Boolean operations on groups
In MESH you can perform some Boolean operations on groups, which belong to one and the same mesh.
Union of groups
This operation allows to create a new group in such a way that all mesh elements that are present in the initial groups will be added to the new one.
To union groups:
In the Mesh menu select the Union Groups item. The following dialog box will appear:
In this dialog box you should specify the name of the resulting group and set of groups which will be united.
For example, we have two groups Group1 and Group2. The result of their Union will be Group12:
Group1
Group2
Group12
Click the Apply or Apply and Close button to confirm creation of the group.
See Also a sample TUI Script of a Union of groups operation.
Intersection of groups
This operation allows to create a new group in such a way that all mesh elements that are present in all initial groups together are added to the new one.
To intersect groups:
In the Mesh menu select the Intersect Groups item. The following dialog box will appear:
In this dialog box you should specify the name of the resulting group and set of groups which will be intersected.
For example, we have two groups Group1 and Group2. The result of their Intersection will be Group12a:
Group1
Group2
Group12a
See Also a sample TUI Script of an Intersection of groups operation.
Cut of groups
This operation allows to create a new group in such a way that all mesh elements that are present in the main groups but are absent in the tool groups are added to the new one.
To cut groups:
In the Mesh menu select the Cut Groups item. The following dialog box will appear:
In this dialog box you should specify the name of the resulting group and groups which will be cut.
For example, we have two groups Group1 and Group2. The result of their Cut will be Group12b:
Group1
Group2
Group12b
See Also a sample TUI Script of a Cut of groups operation.
