a + b * b), 13);
We create a 2D vector field with 2 values (vectors) and then we transform this field into a 3D vector field by applying an expression to values of the 2D field using applyFunc2(). Note that we set component info the array ("a" and "b" ) which will be used to refer to corresponding components within a function. The expression func is applied to components of each vector of the field. We want the field to have 3 components computed as follows. (In func, we refer to the first component of a field value using the variable "a", and to the second component, using the variable "b").
array->setInfoOnComponent(0, "a");
array->setInfoOnComponent(1, "b");
field->applyFuncCompo(3, func);
double vec1[3];
We create a 2D vector field with 2 values (vectors) and then we transform this field into a 3D vector field by applying an expression to values of the 2D field using applyFunc(). The expression func is applied to components of each vector of the field. We want the field to have 3 components computed as follows. (In func, we refer to the first component of a field value using the variable "a", and to the second component, using the variable "b").
field->applyFunc(3, func);
double vec1[3];
Filling a field with a value
We want to transform a 2D vector field to a 3D vector field so that all values to be equal to a certain value. First, we create the 2D mesh and the vector field on it.
Finally we use applyFunc() to change the number of components and all field values.
As a result, number of tuples in the field equals to the number of cells in the mesh, and number of components becomes equal to 3 as required.
Filling a field using an expression
Now we create a field on cells and use fillFromAnalytic2() to fill it with values computed using an expression func. This expression is applied to coordinates of each point (barycenter) for which the field value is computed. We want the field to have 3 components computed as follows. (In func, we refer to the first component of a point using the variable "a", and to the second component, using the variable "b").
field->setMesh(mesh);
field->fillFromAnalyticNamedCompo(3, varNamesVec, func);
double val1[3];
double bc1[2];
field->fillFromAnalytic(3, func);
double val1[3];
double bc1[2];
const double coords[3] = {0., 2., 4};
Now we create a field on cells and use fillFromAnalytic() to fill it with values computed using an expression func. This expression is applied to coordinates of each point (barycenter) for which the field value is computed. We want the field to have 3 components computed as follows. (In func, we refer to the first component of a point using the variable "a", and to the second component, using the variable "b").
Now we ascertain that the result field is as we expect. We check the second tuple of the field. We get barycenter of the cell #1 to check that values of the second tuple (#1) are computed as we want.
double val1[3];
double bc1[2];
Some operations that can be carried out on fields on cells
const double pos1[2] = {0.48, 0.38};
double res;
void fillFromAnalytic(int nbOfComp, FunctionToEvaluate func)
Definition: MEDCouplingFieldDouble.cxx:1201
void applyFunc(int nbOfComp, FunctionToEvaluate func)
Definition: MEDCouplingFieldDouble.cxx:1366
void getValueOn(const double *spaceLoc, double *res) const
Definition: MEDCouplingFieldDouble.cxx:1068
The decrementation of ref counter should be carried out in CPlusPlus only ...
f2->decrRef();
f4->decrRef();
Permuting a field on nodes
First, we create a supporting 2D mesh constituted by 4 cells. We create a 2x2 Cartesian mesh and then convert it to an unstructured one, since the Cartesian mesh is not suitable for renumberNodes() as its nature does not imply node renumbering.
MCAuto<MEDCouplingCMesh> cmesh = MEDCouplingCMesh::New();
cmesh->setCoords(coordsArr, coordsArr);
MCAuto<MEDCouplingUMesh> mesh = cmesh->buildUnstructured();
Then we create a field on nodes using fillFromAnalytic(), such that its values to coincide with coordinates of field location points that are nodes in our case (as our field is ON_NODES). At last we ascertain that field values are equal to node coordinates.
MCAuto<MEDCouplingFieldDouble> field = mesh->fillFromAnalytic(
MEDCoupling::ON_NODES, 2,
"IVec*x+JVec*y");
const DataArrayDouble *values = field->getArray();
const DataArrayDouble *nodeCoords = mesh->getCoords();
CPPUNIT_ASSERT(values->isEqualWithoutConsideringStr(*nodeCoords, 1e-13));
Now, we are going to reverse order of nodes using renumberNodes().
const mcIdType renumber[9] = {8, 7, 6, 5, 4, 3, 2, 1, 0};
field->renumberNodes(renumber, false);
const MEDCouplingMesh *mesh2 = field->getMesh();
nodeCoords = (static_cast<const MEDCouplingUMesh *>(mesh2))->getCoords();
As a result, the underlying mesh of field is changed and its nodes are also renumbered. And the field values are still equal to node coordinates of the renumbered mesh2.
Permuting a field on cells
First, we create a supporting 2D mesh constituted by 4 cells. We create a 2x2 Cartesian mesh and then convert it to an unstructured one, since the Cartesian mesh is not suitable for renumberCells() as its nature does not imply cell renumbering.
Then we create a field on cells using fillFromAnalytic(), such that its values to coincide with coordinates of field location points that are cell barycenters in our case (as our field is ON_CELLS). At last we ascertain that field values are equal to cell barycenters.
MEDCoupling::ON_CELLS, 2,
"IVec*x+JVec*y");
CPPUNIT_ASSERT(values->isEqualWithoutConsideringStr(*bc, 1e-13));
Now, we are going to reverse order of cells using renumberCells().
const mcIdType renumber[4] = {3, 2, 1, 0};
field->renumberCells(renumber, false);
bc = mesh2->computeCellCenterOfMass();
As a result, the underlying mesh of field is changed and its cells are also renumbered. And the field values are still equal to cell barycenters of the renumbered mesh2.
Filling a field using a C function
We want to create a 3D vector field lying on a 2D mesh using a C function as a value generator. For that, first, we define the function that computes 3 values basing on 2 coordinates of a 2D point.
bool
getNewValue(const double *pos, double *res)
res[0] = pos[0];
res[1] = pos[1];
res[2] = sqrt(pos[0] * pos[0] + pos[1] * pos[1]);
return true;
Then we create the 2D mesh and the field on it, and finally we use fillFromAnalytic() to fill the field with values each composed of 3 components.
field->fillFromAnalytic(3, &getNewValue);
CPPUNIT_ASSERT(field->getNumberOfTuples() == mesh->getNumberOfCells());
As a result, number of tuples in the field equals to the number of cells in the mesh, and number of components equals to 3 as required.
Changing a field by applying a C function
We want to transform a 2D vector field to a 3D vector field by applying a C function to each vector value. For that, first, we define the function that computes 3 values basing on 2 components of a 2D vector.
bool
res[0] = pos[0];
res[1] = pos[1];
return true;
Then we create the 2D mesh and the vector field on it.
field->setArray(bc);
Finally we use applyFunc() to change the field values.
field->applyFunc(3, &getNewValue);
Using interpolation tools - High level usage
const char sourceFileName[]="source.med"
const char targetFileName[]="target.med"
MEDCouplingUMesh *med_target_mesh=MEDLoader::
ReadUMeshFromFile(targetFileName,"Target_Mesh",0)
sourceField->setNature(ConservativeVolumic)
MEDCouplingRemapper remapper
remapper.setPrecision(1e-12)
remapper.prepare(sourceField->getMesh(),med_target_mesh,"P0P0")
MEDCouplingFieldDouble *targetField=remapper.transferField(sourceField,4.57)
targetField->decrRef()
sourceField->decrRef()
med_target_mesh->decrRef()
Definition: NormalizedUnstructuredMesh.hxx:27
@ Triangulation
Definition: InterpolationOptions.hxx:31
MEDCoupling::MEDCouplingField * ReadFieldCell(const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, int iteration, int order)
Definition: MEDLoader.cxx:1789
MEDCoupling::MEDCouplingUMesh * ReadUMeshFromFile(const std::string &fileName, const std::string &meshName, int meshDimRelToMax=0)
Definition: MEDLoader.cxx:1351
Using interpolation tools - Middle level usage
ReadUMeshFromFile("target.med","Target_mesh",0)
MEDCouplingNormalizedUnstructuredMesh<2,2> wrap_source_mesh(med_source_mesh)
MEDCouplingNormalizedUnstructuredMesh<2,2> wrap_target_mesh(med_target_mesh)
myInterpolator.setPrecision(1e-7)
std::vector<std::map<int,double> > resultMatrix
myInterpolator.interpolateMeshes(wrap_source_mesh,wrap_target_mesh,resultMatrix,"P0P0")
myInterpolator.interpolateMeshes(wrap_source_mesh,wrap_target_mesh,resultMatrix2,"P0P0")
@ Geometric2D
Definition: InterpolationOptions.hxx:33
@ ALL_C_MODE
Definition: NormalizedUnstructuredMesh.hxx:30
- Same with VTK data structure :
vtkXMLUnstructuredGridReader *readerSource=vtkXMLUnstructuredGridReader::New()
readerSource->SetFileName("source.vtu")
vtkUnstructuredGrid *vtk_source_mesh=readerSource->GetOutput()
readerSource->Update()
vtkXMLUnstructuredGridReader *readerTarget=vtkXMLUnstructuredGridReader::New()
readerTarget->SetFileName("target.vtu")
vtkUnstructuredGrid *vtk_target_mesh=readerTarget->GetOutput()
readerTarget->Update()
VTKNormalizedUnstructuredMesh<2> wrap_source_mesh(vtk_source_mesh)
VTKNormalizedUnstructuredMesh<2> wrap_target_mesh(vtk_target_mesh)
resultMatrix.multiply(...)
readerSource->Delete()
readerTarget->Delete()
Access
Getting a field value at some point at certain time
First, we create a supporting structured mesh. We create a 2x2 Cartesian mesh constituted by 4 cells.
Then we create a scalar field on cells, whose values vary linearly in time. We set all field values at a start time to be equal 10.0 using fillFromAnalytic(). And we set all field values at an end time to be equal 20.0 by doubling the start time array.
field->fillFromAnalytic(1, "10");
MCAuto<DataArrayDouble> array2 =
DataArrayDouble::Add(field->getArray(), field->getArray());
field->setEndArray(array2);
const double time1 = 1.1, time2 = 22.;
field->setStartTime(time1, 0, 0);
field->setEndTime(time2, 0, 0);
@ LINEAR_TIME
Definition: MEDCouplingRefCountObject.hxx:57
Now, we want to get a field value at a point [0,0] at a middle time between the start and end times. We expect the returned value to be equal to an average of 10. and 20.
const double pos[2] = {1., 1.};
double value[1];
field->getValueOn(pos, 0.5 * (time1 + time2), value);
CPPUNIT_ASSERT(fabs(value[0] - 0.5 * (10. + 20.)) < 1e-13);
Getting field values at some points
First, we create a supporting structured mesh. We create a 2x2 Cartesian mesh constituted by 4 cells. Then we create a scalar field on cells using fillFromAnalytic().
Now, we want to retrieve all field values using getValueOnMulti(). The field values relate to cells, hence we will use cell barycenters as a parameter of getValueOnMulti(). We expect that the double array returned getValueOnMulti() is equal to that stored by field.
MCAuto<DataArrayDouble> valArray = field->getValueOnMulti(bc->getConstPointer(), bc->getNumberOfTuples());
CPPUNIT_ASSERT(valArray->isEqual(*field->getArray(), 1e-13));
Getting a field value at a point
Now, we want to retrieve all field values using getValueOn(). The field values relate to cells, hence we will use cell barycenters to get a field value at each cell.
std::vector<double> vals(field->getNumberOfTuples());
double cellBC[2];
for (int i = 0; i < bc->getNumberOfTuples(); ++i)
bc->getTuple(i, cellBC);
field->getValueOn(cellBC, &vals[i]);
CPPUNIT_ASSERT(std::equal(vals.begin(), vals.end(), field->getArray()->getConstPointer()));
We collected all values returned by getValueOn() in an array, so that we can ascertain that the array of returned values is same as that stored by field.
Getting a value of field lying on a structured mesh
Now, we retrieve a field value relating to the cell #3 (this cell has a structured indexed (1,1)). For that we use getValueOnPos() where we pass the structured indexed of the cell: 1,1,-1 (the last index is meaningless as the mesh is 2D).
double val11[1];
field->getValueOnPos(1, 1, -1, val11);
CPPUNIT_ASSERT(val11[0] == bc->getIJ(3, 0) + bc->getIJ(3, 1));
After all we ascertain that the returned value corresponds to the expression used for the field creation. Namely that the value equals to the sum of components of barycenter of cell #3.
Meshes
Create
Standard build of an unstructured mesh from scratch
Firstly retrieve basic data in full interlace mode for coordinates, and nodal connectivity cell per cell.
double coords[27] = {-0.3, -0.3, 0., 0.2, -0.3, 0., 0.7, -0.3, 0., -0.3, 0.2, 0., 0.2, 0.2,
0., 0.7, 0.2, 0., -0.3, 0.7, 0., 0.2, 0.7, 0., 0.7, 0.7, 0.};
mcIdType nodalConnPerCell[18] = {0, 3, 4, 1, 1, 4, 2, 4, 5, 2, 6, 7, 4, 3, 7, 8, 5, 4};
Then create MEDCoupling::MEDCouplingUMesh instance giving its mesh dimension (2 here) and a name.
static MEDCouplingUMesh * New()
Definition: MEDCouplingUMesh.cxx:75
Gives an upper bound of the number of cells to be inserted into the unstructured mesh.
Then enter nodal connectivity of all cells, cell per cell using MEDCoupling::MEDCouplingUMesh::insertNextCell method.
When the nodal connectivity cell per cell has been finished, call MEDCoupling::MEDCouplingUMesh::finishInsertingCells method in order to restore mesh instance.
mesh->
insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, nodalConnPerCell + 4);
mesh->
insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, nodalConnPerCell + 7);
mesh->
insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, nodalConnPerCell + 10);
mesh->
insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, nodalConnPerCell + 14);
void finishInsertingCells()
Definition: MEDCouplingUMesh.cxx:466
void allocateCells(mcIdType nbOfCells=0)
Definition: MEDCouplingUMesh.cxx:385
void insertNextCell(INTERP_KERNEL::NormalizedCellType type, mcIdType size, const mcIdType *nodalConnOfCell)
Definition: MEDCouplingUMesh.cxx:419
At this level the connectivity part of the mesh mesh as been defined. Now let's set the coordinates using array coords defined above.
std::copy(coords, coords + 27, coordsArr->
getPointer());
void setCoords(const DataArrayDouble *coords)
Definition: MEDCouplingPointSet.cxx:96
At this level mesh is usable. When this mesh is no more needed simply call decrRef to decrement its reference counter.
Advanced build of an unstructured mesh from scratch
Firstly retrieve basic data in full interlace mode for coordinates, and nodal connectivity cell per cell, cell type included (3 for INTERP_KERNEL::NORM_TRI3 and 4 for INTERP_KERNEL::QUAD4).
mcIdType nodalConnPerCell[23] = {4, 0, 3, 4, 1, 3, 1, 4, 2, 3, 4, 5, 2, 4, 6, 7, 4, 3, 4, 7, 8, 5, 4};
mcIdType nodalConnPerCellIndex[6] = {0, 5, 9, 13, 18, 23};
Then enter nodal connectivity at once.
MEDCoupling::DataArrayIdType *nodalConn = MEDCoupling::DataArrayIdType::New();
nodalConn->alloc(23, 1);
std::copy(nodalConnPerCell, nodalConnPerCell + 23, nodalConn->getPointer());
MEDCoupling::DataArrayIdType *nodalConnI = MEDCoupling::DataArrayIdType::New();
nodalConnI->alloc(6, 1);
std::copy(nodalConnPerCellIndex, nodalConnPerCellIndex + 6, nodalConnI->getPointer());
nodalConn->decrRef();
nodalConnI->decrRef();
void setConnectivity(DataArrayIdType *conn, DataArrayIdType *connIndex, bool isComputingTypes=true)
Definition: MEDCouplingUMesh.cxx:4133
getPointer());
At this level mesh is usable. When this mesh is no more needed simply call decrRef() to decrement its reference counter.
Standard build of an cartesian mesh from scratch
We are going to build a 2D cartesian mesh, constituted from 9 nodes along X axis, and 7 nodes along Y axis.
Firstly retrieve for each direction the discretization and build a DataArrayDouble instance on the corresponding direction.
double XCoords[9] = {-0.3, 0., 0.1, 0.3, 0.45, 0.47, 0.49, 1., 1.22};
double YCoords[7] = {0., 0.1, 0.37, 0.45, 0.47, 0.49, 1.007};
std::copy(XCoords, XCoords + 9, arrX->
getPointer());
std::copy(YCoords, YCoords + 7, arrY->
getPointer());
void setInfoOnComponent(std::size_t i, const std::string &info)
Definition: MEDCouplingMemArray.cxx:664
Then create MEDCoupling::MEDCouplingCMesh instance giving the 2 instances of DataArrayDouble obtained above.
There are 2 techniques to get it.
Either :
Definition: MEDCouplingCMesh.hxx:32
void setCoords(const DataArrayDouble *coordsX, const DataArrayDouble *coordsY=0, const DataArrayDouble *coordsZ=0)
Definition: MEDCouplingCMesh.cxx:564
static MEDCouplingCMesh * New()
Definition: MEDCouplingCMesh.cxx:80
Or :
void setCoordsAt(int i, const DataArrayDouble *arr)
Definition: MEDCouplingCMesh.cxx:528
mesh is now available for use :
int getSpaceDimension() const
Definition: MEDCouplingCMesh.cxx:401
int getMeshDimension() const
Definition: MEDCouplingStructuredMesh.cxx:199
Definition: MEDCouplingStructuredMesh.cxx:1560
Definition: MEDCouplingStructuredMesh.cxx:1586
When this mesh is no more needed simply call decrRef to decrement its reference counter (nothing to be done in Python).
Getting a bounding mesh
First, we create a 2D mesh with 3 QUAD4 and 2 TRI3 cells.
MCAuto<MEDCouplingUMesh> mesh = MEDCouplingUMesh::New();
mesh->setMeshDimension(2);
mesh->allocateCells(5);
const mcIdType conn[18] = {0, 3, 4, 1, 1, 4, 2, 4, 5, 2, 6, 7, 4, 3, 7, 8, 5, 4};
mesh->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn);
mesh->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 4);
mesh->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 7);
mesh->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn + 10);
mesh->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn + 14);
mesh->finishInsertingCells();
coordsArr->alloc(9, 2);
const double coords[18] = {
-0.3, -0.3, 0.2, -0.3, 0.7, -0.3, -0.3, 0.2, 0.2, 0.2, 0.7, 0.2, -0.3, 0.7, 0.2, 0.7, 0.7, 0.7
std::copy(coords, coords + 18, coordsArr->getPointer());
mesh->setCoords(coordsArr);
Now we use buildBoundaryMesh() to get a mesh of lower dimension bounding mesh.
MCAuto<MEDCouplingPointSet> mesh1 = mesh->buildBoundaryMesh(true);
MCAuto<MEDCouplingPointSet> mesh2 = mesh->buildBoundaryMesh(false);
CPPUNIT_ASSERT(coordsArr->isEqual(*mesh1->getCoords(), 1e-13));
CPPUNIT_ASSERT(!coordsArr->isEqual(*mesh2->getCoords(), 1e-13));
Depending on the value of a parameter, buildBoundaryMesh() creates the mesh sharing the node coordinates array with mesh or not.
Retrieving a lower dimension mesh based on given nodes
In the following code we retrieve nodes of the cell #0 an then we call buildFacePartOfMySelfNode() twice with these nodes and with varying last parameter allNodes as input.
std::vector<mcIdType> nodes;
mesh->getNodeIdsOfCell(0, nodes);
const bool allNodes = true;
(MEDCouplingUMesh *)mesh->buildFacePartOfMySelfNode(&nodes[0], &nodes[0] + nodes.size(), allNodes);
CPPUNIT_ASSERT(mesh1->getNumberOfCells() == 4);
(MEDCouplingUMesh *)mesh->buildFacePartOfMySelfNode(&nodes[0], &nodes[0] + nodes.size(), !allNodes);
CPPUNIT_ASSERT(mesh2->getNumberOfCells() == 9);
If the last parameter is true buildFacePartOfMySelfNode() looks for segments whose all nodes are given to it, hence it finds segments bounding the cell #0 only.
If the last parameter is false buildFacePartOfMySelfNode() looks for any segment whose nodes are given to it, hence it adds more segments to mesh2.
Copying cells selected by nodes
In the following code we retrieve nodes of the cell #0 an then we call buildPartOfMySelfNode() twice with these nodes and with varying last parameter allNodes as input.
(MEDCouplingUMesh *)mesh->buildPartOfMySelfNode(&nodes[0], &nodes[0] + nodes.size(), allNodes);
(MEDCouplingUMesh *)mesh->buildPartOfMySelfNode(&nodes[0], &nodes[0] + nodes.size(), !allNodes);
CPPUNIT_ASSERT_EQUAL(mesh1->getNumberOfCells(), ToIdType(1));
CPPUNIT_ASSERT_EQUAL(mesh2->getNumberOfCells(), mesh->getNumberOfCells());
If the last parameter is true buildPartOfMySelfNode() looks for cells whose all nodes are given to it, hence it finds the cell #0 only.
If the last parameter is false buildPartOfMySelfNode() looks for any cell whose nodes are given to it, hence it finds all cells of mesh because all cells share the node #4.
Getting a part of mesh
Now we use buildPartOfMySelf() to get a mesh containing only two cells of mesh.
const mcIdType cellIds[2] = {1, 2};
MEDCouplingUMesh *mesh2 = (MEDCouplingUMesh *)mesh->buildPartOfMySelf(cellIds, cellIds + 2, true);
MEDCouplingUMesh *mesh3 = (MEDCouplingUMesh *)mesh->buildPartOfMySelf(cellIds, cellIds + 2, false);
CPPUNIT_ASSERT(coordsArr->isEqual(*mesh2->getCoords(), 1e-13));
CPPUNIT_ASSERT(!coordsArr->isEqual(*mesh3->getCoords(), 1e-13));
for (mcIdType i = 0; i < 2; ++i)
std::vector<mcIdType> nodes1, nodes2;
mesh->getNodeIdsOfCell(cellIds[i], nodes1);
mesh2->getNodeIdsOfCell(i, nodes2);
CPPUNIT_ASSERT(nodes1 == nodes2);
Modify
Fixing orientation of "extruded" volumes
First, we create a mesh with 2 incorrectly oriented "extruded" volumes.
const double coords[5 * 2] = {-0.3, -0.3, 0.2, -0.3, 0.7, -0.3, -0.3, 0.2, 0.2, 0.2};
coordsArr->useExternalArrayWithRWAccess(coords, 5, 2);
MCAuto<DataArrayDouble> coordsArr2 = coordsArr->deepCopy();
coordsArr = coordsArr->changeNbOfComponents(3, 0);
coordsArr2 = coordsArr2->changeNbOfComponents(3, 1);
coordsArr = DataArrayDouble::Aggregate(coordsArr, coordsArr2);
mesh->setMeshDimension(3);
mesh->allocateCells(2);
const mcIdType conn[8 + 6] = {0, 1, 4, 3, 5, 6, 9, 8, 1, 2, 4, 6, 7, 9};
mesh->insertNextCell(INTERP_KERNEL::NORM_HEXA8, 8, conn + 0);
mesh->insertNextCell(INTERP_KERNEL::NORM_PENTA6, 6, conn + 8);
Now we check that findAndCorrectBadOriented3DExtrudedCells() finds and fixes the reversed cells.
MCAuto<DataArrayIdType> fixedCells = mesh->findAndCorrectBadOriented3DExtrudedCells();
CPPUNIT_ASSERT(fixedCells->getNumberOfTuples() == 2);
CPPUNIT_ASSERT(fixedCells->getNumberOfTuples() == 0);
Fixing orientation of polyhedra
First, we create a mesh with 2 polyhedra, one of which is incorrectly oriented. We create two "extruded" polyhedra and then convert them to correctly defined polyhedra.
const mcIdType conn[8 + 6] = {0, 3, 4, 1, 5, 8, 9, 6, 1, 2, 4, 6, 7, 9};
mesh->insertNextCell(INTERP_KERNEL::NORM_POLYHED, 8, conn);
mesh->insertNextCell(INTERP_KERNEL::NORM_POLYHED, 6, conn + 8);
mesh->convertExtrudedPolyhedra();
Now we check that arePolyhedronsNotCorrectlyOriented() finds one reversed cell. After that we fix it using orientCorrectlyPolyhedrons() and re-check the orientation of polyhedra.
std::vector<mcIdType> badCellIds;
mesh->arePolyhedronsNotCorrectlyOriented(badCellIds);
CPPUNIT_ASSERT(badCellIds.size() == 1);
mesh->orientCorrectlyPolyhedrons();
badCellIds.clear();
CPPUNIT_ASSERT(badCellIds.size() == 0);
Fixing orientation of faces
First, we create a 2D mesh in 3D space with 3 QUAD4 and 2 TRI3 cells. Orientation of the cell #1 is reversed comparing with others.
const mcIdType conn[18] = {0, 3, 4, 1, 1, 2, 4, 4, 5, 2, 6, 7, 4, 3, 7, 8, 5, 4};
mesh->changeSpaceDimension(3);
Now we check that are2DCellsNotCorrectlyOriented() finds one reversed face. After that we fix the incorrectly oriented cell using orientCorrectly2DCells() and re-check the orientation of cells.
const double vec[3] = {0., 0., -1.};
mesh->are2DCellsNotCorrectlyOriented(vec, false, badCellIds);
mesh->orientCorrectly2DCells(vec, false);
badCellIds.clear();
Alternatively you can orient all 2D cells equally using the first cell as a reference:
mesh->orientCorrectly2DCells();
Also it is possible to orient some selected 2D cells by using another group of cells as the reference:
const mcIdType refCells[] = {0, 2};
const mcIdType objCells[] = {1, 3};
MCAuto<MEDCouplingUMesh> refGroup = mesh->buildPartOfMySelf(refCells, refCells + 2);
MCAuto<MEDCouplingUMesh> objGroup = mesh->buildPartOfMySelf(objCells, objCells + 2);
objGroup->orientCorrectly2DCells(refGroup);
mesh->setPartOfMySelf(objCells, objCells + 2, *objGroup);
Renumbering nodes in the connectivity array
First, we create a 2D mesh with 1 QUAD4 cell and with undefined coordinates of nodes.
mesh->allocateCells(1);
const mcIdType conn[4] = {4, 3, 2, 1};
Now we use renumberNodesInConn() to get the following nodal connectivity of a sole cell: 0,1,2,3.
const mcIdType old2newIds[] = {-1, 3, 2, 1, 0};
mesh->renumberNodesInConn(old2newIds);
const mcIdType nodes0Expected[] = {0, 1, 2, 3};
std::vector<mcIdType> nodes0;
mesh->getNodeIdsOfCell(0, nodes0);
CPPUNIT_ASSERT(std::equal(nodes0Expected, nodes0Expected + 4, &nodes0[0]));
old2newIds array defines how node ids are changed:
- new id of node #0 is -1,
- new id of node #1 is 3,
- new id of node #2 is 4,
- new id of node #3 is 1,
- new id of node #4 is 0.
Renumbering nodes
First, we create a 2D mesh with 4 nodes and no cells.
const double coords[4 * 2] = {-0.3, -0.3, 0.2, -0.3, 0.7, -0.3, -0.3, 0.3};
coordsArr->useExternalArrayWithRWAccess(coords, 4, 2);
mesh->allocateCells(0);
Next, we use renumberNodes() to permute nodes so that
- old node #0 becomes #2,
- old node #1 remains #1,
- old node #2 becomes #0,
- old node #3 is removed.
Number of nodes becomes 3.
const mcIdType newIds[] = {2, 1, 0, -1};
mesh->renumberNodes(newIds, 3);
coordsArr = mesh->getCoordinatesAndOwner();
const double coordsExpected[3 * 2] = {0.7, -0.3, 0.2, -0.3, -0.3, -0.3};
MCAuto<DataArrayDouble> coordsExpectedArr = DataArrayDouble::New();
coordsExpectedArr->useExternalArrayWithRWAccess(coordsExpected, 3, 2);
CPPUNIT_ASSERT(coordsExpectedArr->isEqual(*coordsArr, 1e-13));
Next we compare behavior of renumberNodes() and that of renumberNodes2() which, in contrast to renumberNodes(), moves merged nodes to their barycenter.
We set #2 as new id of old node #3 and expect that renumberNodes2() moves old nodes #0 and #3 to their barycenter (-0.3,0.0) which becomes position of node #2.
const mcIdType newIds2[] = {2, 1, 0, 2};
mesh->renumberNodesCenter(newIds2, 3);
const double coordsExpected2[3 * 2] = {0.7, -0.3, 0.2, -0.3, -0.3, 0.0};
MCAuto<DataArrayDouble> coordsExpectedArr2 = DataArrayDouble::New();
coordsExpectedArr2->useExternalArrayWithRWAccess(coordsExpected2, 3, 2);
CPPUNIT_ASSERT(coordsExpectedArr2->isEqual(*coordsArr, 1e-13));
Merging equal nodes
First, we create a 2D mesh with 1 QUAD4 and 2 TRI3 cells. The cells are based on 6 nodes of which 2 nodes fully coincide (#3 and #4) and 3 nodes are equal with precision 0.003.
const mcIdType conn[18] = {0, 3, 4, 1, 1, 4, 2, 4, 5, 2};
const double coords[6 * 2] = {
0.3,
-0.301,
0.2,
-0.3,
0.3,
-0.302,
1.1,
0.0,
1.1,
0.0,
0.3,
-0.303
coordsArr->alloc(6, 2);
std::copy(coords, coords + 6 * 2, coordsArr->getPointer());
Now we merge node duplicates using mergeNodes() and check values it returns.
bool areNodesMerged;
mcIdType newNbOfNodes;
MCAuto<DataArrayIdType> arr = mesh->mergeNodes(0.004, areNodesMerged, newNbOfNodes);
const mcIdType idsExpected[6] = {0, 1, 0, 2, 2, 0};
CPPUNIT_ASSERT(std::equal(idsExpected, idsExpected + 6, arr->getPointer()));
CPPUNIT_ASSERT(areNodesMerged);
CPPUNIT_ASSERT_EQUAL(ToIdType(3), newNbOfNodes);
Contents of arr shows ids of old nodes after the merging. The nodes considered equal one to the other have the same id in arr.
Next we compare behavior of mergeNodes() and that of mergeNodes2() which, in contrast to mergeNodes(), moves merged nodes to their barycenter.
We expect that mergeNodes2() moves old nodes #0, #2 and #5 to their barycenter equal to position of node #2.
First we check that mergeNodes() does not move nodes coincident with the node #2 to the position of node #2, and then we check that mergeNodes2() does move. (We check only the second (Y) component of node coordinates since the first component of these nodes is exactly same.)
const double *baryCoords2 = coords + 2 * 2;
CPPUNIT_ASSERT(
fabs(baryCoords2[1] - coordsArr->getIJ(0, 1)) > 1e-4
arr = mesh->mergeNodesCenter(0.004, areNodesMerged, newNbOfNodes);
baryCoords2[1], coordsArr->getIJ(0, 1), 13
Removing cell duplicates
First, we create a 2D mesh with 3 QUAD4 and 2 TRI3 cells, so that
- the cell #2 has the same nodal connectivity as the cell #1 does,
- the cell #3 has the same nodal connectivity as the cell #0 does,
- the cell #4 is based on the same nodes as the cell #0 but nodes order is different.
const mcIdType conn[11] = {0, 3, 4, 1, 1, 4, 2, 4, 1, 0, 3};
mesh->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn + 0);
mesh->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn + 7);
Now we use zipConnectivityTraducer() to remove duplicate cells. Then we check that two cells, having exactly same nodal connectivity with other cells, have been removed.
const mcIdType oldNbCells = mesh->getNumberOfCells();
DataArrayIdType *arr = mesh->zipConnectivityTraducer(0);
CPPUNIT_ASSERT_EQUAL(oldNbCells - 2, mesh->getNumberOfCells());
const mcIdType idsExpected[5] = {0, 1, 1, 0, 2};
CPPUNIT_ASSERT(std::equal(idsExpected, idsExpected + 5, arr->getPointer()));
Contents of arr shows ids of cells after duplicates removal. If a value (cell id) equals to its index in arr, this means that the cell is not a duplicate of any cell with lower id. Else, the value gives a cell id to which this cell is equal.
Thus, the cells #0 and #1 have no preceding equal cell since arr[i] == i.
The cell #2 equals to the cell #1 (== arr[2] ).
The cell #3 equals to the cell #0 (== arr[3] ).
The cell #4 has no equal cell. This is because the cell comparison technique specified when we called zipConnectivityTraducer() was 0 ("exact"), if we had used the technique 2 ("nodal"), arr[4] would be 0.
Removing unused nodes
Now we create mesh2 including all nodes but only two cells of mesh, and we use zipCoordsTraducer() to remove unused nodes from mesh2. zipCoordsTraducer() returns an array with -1 for unused nodes and new ids for used ones.
DataArrayIdType *arr = mesh2->zipCoordsTraducer();
CPPUNIT_ASSERT_EQUAL(ToIdType(4), mesh2->getNumberOfNodes());
CPPUNIT_ASSERT_EQUAL(mesh->getNumberOfNodes(), arr->getNumberOfTuples());
const mcIdType idsExpected[9] = {-1, 0, 1, -1, 2, 3, -1, -1, -1};
CPPUNIT_ASSERT(std::equal(idsExpected, idsExpected + 9, arr->getPointer()));
Retrieving unused nodes
Now we create mesh2 including all nodes but only two cells of mesh, and we use getNodeIdsInUse() to get nodes of mesh2 used in its two cells. getNodeIdsInUse() returns an array with -1 for unused nodes and new ids for used ones.
mcIdType newNbOfNodes = 0;
DataArrayIdType *arr = mesh2->getNodeIdsInUse(newNbOfNodes);
Now we use newNbOfNodes returned by getNodeIdsInUse() to convert arr to "New to Old" mode.
DataArrayIdType *arr2 = arr->invertArrayO2N2N2O(newNbOfNodes);
const mcIdType idsExpected2[4] = {1, 2, 4, 5};
CPPUNIT_ASSERT(std::equal(idsExpected2, idsExpected2 + 4, arr2->getPointer()));
Conversion of cells to "poly" types
Now we convert cells #1 and #3 to type POLYGON and check the result
const mcIdType cells[2] = {1, 3};
mesh->convertToPolyTypes(cells, cells + 2);
CPPUNIT_ASSERT(mesh->getTypeOfCell(0) == INTERP_KERNEL::NORM_QUAD4);
CPPUNIT_ASSERT(mesh->getTypeOfCell(1) == INTERP_KERNEL::NORM_POLYGON);
CPPUNIT_ASSERT(mesh->getTypeOfCell(2) == INTERP_KERNEL::NORM_TRI3);
CPPUNIT_ASSERT(mesh->getTypeOfCell(3) == INTERP_KERNEL::NORM_POLYGON);
Scaling the mesh
double coords[4 * 2] = {0.0, 0.0, 1.0, 0.0, 1.0, 1.0, 0.0, 1.0};
DataArrayDouble *initCoords = coordsArr->deepCopy();
Then we scale it by a factor of 2 with a center (0.,0.).
const double center[2] = {0., 0.};
const double factor = 2.;
mesh->scale(center, factor);
Finally we check that all node coordinates have changed by more than 0.9.
const DataArrayDouble *coordsArr2 = mesh->getCoords();
CPPUNIT_ASSERT(coordsArr2->isEqualWithoutConsideringStr(*initCoords, 1.0));
CPPUNIT_ASSERT(!coordsArr2->isEqualWithoutConsideringStr(*initCoords, 0.9));
initCoords->decrRef();
Translating the mesh
Then we translate it by a vector (1.,1.).
double vector[2] = {1., 1.};
mesh->translate(vector);
Rotating the mesh
double coords[4 * 2] = {0.0, 0.0, 0.1, 0.0, 0.1, 0.1, 0.0, 0.1};
double coordsOrig[4 * 2];
std::copy(coords, coords + sizeof(coords) / sizeof(double), coordsOrig);
Then we rotate it around a point (0.,0.) by 90 degrees clockwise.
double center[3] = {0., 0., 0.};
double vector[3] = {0., 0., 1.};
mesh->rotate(center, vector, -M_PI / 2);
Next, we make a 3D mesh from the 2D one and rotate it around the Z axis by 90 degrees counter-clockwise.
mesh->rotate(center, vector, +M_PI / 2);
Finally we transform the mesh back to 2D space and check that all nodes get back to the initial location.
mesh->changeSpaceDimension(2);
coordsArr->useExternalArrayWithRWAccess(coordsOrig, 4, 2);
CPPUNIT_ASSERT(coordsArr2->isEqualWithoutConsideringStr(*coordsArr, 1e-13));
Access
Getting node coordinates along an axis
We create an 1D Cartesian mesh and retrieves node coordinates using getCoordsAt().
const double coords[3] = {1., 2., 4.};
mesh->setCoordsAt(0, x);
const DataArrayDouble *x2 = mesh->getCoordsAt(0);
CPPUNIT_ASSERT(x2->isEqual(*x, 1e-13));
Getting coordinates of a node
The following code creates a 2D MEDCouplingUMesh with 3 nodes and no cells.
double coords[18] = {-0.3, -0.3, 0.2, -0.3, 0.7, -0.3};
coordsArr->useExternalArrayWithRWAccess(coords, 3, 2);
Here we get coordinates of the second node and check its two coordinates.
std::vector<double> coords2;
mesh->getCoordinatesOfNode(1, coords2);
CPPUNIT_ASSERT_DOUBLES_EQUAL(coords[2], coords2[0], 1e-13);
CPPUNIT_ASSERT_DOUBLES_EQUAL(coords[3], coords2[1], 1e-13);
Cells correspondence in two meshes
First, we create a 2D mesh1 with 3 QUAD4 and 2 TRI3 cells.
mesh1->setMeshDimension(2);
mesh1->allocateCells(5);
mesh1->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn);
mesh1->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 4);
mesh1->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 7);
mesh1->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn + 10);
mesh1->insertNextCell(INTERP_KERNEL::NORM_QUAD4, 4, conn + 14);
Then we create a mesh2 which includes cells #4, #2 and #0 of mesh1. The two meshes share the same node coordinates array.
const mcIdType cells2[3] = {4, 2, 0};
MCAuto<MEDCouplingUMesh> mesh2 = (MEDCouplingUMesh *)mesh1->buildPartOfMySelf(cells2, cells2 + 3, true);
- areCellsIncludedIn() detects that all cells of mesh2 are present in mesh1,
- the correspondence array corr2to1, which gives cell ids of mesh2 within mesh1, is equal to the array cells2 which selected cells from mesh1 for creation of mesh2.
int compType = 0;
DataArrayIdType *corr2to1, *corr1to2;
CPPUNIT_ASSERT(mesh1->areCellsIncludedIn(mesh2, compType, corr2to1));
CPPUNIT_ASSERT(std::equal(cells2, cells2 + 3, corr2to1->getConstPointer()));
Now we apply areCellsIncludedIn() in a reverse direction and ascertain that it returns false.
CPPUNIT_ASSERT(!mesh2->areCellsIncludedIn(mesh1, compType, corr1to2));
const mcIdType corr1to2Expected[5] = {2, 3, 1, 4, 0};
CPPUNIT_ASSERT(std::equal(corr1to2Expected, corr1to2Expected + 5, corr1to2->getConstPointer()));
The contents of the correspondence array corr1to2 [2, 3, 1, 4, 0] means the following.
- The cell #0 of mesh1 is equal to the cell #2 (== corr1to2[ 0 ]) of mesh2.
- The cell #1 of mesh1 is missing from mesh2 (as corr1to2[ 1 ] >= mesh2->getNumberOfCells()).
- The cell #2 of mesh1 is equal to the cell #1 (== corr1to2[ 2 ]) of mesh2.
- The cell #3 of mesh1 is missing from mesh2 (as corr1to2[ 3 ] >= mesh2->getNumberOfCells()).
- The cell #4 of mesh1 is equal to the cell #0 (== corr1to2[ 4 ]) of mesh2.
Deep comparison of meshes
First, we create two 2D meshes with two triangles, so that
- their nodes are almost same but permuted,
- the first triangle is based exactly on the same nodes (taking the permutation into account),
- an order of nodes in the second triangle is changed.
MEDCouplingUMesh *mesh1 = MEDCouplingUMesh::New();
0.0,
0.0,
1.0,
0.0,
1.0,
1.0,
0.0,
1.0
mesh1->allocateCells(2);
const mcIdType conn[6] = {0, 1, 2, 1, 2, 3};
mesh1->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 0);
mesh1->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 3);
MEDCouplingUMesh *mesh2 = MEDCouplingUMesh::New();
const double coords2[4 * 2] = {
0.0,
1.0,
0.0,
0.0,
1.0,
0.0,
1.0,
1.001
mesh2->setMeshDimension(2);
coordsArr->useExternalArrayWithRWAccess(coords2, 4, 2);
mesh2->setCoords(coordsArr);
mesh2->allocateCells(2);
const mcIdType conn[6] = {2, 3, 0, 3, 1, 2};
mesh2->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 0);
mesh2->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn + 3);
mesh2->finishInsertingCells();
Then we check that
- checkDeepEquivalWith() considers the meshes equal (i.e. it does not throw any exception) if it is called with a cell comparison policy cellCompPol == 1
- mapping from mesh1 to mesh2 for both nodes and cells is as expected.
int cellCompPol = 1;
DataArrayIdType *nOld2New, *cOld2New;
mesh1->checkDeepEquivalWith(mesh2, cellCompPol, 0.002, cOld2New, nOld2New);
const mcIdType nOld2NewExpected[4] = {3, 0, 1, 2};
const mcIdType cOld2NewExpected[2] = {1, 0};
CPPUNIT_ASSERT(std::equal(nOld2NewExpected, nOld2NewExpected + 4, nOld2New->getConstPointer()));
CPPUNIT_ASSERT(std::equal(cOld2NewExpected, cOld2NewExpected + 2, cOld2New->getConstPointer()));
Next we ascertain that checkDeepEquivalOnSameNodesWith() consider mesh1 and mesh2 different as they do not share the same nodal connectivity array.
After that we make the meshes share the node coordinates array and insert new triangles based on the same nodes but in different order. This is to ascertain that checkDeepEquivalOnSameNodesWith() called with the weakest cell comparison policy considers the meshes equal.
cOld2New->decrRef();
CPPUNIT_ASSERT_THROW(
mesh1->checkDeepEquivalOnSameNodesWith(mesh2, cellCompPol, 0.002, cOld2New), INTERP_KERNEL::Exception
mesh2->setCoords(mesh1->getCoords());
const mcIdType conn[6] = {1, 2, 3, 1, 0, 2};
cellCompPol = 2;
mesh1->checkDeepEquivalOnSameNodesWith(mesh2, cellCompPol, 0, cOld2New);
Getting barycenters of cells
Now we use getPartBarycenterAndOwner() to get barycenters of all but the first cell.
const mcIdType cellIds[4] = {1, 2, 3, 4};
MCAuto<DataArrayDouble> baryCenters = mesh->getPartBarycenterAndOwner(cellIds, cellIds + 4);
CPPUNIT_ASSERT(baryCenters->getNumberOfTuples() == 4);
CPPUNIT_ASSERT((int)baryCenters->getNumberOfComponents() == mesh->getSpaceDimension());
The returned array contains 4 tuples per 2 components.
Finding cells containing a point (multi-point case)
Then we use getCellsContainingPoints() to get cells in contact with tree points. Two of them are in contact with some cells and one is not.
const double pos[3 * 2] = {
10.,
10,
0.3,
0.3,
coords[2],
coords[3]
const double eps = 1e-4;
MCAuto<DataArrayIdType> cells, cellsIndex;
mesh->getCellsContainingPoints(pos, 3, eps, cells, cellsIndex);
const mcIdType cellsExpected[3] = {4, 0, 1};
const mcIdType cellsIndexExpected[4] = {0, 0, 1, 3};
CPPUNIT_ASSERT(std::equal(cellsExpected, cellsExpected + 3, cells->begin()));
CPPUNIT_ASSERT(std::equal(cellsIndexExpected, cellsIndexExpected + 4, cellsIndex->begin()));
The contents of the result arrays cells ([4, 0, 1]) and cellsIndex ([0, 0, 1, 3]) mean the following.
- Point #0 is in contact with none (== cellsIndx[1] - cellsIndx[0]) cell.
- Point #1 is in contact with 1 (== cellsIndx[2] - cellsIndx[1]) cell whose id is #4 (== cells[ cellsIndx[ 1 ]]).
- Point #2 is in contact with 2 (== cellsIndx[3] - cellsIndx[2]) cells whose ids are #0 (== cells[ cellsIndx[ 2 ]]) and #1 (== cells[ cellsIndx[ 2 ] + 1 ]).
Then we use getCellsContainingPoint() to get cells in contact with a small ball (point with precision) located near the node #4 and shifted from this node by its radius eps.
const double *coords4 = coords + 4 * 2;
const double pos[2] = {coords4[0] + eps, coords4[1] - eps};
std::vector<mcIdType> cellIds;
mesh->getCellsContainingPoint(pos, eps, cellIds);
CPPUNIT_ASSERT(ToIdType(cellIds.size()) == mesh->getNumberOfCells());
Since the node #4 is shared by all cells, size of the vector cellIds must be equal to the number of cells in mesh.
Getting normals of cells
First, we create a 2D mesh with 3 QUAD4 and 2 TRI3 cells. Orientation of the cell #1 is reversed.
Now we use buildPartOrthogonalField() to get normal vectors to the cells.
const mcIdType part[4] = {1, 2, 3, 4};
MCAuto<MEDCouplingFieldDouble> vecField = mesh->buildPartOrthogonalField(part, part + 4);
CPPUNIT_ASSERT(vecField->getArray()->getNumberOfTuples() == 4);
CPPUNIT_ASSERT(vecField->getArray()->getNumberOfComponents() == 3);
Getting volumes of cells
Now we use getPartMeasureField() to get volumes of all but the first cell. If we call getPartMeasureField() with isAbs == true, the area of the cell #1 is returned positive, else, negative that reflects its inverse orientation.
const bool isAbs = true;
MCAuto<DataArrayDouble> areaArr = mesh->getPartMeasureField(isAbs, part, part + 4);
CPPUNIT_ASSERT(areaArr->getIJ(0, 0) > 0);
areaArr = mesh->getPartMeasureField(!isAbs, part, part + 4);
CPPUNIT_ASSERT(areaArr->getIJ(0, 0) < 0);
CPPUNIT_ASSERT(areaArr->getNumberOfTuples() == 4);
Getting cells using the bounding box
First, we create a 2D mesh with 1 TRI3 cell. Bounding box of this cell is [0.,0., 1.,1].
const double coords[3 * 2] = {0., 0., 0., 1., 1., 1};
const mcIdType conn[3] = {0, 1, 2};
mesh->insertNextCell(INTERP_KERNEL::NORM_TRI3, 3, conn);
Now we check how getCellsInBoundingBox() searches for cells using the bounding box. We use a bounding box touching the bounding box of the sole cell at one point (1.,1.).
const double bbox[] = {1., 1., 1.001, 1.001};
MCAuto<DataArrayIdType> cellIdsArr = mesh->getCellsInBoundingBox(bbox, 0.0);
CPPUNIT_ASSERT(cellIdsArr->getNumberOfTuples() == 0);
cellIdsArr = mesh->getCellsInBoundingBox(bbox, 0.1);
CPPUNIT_ASSERT(cellIdsArr->getNumberOfTuples() == 1);
If getCellsInBoundingBox() is called with parameter eps == 0.0, the cell is not found because the two bounding boxes (one of the cell and the one passed as parameter) do not overlap.
If getCellsInBoundingBox() is called with parameter eps == 0.1, the cell is found because eps is used to increase the bounding box of the cell and thus the two bounding boxes intersect each other.
Getting boundary nodes
Now we use findBoundaryNodes() to get ids of boundary nodes.
MCAuto<DataArrayIdType> nodeIdsArr = mesh->findBoundaryNodes();
CPPUNIT_ASSERT(nodeIdsArr->getNumberOfTuples() == mesh->getNumberOfNodes() - 1);
findBoundaryNodes() returns all node ids except the node #4 which is in the middle of mesh.
Getting cells by nodes
In the following code we retrieve nodes of the cell #0 an then we call getCellIdsLyingOnNodes() twice with these nodes and with varying last parameter allNodes as input.
DataArrayIdType *cellIdsArr1 = mesh->getCellIdsLyingOnNodes(&nodes[0], &nodes[0] + nodes.size(), allNodes);
DataArrayIdType *cellIdsArr2 = mesh->getCellIdsLyingOnNodes(&nodes[0], &nodes[0] + nodes.size(), !allNodes);
CPPUNIT_ASSERT_EQUAL(cellIdsArr1->getNumberOfTuples(), ToIdType(1));
CPPUNIT_ASSERT_EQUAL(cellIdsArr2->getNumberOfTuples(), mesh->getNumberOfCells());
If the last parameter is true getCellIdsLyingOnNodes() looks for cells whose all nodes are given to it, hence it finds the cell #0 only.
If the last parameter is false getCellIdsLyingOnNodes() looks for any cell whose nodes are given to it, hence it finds all cells of mesh because all cells share the node #4.
In the following code we retrieve nodes of two cells an then we use getCellIdsFullyIncludedInNodeIds() to find these cells by their nodes.
mesh->getNodeIdsOfCell(cellIds[0], nodes);
mesh->getNodeIdsOfCell(cellIds[1], nodes);
DataArrayIdType *cellIdsArr = mesh->getCellIdsFullyIncludedInNodeIds(&nodes[0], &nodes[0] + nodes.size());
CPPUNIT_ASSERT(std::equal(cellIds, cellIds + 2, cellIdsArr->getPointer()));
Retrieving the descending connectivity with orientation
Now we get and check the descending connectivity.
DataArrayIdType *desc = DataArrayIdType::New();
DataArrayIdType *descIndx = DataArrayIdType::New();
DataArrayIdType *revDesc = DataArrayIdType::New();
DataArrayIdType *revDescIndx = DataArrayIdType::New();
MEDCouplingUMesh *mesh2 = mesh->buildDescendingConnectivity2(desc, descIndx, revDesc, revDescIndx);
const mcIdType descExpected[] = {1, 2, 3, 4, -3, 5, 6, 7, 8, -5, 9, 10, -2, 11, 12, 13, -7, -10};
const mcIdType descIndxExpected[] = {0, 4, 7, 10, 14, 18};
const mcIdType revDescExpected[] = {0, 0, 3, 0, 1, 0, 1, 2, 1, 2, 4, 2, 3, 3, 4, 3, 4, 4};
const mcIdType revDescIndxExpected[] = {0, 1, 3, 5, 6, 8, 9, 11, 12, 13, 15, 16, 17, 18};
CPPUNIT_ASSERT(std::equal(descExpected, descExpected + 18, desc->getPointer()));
CPPUNIT_ASSERT(std::equal(descIndxExpected, descIndxExpected + 6, descIndx->getPointer()));
CPPUNIT_ASSERT(std::equal(revDescExpected, revDescExpected + 18, revDesc->getPointer()));
CPPUNIT_ASSERT(std::equal(revDescIndxExpected, revDescIndxExpected + 14, revDescIndx->getPointer()));
Here we get connectivity of the cell #2 (#3 in FORTRAN mode) of mesh2 to see how mutual orientation of cells in mesh and mesh2 is defined.
const mcIdType cell2ConnExpect[] = {4, 1};
std::vector<mcIdType> cell2Conn;
mesh2->getNodeIdsOfCell(3 - 1, cell2Conn);
CPPUNIT_ASSERT(std::equal(cell2ConnExpect, cell2ConnExpect + 2, &cell2Conn[0]));
The contents of the result arrays desc and descIndx mean the following.
- The cell #0 of mesh (QUAD4) is bound by 4 (== descIndx[1] - descIndx[0]) segments (SEG2) of mesh2 whose ids in FORTRAN mode are
- #1 (== desc[ descIndx[ 0 ]]),
- #2 (== desc[ descIndx[ 0 ] + 1 ]),
- #3 (== desc[ descIndx[ 0 ] + 2 ]) and
- #4 (== desc[ descIndx[ 0 ] + 3 ]).
Ids are positive since order of nodes in the corresponding cells of mesh and mesh2 are same. For example nodes of SEG2 #3 are [4,1] and nodes of QUAD4 #0 are [0,3,4,1].
- The cell #1 of mesh (TRI3) is bound by 3 (== descIndx[2] - descIndx[1]) segments of mesh2 whose ids in FORTRAN mode are:
- #-3 (== desc[ descIndx[ 1 ]]),
- #5 (== desc[ descIndx[ 1 ] + 1 ]) and
- #6 (== desc[ descIndx[ 1 ] + 2 ]).
The id -3 means that order of nodes in SEG2 #3 ([4,1]) is different from the order of these nodes in TRI3 #1: [1,4,2].
- etc.
The contents of the result arrays revDesc and revDescIndx mean the following.
- The cell #0 of mesh2 (SEG2) bounds 1 (== revDescIndx[1] - revDescIndx[0]) cell of mesh whose id is:
- # 0 (== revDesc[ revDescIndx[ 0 ]]).
- The cell #1 of mesh2 bounds 2 (== revDescIndx[2] - revDescIndx[1]) cells of mesh whose ids are:
- # 0 (== revDesc[ revDescIndx[ 1 ]]) and
- # 1 (== revDesc[ revDescIndx[ 1 ] + 1 ]).
- etc.
MEDCouplingUMesh *mesh2 = mesh->buildDescendingConnectivity(desc, descIndx, revDesc, revDescIndx);
const mcIdType descExpected[] = {0, 1, 2, 3, 2, 4, 5, 6, 7, 4, 8, 9, 1, 10, 11, 12, 6, 9};
- The cell #0 of mesh (QUAD4) is bound by 4 (== descIndx[1] - descIndx[0]) segments (SEG2) of mesh2 whose ids are
- #0 (== desc[ descIndx[ 0 ]]),
- #1 (== desc[ descIndx[ 0 ] + 1 ]),
- #2 (== desc[ descIndx[ 0 ] + 2 ]) and
- #3 (== desc[ descIndx[ 0 ] + 3 ]).
- The cell #1 of mesh (TRI3) is bound by 3 (== descIndx[2] - descIndx[1]) segments of mesh2 whose ids are:
- #2 (== desc[ descIndx[ 1 ]]),
- #4 (== desc[ descIndx[ 1 ] + 1 ]) and
- #5 (== desc[ descIndx[ 1 ] + 2 ]).
- etc.
- etc.
Getting the reverse nodal connectivity
Now we get and check its reverse nodal connectivity.
DataArrayIdType *revNodal = DataArrayIdType::New();
DataArrayIdType *revNodalIndx = DataArrayIdType::New();
mesh->getReverseNodalConnectivity(revNodal, revNodalIndx);
const mcIdType revNodalExpected[18] = {0, 0, 1, 1, 2, 0, 3, 0, 1, 2, 3, 4, 2, 4, 3, 3, 4, 4};
const mcIdType revNodalIndexExpected[10] = {0, 1, 3, 5, 7, 12, 14, 15, 17, 18};
CPPUNIT_ASSERT(std::equal(revNodalExpected, revNodalExpected + 18, revNodal->getPointer()));
CPPUNIT_ASSERT(std::equal(revNodalIndexExpected, revNodalIndexExpected + 10, revNodalIndx->getPointer()));
The contents of the result arrays mean the following.
- Node #0 is shared by 1 (== revNodalIndx[1] - revNodalIndx[0]) cell whose id is #0 (== revNodal[ revNodalIndx[ 0 ]]).
- Node #1 is shared by 2 (== revNodalIndx[2] - revNodalIndx[1]) cells whose ids are #0 (== revNodal[ revNodalIndx[ 1 ]]) and #1 (== revNodal[ revNodalIndx[ 1 ] + 1 ]).
- etc.
Getting a minimum box bounding nodes
First, we create a 3D mesh with 2 nodes, so that the first one has minimal coordinates and the second one has maximal coordinates.
double cc[2 * 3] = {
0.0,
0.1,
0.2,
2.0,
2.1,
2.2
coordsArr->useExternalArrayWithRWAccess(cc, 2, 3);
Now we get a bounding box enclosing these nodes. This bounding box should contain coordinates of our two nodes (but in "no interlace" mode), as the nodes coincide with points returned by the bounding box.
double bbox[3][2];
mesh->getBoundingBox((double *)bbox);
for (mcIdType j = 0; j < 3; ++j)
CPPUNIT_ASSERT_DOUBLES_EQUAL(cc[i * 3 + j], bbox[j][i], 1e-13);
Getting nodes close to a point
The following code creates a 2D MEDCouplingUMesh with 5 nodes and no cells.
0.3,
-0.30001,
0.2,
-0.3,
0.3,
-0.30002,
1.1,
0.0,
0.3,
-0.30003
Now we define an array of coordinates of a point close to nodes #0, #2 and #4.
Thus we expect that getNodeIdsNearPoint() that we are going to use, if called with eps = 0.003, would return ids of nodes #0, #2 and #4.
double point[2] = {0.3, -0.3};
DataArrayIdType *ids = mesh->getNodeIdsNearPoint(point, 1e-2);
const mcIdType expectedIDs[3] = {0, 2, 4};
DataArrayIdType *okIDs = ids->findIdsEqualList(expectedIDs, expectedIDs + 3);
CPPUNIT_ASSERT_EQUAL(ToIdType(3), okIDs->getNumberOfTuples());
ids->decrRef();
okIDs->decrRef();
Getting nodes close to some points
The following code creates a 2D MEDCouplingUMesh with 7 nodes and no cells.
double coords[7 * 2] = {
0.3,
-0.301,
0.2,
-0.3,
0.3,
-0.302,
1.1,
0.0,
1.1,
0.0,
1.1,
0.002,
0.3,
-0.303
MCAuto<DataArrayDouble> coordsArr = DataArrayDouble::New();
coordsArr->useExternalArrayWithRWAccess(coords, 7, 2);
Now we define an array of coordinates of 3 points near which we want to find nodes of the mesh.
- Point #0 is at distance 0.001 from the node #1.
- Point #1 is rather far from all nodes.
- Point #2 is close to nodes #3, #4 and #5.
Thus we expect that getNodeIdsNearPoints() that we are going to use, if called with eps = 0.003, would return ids of close nodes #1, #3, #4 and #5.
const mcIdType nbOfPoints = 3;
double points[nbOfPoints * 2] = {
0.2,
-0.30001,
0.0,
0.0,
1.1,
0.002
DataArrayIdType *ids, *idsIndex;
mesh->getNodeIdsNearPoints(points, nbOfPoints, 1e-1, ids, idsIndex);
const mcIdType expectedIDs[4] = {1, 3, 4, 5};
DataArrayIdType *okIDs = ids->findIdsEqualList(expectedIDs, expectedIDs + 4);
CPPUNIT_ASSERT_EQUAL(ToIdType(4), okIDs->getNumberOfTuples());
ids->decrRef();
idsIndex->decrRef();
okIDs->decrRef();
idsIndex returns [0, 1, 1, 4] which means that:
- Point #0 is close to 1 (== idsIndex[1] - idsIndex[0]) node whose id is ids[ idsIndex[ 0 ]].
- Point #1 is close to 0 (== idsIndex[2] - idsIndex[1]) nodes.
- Point #2 is close to 3 (== idsIndex[3] - idsIndex[2]) nodes whose ids are ids[ idsIndex[ 2 ]], ids[ idsIndex[ 2 ] + 1 ] and ids[ idsIndex[ 2 ] + 2 ].
Finding coincident nodes
First, we create a mesh with 6 nodes, of which two nodes (#3 and #4) are fully coincident and 3 nodes (#0, #2 and #5) have distance less than 0.004 between them.
0.3,
-0.301,
0.2,
-0.3,
0.3,
-0.302,
1.1,
0.0,
1.1,
0.0,
0.3,
-0.303
coordsArr->useExternalArrayWithRWAccess(coords, 6, 2);
Then, we use findCommonNodes() to find coincident nodes, and check that (1) calling findCommonNodes() with prec == 1e-13 finds the two fully coincident nodes only and (2) findCommonNodes(0.004) finds 5 equal nodes.
DataArrayIdType *com, *comI;
mesh->findCommonNodes(1e-13, -1, com, comI);
CPPUNIT_ASSERT_EQUAL(ToIdType(2), com->getNumberOfTuples());
com->decrRef();
comI->decrRef();
mesh->findCommonNodes(0.004, -1, com, comI);
CPPUNIT_ASSERT_EQUAL(ToIdType(5), com->getNumberOfTuples());
Arrays
Create
Building an array from scratch in C++
In this example we will create arrays with 12 tuples constituted each of 3 components. These arrays will be created using different ways.
The following code is only based using DataArrayDouble but the use of DataArrayInt is strictly equivalent.
const mcIdType nbOfNodes = 12;
double coords[3 * nbOfNodes] = {2., 3., 4., 3., 4., 5., 4., 5., 6., 5., 6., 7.,
6., 7., 8., 7., 8., 9., 8., 9., 10., 9., 10., 11.,
10., 11., 12., 11., 12., 13., 12., 13., 14., 13., 14., 15.};
double *tmp = 0;
Building an array from scratch in C++, no copy no ownership
void useArray(const T *array, bool ownership, DeallocType type, std::size_t nbOfTuple, std::size_t nbOfCompo)
Definition: MEDCouplingMemArray.txx:840
Building an array from scratch in C++, no copy with C++ ownership
tmp = new double[3 * nbOfNodes];
std::copy(coords, coords + 3 * nbOfNodes, tmp);
Building an array from scratch in C++, no copy with C ownership
tmp = (double *)malloc(3 * nbOfNodes * sizeof(double));
Building an array from scratch in C++, with copy
coordsArr->
alloc(nbOfNodes, 3);
void declareAsNew() const
This method should be called when write access has been done on this.
Definition: MEDCouplingTimeLabel.cxx:43
Copy DataArrays
Deep copy
To perform a deep copy of a DataArray instance simply invoke :
DataArrayDouble * deepCopy() const
Definition: MEDCouplingMemArray.cxx:915
or :
Traits< T >::ArrayType * performCopyOrIncrRef(bool dCpy) const
Definition: MEDCouplingMemArray.txx:3852
coordsArrCpy is the deep copy of coordsArr so they are independent and their raw data has been deeply copied.
So it leads to the following behaviour :
CPPUNIT_ASSERT(coordsArrCpy->isEqual(*coordsArr, 1e-12));
coordsArrCpy->setIJ(0, 0, 1000.);
CPPUNIT_ASSERT(!coordsArrCpy->isEqual(*coordsArr, 1e-12));
As coordsArrCpy is a copy object it needs to be deallocated in C++ like coordsArr.
Shallow copy
To perform a shallow copy of a DataArray instance simply invoke :
coordsArrCpy is the shallow copy of coordsArr so they share the same raw data. In reality they are the same object. So it leads to the following behaviour to compare with the deep copy :
CPPUNIT_ASSERT(
So here the content of coordsArr and coordsArrCpy are linked, contrary to the deep copy case.
As coordsArrCpy is a copy object, in C++, it needs to be deallocated.
Assignation by deep copy of DataArray
We start by building a instance of MEDCoupling::DataArrayDouble allocated or not. Here, instance is not allocated, only built empty.
Then, coordsArrCpy is assigned with the content of coordsArr.
coordsArrCpy->deepCopyFrom(*coordsArr);
Then coordsArrCpy is a deep copy of coordsArr except that the instance of MEDCoupling::DataArrayDouble is those specified. But the behaviour is the same than those seen for deep copy.
coordsArrCpy->setIJ(0, 0, 2000.);
As always, in C++, coordsArrCpy is an object whose life cycle is fully independent from coordsArr so decrement is needed.
Building a permutation array
Here we create two arrays containing same values but in different order and then we use DataArrayInt::buildPermutationArr() to get an array showing in what places the values of b array are located in a array.
DataArrayInt *a = DataArrayInt::New();
const mcIdType vala[5] = {4, 5, 6, 7, 8};
a->alloc(5, 1);
std::copy(vala, vala + 5, a->getPointer());
DataArrayInt *b = DataArrayInt::New();
const mcIdType valb[5] = {5, 4, 8, 6, 7};
b->alloc(5, 1);
std::copy(valb, valb + 5, b->getPointer());
DataArrayIdType *c = a->buildPermutationArr(*b);
The result array c contains [1,0,4,2,3].
Modify
Inverting renumbering maps
invertArrayO2N2N2O()
In this example we create a DataArrayInt containing a renumbering map in "Old to New" mode, convert it into the renumbering map in "New to Old" mode and check the result.
const mcIdType arr1[6] = {2, 0, 4, 1, 5, 3};
DataArrayInt *da = DataArrayInt::New();
da->alloc(6, 1);
std::copy(arr1, arr1 + 6, da->getPointer());
DataArrayIdType *da2 = da->invertArrayO2N2N2O(6);
const mcIdType expected1[6] = {1, 3, 0, 5, 2, 4};
for (mcIdType i = 0; i < 6; i++) CPPUNIT_ASSERT_EQUAL(expected1[i], da2->getIJ(i, 0));
invertArrayN2O2O2N()
In this example we create a DataArrayInt containing a renumbering map in "New to Old" mode, convert it into the renumbering map in "Old to New" mode and check the result.
da->alloc(6, 1);
DataArrayIdType *da2 = da->invertArrayN2O2O2N(6);
Set part of values of DataArrayDouble
setSelectedComponents()
First, we create a 'source' array.
array1 = [1.0, 2.0, 3.0, 4.0, 5.0, 6.0]
da = DataArrayDouble(array1, 3, 2)
da.setInfoOnComponents(["a1", "a2"])
Now we create a larger zero array and assign the array da into it.
dv = DataArrayDouble()
dv.alloc(4, 4)
dv.fillWithZero()
dv.setInfoOnComponents(["v1", "v2", "v3", "v4"])
dv2 = dv.deepCopy()
dv.setSelectedComponents(da, [1, 0])
As result contents of the array dv are as follows.
Info of components : "a2" "a1" "v3" "v4"
Tuple #0 : 2 1 0 0
Tuple #1 : 4 3 0 0
Tuple #2 : 6 5 0 0
Tuple #3 : 0 0 0 0
The same result can be achieved other way (except that component info is not copied):
dv2[:3, [1, 0]] = da
self.assertTrue(dv.isEqualWithoutConsideringStr(dv2, 1e-20))
setPartOfValues1()
We create two arrays:
- a "large" (4x4) zero array da to assign to and
- a smaller (2x2) array dv filled with values [7.,8.,9.,10].
da = DataArrayDouble()
da.alloc(4, 4)
da.setInfoOnComponents(["v1", "v2", "v3", "v4"])
dv.alloc(4, 1)
dv.iota(7)
dv.rearrange(2)
dv.setInfoOnComponents(["a1", "a2"])
Now we copy dv to the middle of da.
da.fillWithZero()
da.setPartOfValues1(dv, 1, 3, 1, 1, 3, 1, True)
As result contents of the array da are as follows.
Info of components :"v1" "v2" "v3" "v4"
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 8 0
Tuple #2 : 0 9 10 0
Tuple #3 : 0 0 0 0
Here we re-fill da with zeros and copy dv into a component of da.
Note that the last parameter strictCompoCompare should be False in this case, else MEDCoupling::DataArrayDouble::setPartOfValues1() throws an exception because da has 2 components but only one target component is specified.
da.fillWithZero()
da.setPartOfValues1(dv, 0, 4, 1, 1, 2, 1, False)
Tuple #0 : 0 7 0 0
Tuple #1 : 0 8 0 0
Tuple #2 : 0 9 0 0
Tuple #3 : 0 10 0 0
Below more two variants of location of target values are shown.
da.fillWithZero()
da.setPartOfValues1(dv, 1, 2, 1, 0, 4, 1, False)
Tuple #0 : 0 0 0 0
Tuple #1 : 7 8 9 10
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
da.setPartOfValues1(dv, 0, 3, 2, 1, 4, 2, True)
Tuple #0 : 0 7 0 8
Tuple #1 : 0 0 0 0
Tuple #2 : 0 9 0 10
Tuple #3 : 0 0 0 0
The same result can be achieved other way:
da2 = da.deepCopy()
da2.fillWithZero()
da2[0:3:2, 1:4:2] = dv
self.assertTrue(da.isEqual(da2, 1e-20))
setPartOfValuesSimple1()
We create an array (4x4) da to assign to and define a value dv to assign.
da.alloc(4, 4)
dv = 7
Now we assign dv to the middle of da.
da.fillWithZero()
da.setPartOfValuesSimple1(dv, 1, 3, 1, 1, 3, 1)
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 7 0
Tuple #2 : 0 7 7 0
Tuple #3 : 0 0 0 0
Here we re-fill da with zeros and assign dv to a component of da.
da.fillWithZero()
da.setPartOfValuesSimple1(dv, 0, 4, 1, 1, 2, 1)
Tuple #0 : 0 7 0 0
Tuple #1 : 0 7 0 0
Tuple #2 : 0 7 0 0
Tuple #3 : 0 7 0 0
da.fillWithZero()
da.setPartOfValuesSimple1(dv, 1, 2, 1, 0, 4, 1)
Tuple #0 : 0 0 0 0
Tuple #1 : 7 7 7 7
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
da.setPartOfValuesSimple1(dv, 0, 3, 2, 1, 4, 2)
Tuple #0 : 0 7 0 7
Tuple #1 : 0 0 0 0
Tuple #2 : 0 7 0 7
Tuple #3 : 0 0 0 0
da2 = da.deepCopy()
da2.fillWithZero()
setPartOfValuesSimple2()
da.alloc(4, 4)
dv = 7
Now we assign dv to the middle of da. We explicitly specify tuples and component to assign to by a list [1,2].
da.fillWithZero()
da[[1, 2], [1, 2]] = dv
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 7 0
Tuple #2 : 0 7 7 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
da[[0, 1, 2, 3], [1]] = dv
Tuple #0 : 0 7 0 0
Tuple #1 : 0 7 0 0
Tuple #2 : 0 7 0 0
Tuple #3 : 0 7 0 0
da.fillWithZero()
da[[1], [0, 1, 2, 3]] = dv
Tuple #0 : 0 0 0 0
Tuple #1 : 7 7 7 7
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
da[[0, 2], [1, 3]] = dv
Tuple #0 : 0 7 0 7
Tuple #1 : 0 0 0 0
Tuple #2 : 0 7 0 7
Tuple #3 : 0 0 0 0
- Note
- MEDCoupling::DataArrayDouble::setPartOfValuesSimple2() can't be explicitly called in Python.
setPartOfValuesSimple3()
da.alloc(4, 4)
dv = 7
Now we assign dv to the middle of da. We explicitly specify tuples to assign to by a list [1,2]. And we specify components to assign to using slicing: 1:3.
da.fillWithZero()
da[[1, 2], 1:3] = dv
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 7 0
Tuple #2 : 0 7 7 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
da[[0, 1, 2, 3], 1:2] = dv
Tuple #0 : 0 7 0 0
Tuple #1 : 0 7 0 0
Tuple #2 : 0 7 0 0
Tuple #3 : 0 7 0 0
da.fillWithZero()
da[[1], 0:4] = dv
Tuple #0 : 0 0 0 0
Tuple #1 : 7 7 7 7
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
da[[0, 2], 1:4:2] = dv
Tuple #0 : 0 7 0 7
Tuple #1 : 0 0 0 0
Tuple #2 : 0 7 0 7
Tuple #3 : 0 0 0 0
- Note
- MEDCoupling::DataArrayDouble::setPartOfValuesSimple3() can't be explicitly called in Python.
setPartOfValues2()
- a "large" (4x7) zero array da to assign to,
- a smaller (3x2) array dv filled with values [7.,8.,9.,10.,11.,12.].
da.alloc(4, 7)
dv.alloc(6, 1)
dv.iota(7)
dv.rearrange(2)
Now we assign the two components of dv to the components of da with indices [1,3], and the 3 tuples of dv to the 3 tuples of da with indices [0,1,2]. This is the first mode of usage.
da.fillWithZero()
da[[0, 1, 2], [1, 3]] = dv
Tuple #0 : 0 7 0 8 0 0 0
Tuple #1 : 0 9 0 10 0 0 0
Tuple #2 : 0 11 0 12 0 0 0
Tuple #3 : 0 0 0 0 0 0 0
Every value of dv has been assigned to its own location within da.
Now we re-fill da with zeros and rearrange dv to have 6 components. And we assign dv to the tuples of da with indices [0,2,3] . This is the second mode of usage.
da.fillWithZero()
dv.rearrange(6)
da[[0, 2, 3], [0, 2, 3, 4, 5, 6]] = dv
The contents of dv have been assigned to each of specified tuples of da. Every value of dv is repeated in the 3 specified tuples within da.
Tuple #0 : 7 0 8 9 10 11 12
Tuple #1 : 0 0 0 0 0 0 0
Tuple #2 : 7 0 8 9 10 11 12
Tuple #3 : 7 0 8 9 10 11 12
- Note
- MEDCoupling::DataArrayDouble::setPartOfValues2() can't be explicitly called in Python.
setPartOfValues3()
da.alloc(4, 7)
dv.alloc(6, 1)
dv.iota(7)
dv.rearrange(2)
Now we assign the two components of dv to the components of da with indices [1,3], and the 3 tuples of dv to the 3 tuples of da with indices [0,1,2] which are specified using slicing: "0:3". This is the first mode of usage.
da.fillWithZero()
da[0:3, [1, 3]] = dv
Now we re-fill da with zeros and rearrange dv to have 6 components. And we assign dv to the tuples of da with indices [0,2] using slice notation "0:4:2". This is the second mode of usage.
da.fillWithZero()
dv.rearrange(6)
da[0:4:2, [0, 2, 3, 4, 5, 6]] = dv
- Note
- MEDCoupling::DataArrayDouble::setPartOfValues3() can't be explicitly called in Python.
Set part of values of DataArrayInt
da = DataArrayInt()
array1 = [1, 2, 3, 4, 5, 6]
da.setValues(array1, 3, 2)
Now we create a larger zero array and assign the array da to it.
dv = DataArrayInt()
dv.alloc(4, 4)
dv.fillWithZero()
dv2 = dv.deepCopy()
Tuple #0 : 2 1 0 0
Tuple #1 : 4 3 0 0
Tuple #2 : 6 5 0 0
Tuple #3 : 0 0 0 0
self.assertTrue(dv.isEqualWithoutConsideringStr(dv2))
setPartOfValues1()
- a "large" (4x4) zero array da to assign to, and
- a smaller (2x2) array dv filled with values [7,8,9,10].
da = DataArrayInt()
da.alloc(4, 4)
dv = DataArrayInt()
dv.alloc(4, 1)
dv.iota(7)
dv.rearrange(2)
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 8 0
Tuple #2 : 0 9 10 0
Tuple #3 : 0 0 0 0
Note that the last parameter strictCompoCompare should be False in this case, else MEDCoupling::DataArrayInt::setPartOfValues1() throws an exception because da has 2 components but only one target component is specified.
da.fillWithZero()
Tuple #0 : 0 7 0 0
Tuple #1 : 0 8 0 0
Tuple #2 : 0 9 0 0
Tuple #3 : 0 10 0 0
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 7 8 9 10
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 8
Tuple #1 : 0 0 0 0
Tuple #2 : 0 9 0 10
Tuple #3 : 0 0 0 0
da2 = da.deepCopy()
da2.fillWithZero()
self.assertTrue(da.isEqual(da2))
da = DataArrayInt()
da.alloc(4, 4)
dv = 7
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 7 0
Tuple #2 : 0 7 7 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 0
Tuple #1 : 0 7 0 0
Tuple #2 : 0 7 0 0
Tuple #3 : 0 7 0 0
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 7 7 7 7
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 7
Tuple #1 : 0 0 0 0
Tuple #2 : 0 7 0 7
Tuple #3 : 0 0 0 0
da2 = da.deepCopy()
da2.fillWithZero()
da = DataArrayInt()
da.alloc(4, 4)
dv = 7
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 7 0
Tuple #2 : 0 7 7 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 0
Tuple #1 : 0 7 0 0
Tuple #2 : 0 7 0 0
Tuple #3 : 0 7 0 0
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 7 7 7 7
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 7
Tuple #1 : 0 0 0 0
Tuple #2 : 0 7 0 7
Tuple #3 : 0 0 0 0
- Note
- MEDCoupling::DataArrayInt::setPartOfValuesSimple2() can't be explicitly called in Python.
da = DataArrayInt()
da.alloc(4, 4)
dv = 7
da.fillWithZero()
Tuple #0 : 0 0 0 0
Tuple #1 : 0 7 7 0
Tuple #2 : 0 7 7 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 0
Tuple #1 : 0 7 0 0
Tuple #2 : 0 7 0 0
Tuple #3 : 0 7 0 0
da.fillWithZero()
da[[1], 0:4] = dv
Tuple #0 : 0 0 0 0
Tuple #1 : 7 7 7 7
Tuple #2 : 0 0 0 0
Tuple #3 : 0 0 0 0
da.fillWithZero()
Tuple #0 : 0 7 0 7
Tuple #1 : 0 0 0 0
Tuple #2 : 0 7 0 7
Tuple #3 : 0 0 0 0
- Note
- MEDCoupling::DataArrayInt::setPartOfValuesSimple3() can't be explicitly called in Python.
setPartOfValues2()
- a smaller (3x2) array dv filled with values [7,8,9,10,11,12].
da = DataArrayInt()
da.alloc(4, 7)
dv = DataArrayInt()
dv.alloc(6, 1)
dv.iota(7)
dv.rearrange(2)
da.fillWithZero()
da.fillWithZero()
dv.rearrange(6)
- Note
- MEDCoupling::DataArrayInt::setPartOfValues2() can't be explicitly called in Python.
setPartOfValues3()
da = DataArrayInt()
da.alloc(4, 7)
dv = DataArrayInt()
dv.alloc(6, 1)
dv.iota(7)
dv.rearrange(2)
da.fillWithZero()
da.fillWithZero()
dv.rearrange(6)
- Note
- MEDCoupling::DataArrayInt::setPartOfValues3() can't be explicitly called in Python.
Excluding coincident tuples from DataArrayDouble
The code below creates an array of real values and than an array of unique values, not closer one to another than 0.2, is retrieved from it.
array1 = [2.3, 1.2, 1.3, 2.3, 2.301, 0.8]
da = DataArrayDouble(array1, 6, 1)
dv = da.getDifferentValues(2e-1)
expected2 = [2.301, 1.3, 0.8]
self.assertEqual(3, dv.getNbOfElems())
for i in range(3):
self.assertAlmostEqual(expected2[i], dv.getIJ(i, 0), 14)
pass
Concatenating DataArrayDouble's by appending components
In this example we create two data arrays including same number of tuples and then we concatenate them using meldWith().
const mcIdType sameNbTuples = 7;
DataArrayDouble *da1 = DataArrayDouble::New();
da1->alloc(sameNbTuples, 2);
da1->fillWithValue(7.);
da1->setInfoOnComponent(0, "c0da1");
da1->setInfoOnComponent(1, "c1da1");
DataArrayDouble *da2 = DataArrayDouble::New();
da2->alloc(sameNbTuples, 1);
da2->iota(0.);
da2->setInfoOnComponent(0, "c0da2");
da1->meldWith(da2);
Now the array da1 includes 7 tuples (as before) of 3 components each. Its components are: "c0da1","c1da1","c0da2".
Concatenating DataArrayInt's by appending components
DataArrayInt *da1 = DataArrayInt::New();
da1->fillWithValue(7);
DataArrayInt *da2 = DataArrayInt::New();
da2->iota(0);
da1->meldWith(da2);
Access
Getting a tuple of DataArrayInt
In this simple example we create an array of integers arranged into 3 tuples per 2 components, and finally print the second tuple.
dv = DataArrayInt()
dv.alloc(6, 1)
dv.iota(7)
dv.rearrange(2)
assert dv.getTuple(1) == [9, 10]
The output is
[9, 10]
Note that we can traverse all tuples in the array by simply iterating over it as the code below does.
for tpl in dv:
print(tpl)
Its output follows.
(7, 8)
(9, 10)
(11, 12)
Finding values in range in DataArrayDouble
In this example we create an array da containing same values as ones returned by range( 10 ). Then we get an array of indices of values of da being in range [ 2.5, 6 ].
DataArrayDouble *da = DataArrayDouble::New();
da->alloc(10, 1);
da->iota();
DataArrayIdType *da2 = da->findIdsInRange(2.5, 6);
As result contents of the array da2 are as follows.
Tuple #0 : 3
Tuple #1 : 4
Tuple #2 : 5
Tuple #3 : 6
Finding coincident tuples in DataArrayDouble
Let's create an array of 6 tuples and 2 components that can be considered as coordinates of 6 points in 2D space.
da->alloc(6, 2);
const double array2[12] = {
2.3,
2.3,
1.2,
1.2,
1.3,
1.3,
2.3,
2.3,
2.301,
2.301,
0.8,
0.8
std::copy(array2, array2 + 12, da->getPointer());
Now we find points that are not far each from other than 1e-1.
DataArrayIdType *c = 0, *cI = 0;
da->findCommonTuples(1.01e-1, -1, c, cI);
const mcIdType expected3[5] = {0, 3, 4, 1, 2};
const mcIdType expected4[3] = {0, 3, 5};
CPPUNIT_ASSERT(std::equal(expected3, expected3 + 5, c->getConstPointer()));
CPPUNIT_ASSERT(std::equal(expected4, expected4 + 3, cI->getConstPointer()));
c->decrRef();
cI->decrRef();
da->decrRef();
As we can realize from the above code, a hardcoded array expected3 is equal to the raw data of a DataArrayInt c and a hardcoded array expected4 is equal to the raw data of the DataArrayInt cI.
The array c contains indices of 5 coincident points. The array cI shows us boundaries of (cI->getNumberOfTuples()-1) = 2 groups of coincident points:
- The first group starts at index 0 and includes (3 - 0) = 3 points: 0,3,4.
- The second group starts at index 3 and includes (5 - 3) = 2 points: 1,2.
Creation of a sub-part of the DataArrayDouble by selecting components
arr1 = [
1.0,
2.0,
3.0,
4.0,
11.0,
12.0,
13.0,
14.0,
21.0,
22.0,
23.0,
24.0,
31.0,
32.0,
33.0,
34.0,
41.0,
42.0,
43.0,
44.0,
a1 = DataArrayDouble(arr1, 5, 4)
a1.setInfoOnComponent(0, "a")
a1.setInfoOnComponent(1, "b")
a1.setInfoOnComponent(2, "c")
a1.setInfoOnComponent(3, "d")
We created an array a1 containing 5 tuples of 4 components each (20 values). Now we are going to create an array a2 containing some components of a1.
arr2V = [1, 2, 1, 2, 0, 0]
a2 = a1.keepSelectedComponents(arr2V)
Now each tuple of a2 includes components named "b","c","b","c","a","a". Thus the result array a2 includes 30 elements (5 tuples per 6 components).
Creation of a sub-part of the DataArrayInt by selecting components
arr1 = [
1,
2,
3,
4,
11,
12,
13,
14,
21,
22,
23,
24,
31,
32,
33,
34,
41,
42,
43,
44,
a1 = DataArrayInt()
a1.setValues(arr1, 5, 4)
Note that DataArrayInt::keepSelectedComponents() is called, providing the same result, by the following python code:
Other
Input/Output
Writing fields in a VTK file
In this example we
- create an 2D mesh and 3 fields on it,
- use WriteVTK() to write all the fields and the mesh to a VTK file.
const double coords[3] = {0., 2., 4.};
coordsArr->useExternalArrayWithRWAccess(coords, 3, 1);
MCAuto<MEDCouplingCMesh> mesh1 = MEDCouplingCMesh::New();
mesh1->setCoords(coordsArr, coordsArr);
MCAuto<MEDCouplingFieldDouble> field1 = mesh1->getMeasureField(true);
MCAuto<MEDCouplingFieldDouble> field2 = mesh1->buildOrthogonalField();
MCAuto<MEDCouplingFieldDouble> field3 = mesh1->fillFromAnalytic(
ON_CELLS, 1,
"x");
field2->setName("Normal");
field3->setName("Barycenter");
const char fileName[] = "testExample_MEDCouplingFieldDouble_WriteVTK.vtk";
std::vector<const MEDCouplingFieldDouble *> fs(3);
fs[0] = field1;
fs[1] = field2;
fs[2] = field3;
MEDCouplingFieldDouble::WriteVTK(fileName, fs);
Loading a mesh using advanced API
const char fileName[]=...
const char meshName[]=...
MEDFileUMesh *medmesh=MEDFileUMesh::New(fileName,meshName)
std::vector<int> nel=medmesh->getNonEmptyLevels()
if(nel.size()<1)
throw INTERP_KERNEL::Exception("The test is not good for my file ! Expecting a multi level mesh to play with !")
MEDCouplingUMesh *m0=medmesh->getMeshAtLevel(nel[1],false)
MEDCouplingUMesh *g1=medmesh->getGroup(nel[1],"mesh2",false)
DataArrayInt *dag1=medmesh->getGroupArr(nel[1],"mesh2",false)
MEDCouplingUMesh *g1bis=m0->buildPartOfMySelf(dag1->getConstPointer(),dag1->getConstPointer()+dag1->getNbOfElems())
g1bis->setName(dag1->getName())
if(!g1->isEqual(g1bis,1e-12))
throw
INTERP_KERNEL::Exception("hmmmm :g1 and g1bis should be equal...")
dag1->decrRef()
g1->decrRef()
m0->decrRef()
medmesh->decrRef()
Writing a mesh using advanced API
MEDCouplingUMesh *m=...
MEDCouplingUMesh *m1=...
MEDCouplingUMesh *m2=...
MEDFileUMesh *mm=MEDFileUMesh::New()
mm->setName("mm")
mm->setDescription("Description mm")
mm->setCoords(m1->getCoords())
mm->setMeshAtLevel(-1,m1,false)
mm->setMeshAtLevel(0,m,false)
mm->setMeshAtLevel(-2,m2,false)
DataArrayInt *g1=DataArrayInt::New()
g1->alloc(2,1)
g1->setName("G1")
const int val1[2]={1,3}
std::copy(val1,val1+2,g1->getPointer())
DataArrayInt *g2=DataArrayInt::New()
g2->alloc(3,1)
g2->setName("G2")
const int val2[3]={1,2,3}
std::copy(val2,val2+3,g2->getPointer())
std::vector<const DataArrayInt *> grps(2)
grps[0]=g1 grps[1]=g2
mm->setGroupsAtLevel(0,grps,false)
g2->decrRef()
g1->decrRef()
mm->write(2)
