Using SALOME NoteBook
SALOME NoteBook allows defining variables to be used for creation and modification of objects.
Setting of variables in SALOME NoteBook
Use of variables to add a node in MESH module
The following limitations on the use of variables still exist:
Distribution of Layers hypothesis - parametrical values are correctly applied, but they are not restored after “Update study” operation.
Number of Segments hypothesis, Distribution with Table Density and Distribution with Analytic Density - parametrical values are not applicable.
Translation dialog box, default mode (translation by two points) - parametrical values are correctly applied, but they are not restored after “Update study” operation.
Merging nodes dialog box - parametrical value (tolerance of coincident nodes detection) is correctly applied, but it is not restored after “Update study” operation.
Revolution dialog box - it is impossible to use the angle of revolution as “total angle” if it is defined as variable.
Extrusion along a path dialog box - it is impossible to use “Linear variation of the angles” mode if at least one of those angles is defined as variable.
Pattern mapping dialog box - parametrical values (indices of nodes) are correctly applied, but they are not restored after “Update study” operation.
Clipping dialog box.
Properties dialog box.
Our TUI Scripts provide you with useful examples of Using SALOME NoteBook.
