Offset mesh
Offset 2D elements in mesh, submesh, group or elements from filter.
To offset all elements from mesh, sub-mesh or group:
In the Modification menu, select the Transformations then click Offset button
or click directly in the same button in the toolbar.The following dialog box will appear:
Check the option Select whole mesh, sub-mesh or group if it is not set.
Set the name of the mesh, sub-mesh or created group.
Set the Offset value (negative offsets are allowed).
Select Move Elements to offset the current mesh, Copy Elements to offset and duplicate them, or Create a new mesh to create a new mesh from the offset elements.
Click the Apply or Apply and Close button to confirm the operation.
To offset all elements ids from a filter:
or click directly in the same button from the toolbar.Uncheck the option Select whole mesh, sub-mesh or group.
Then click on Set_Filter button
The dialog for filter for faces will appear:
Define the desired criteria and then click the Apply and Close button to confirm the selection of elements.
Set Offset value and mesh creation options as done for the first case.
See also: A sample TUI Script of a Offset 2D mesh transformation.
