Merging nodes
This functionality allows user to detect groups of coincident nodes with specified tolerance; each group of the coincident nodes can be then converted to the single node.
_images/mergenodes_ico.png
“Merge nodes” menu button
To merge nodes of your mesh:
  1. Choose Modification -> Transformation -> Merge nodes menu item. The following dialog box shall appear:
    _images/mergenodes_auto.png
    • Names contains names of the selected mesh objects whose nodes will be merged.
    • Automatic or Manual mode allows choosing how the nodes are processed. In Manual mode you can adjust groups of coincident nodes detected by the program and/or select any nodes to be merged.
    • Tolerance is a maximum distance between nodes sufficient for merging.
    • Activation of No merge of corner and medium nodes of quadratic cells check-box prevents merging medium nodes of quadratic elements with corner nodes. This check-box is enabled provided that the selected mesh includes quadratic elements.
    • Activation of Avoid making holes check-box prevents merging nodes that make elements invalid (but not degenerated) and hence removed. Thus, no holes in place of removed elements appear.
    • Exclude groups from detection group allows to ignore the nodes which belong to the specified mesh groups. This control is active provided that the mesh includes groups.
    • Nodes to keep during the merge group allows to specify nodes to keep in the mesh. (By default a node being the first in a group of coincident nodes is kept.) It is possible to either select nodes in the Viewer or select groups of any element type whose nodes will be kept.
      • Selection button activates selection of nodes to keep.
      • Nodes button activates selection of nodes in the Viewer.
      • Groups and sub-meshes button activates selection of groups and sub-meshes.
      • Add button adds selected nodes or groups to the list.
      • Nodes or groups selected in the list can be removed using Remove button.
  2. Automatic mode:
    • In the Automatic Mode all nodes within the indicated tolerance will be merged. The nodes which belong to the groups specified in Exclude groups from detection will NOT be taken into account.
  3. The Manual mode gives you full control of what the operation will do. In this mode additional controls are available:
    • Detect button generates the list of coincident nodes for the given Tolerance.
    • Coincident nodes is a list of groups of nodes for merging. Upon Apply all nodes of each group will be united into one node. The first node of a group is kept and the others are removed. By default the first node has a lowest ID within the group.
      • Remove button deletes the selected group from the list.
      • Add button adds to the list a group of nodes selected in the viewer.
      • Select all check-box selects all groups.
      • Show double nodes IDs check-box shows/hides identifiers of nodes of selected groups in the 3D viewer.
    _images/mergenodes.png
    • Edit selected group of coincident nodes list allows editing the selected group:
      • ad adds to the group the nodes selected in the viewer.
      • rm removes from the group the selected nodes.
      • mv moves the selected node to the first position in the group in order to keep it in the mesh.
  4. To confirm your choice click Apply or Apply and Close button.
_images/merging_nodes1.png
The initial object. Nodes 25, 26 and 5 are added to Nodes to keep during the merge group.
_images/merging_nodes2.png
The object has been merged
See Also a sample TUI Script of a Merging Nodes operation.
