SALOMEGUI_Swig Class Reference
Python interface module for SALOME GUI. More...
#include <SALOMEGUI_Swig.hxx>
 SALOMEGUI_Swig ()
 ~SALOMEGUI_Swig ()
bool hasDesktop ()
 Check GUI availability. More...
void updateObjBrowser ()
 Update active study's Object Browser. More...
const char * getActiveStudyName ()
 Get active study name. More...
const char * getComponentName (const char *)
 Get name of the component by its title (user name) More...
const char * getComponentUserName (const char *)
 Get title (user name) of the component by its name. More...
int SelectedCount ()
 Get number of selected items. More...
const char * getSelected (int i)
 Get entry of the specified selected item. More...
void AddIObject (const char *)
 Add an object to the current selection. More...
void RemoveIObject (const char *)
 Remove the object from the selection. More...
void ClearIObjects ()
 Clear selection (unselect all objects). More...
void Display (const char *)
 Display an object in the current view window. More...
void DisplayOnly (const char *)
 Displays an object in the current view window and erases all other ones. More...
void Erase (const char *)
 Erase an object in the current view window. More...
void DisplayAll ()
 Display all active module's presentable child objects in the current view window. More...
void EraseAll ()
 Erase all objects from the current view window. More...
bool IsInCurrentView (const char *)
 Check it the object is displayed in the current view window. More...
void UpdateView ()
 Update (repaint) current view window. More...
void FitAll ()
 Fit current view window to display all its contents. More...
void FitSelection ()
void FitIObjects (const std::list< std::string > &)
void ResetView ()
 Reset current view window to the default state. More...
void ViewTop ()
 Switch current view window to show the top view. More...
void ViewBottom ()
 Switch current view window to show the bottom view. More...
void ViewLeft ()
 Switch current view window to show the left view. More...
void ViewRight ()
 Switch current view window to show the right view. More...
void ViewFront ()
 Switch current view window to show the front view. More...
void ViewBack ()
 Switch current view window to show the back view. More...
const char * getViewParameters ()
void setCameraPosition (double x, double y, double z)
 Set camera position of the active view . More...
void setCameraFocalPoint (double x, double y, double z)
 Set camera focal point of the active view. More...
void setCameraViewUp (double x, double y, double z)
 Set the view up direction for the camera. More...
void setViewScale (double parallelScale, double x, double y, double z)
 Set view scale. More...
This module provides an access to the SALOME GUI implementing set of functions which can be used from Python. This module is implemented using SWIG wrappings for some GUI functionality:
Instance of this class is created every time "import salome" line is typed
  • in IAPP embedded Python interpretor (SALOME_Session_Server executable)
  • in inline Python nodes in Supervisor (in SALOME_Container executable)
  • in stand-alone Python console outside any executable
SALOME GUI (desktop and other objects) is only available in SALOME_Session_Server. It means that it can not be accessed from the external Python console.
The usage in Python:
import libSALOME_Swig
sg = libSALOME_Swig.SALOMEGUI_Swig()
if sg.hasDesktop():
selcount = sg.SelectedCount()
if selcount > 0:
sg.Erase( sg.getSelected( 0 ) )
pass
◆ SALOMEGUI_Swig()
SALOMEGUI_Swig::SALOMEGUI_Swig ( )
◆ ~SALOMEGUI_Swig()
SALOMEGUI_Swig::~SALOMEGUI_Swig ( )
◆ AddIObject()
void SALOMEGUI_Swig::AddIObject ( const char *  theEntry)
theEntryobject entry
References getApplication(), ProcessVoidEvent(), and LightApp_SelectionMgr::setSelectedObjects().
◆ ClearIObjects()
void SALOMEGUI_Swig::ClearIObjects ( )
References SUIT_SelectionMgr::clearSelected(), getApplication(), and ProcessVoidEvent().
◆ Display()
void SALOMEGUI_Swig::Display ( const char *  theEntry)
The presentable object should be previously created and displayed in this viewer.
References LightApp_Study::children(), LightApp_Study::componentDataType(), LightApp_Displayer::Display(), LightApp_Displayer::FindDisplayer(), getActiveStudy(), getApplication(), LightApp_Study::isComponent(), ProcessVoidEvent(), and LightApp_Study::referencedToEntry().
◆ DisplayAll()
void SALOMEGUI_Swig::DisplayAll ( )
The presentable objects should be previously created and displayed in this viewer.
References LightApp_Study::centry(), LightApp_Study::children(), LightApp_Study::components(), LightApp_Displayer::Display(), LightApp_Displayer::FindDisplayer(), getActiveStudy(), getApplication(), ProcessVoidEvent(), and LightApp_Study::referencedToEntry().
◆ DisplayOnly()
void SALOMEGUI_Swig::DisplayOnly ( const char *  theEntry)
References LightApp_Study::children(), LightApp_Study::componentDataType(), LightApp_Study::components(), LightApp_Displayer::Display(), LightApp_Displayer::EraseAll(), LightApp_Displayer::FindDisplayer(), getActiveStudy(), getApplication(), LightApp_Study::isComponent(), ProcessVoidEvent(), and LightApp_Study::referencedToEntry().
◆ Erase()
void SALOMEGUI_Swig::Erase ( const char *  theEntry)
References LightApp_Study::children(), LightApp_Study::componentDataType(), LightApp_Displayer::Erase(), LightApp_Displayer::FindDisplayer(), getActiveStudy(), getApplication(), LightApp_Study::isComponent(), ProcessVoidEvent(), and LightApp_Study::referencedToEntry().
◆ EraseAll()
void SALOMEGUI_Swig::EraseAll ( )
◆ FitAll()
void SALOMEGUI_Swig::FitAll ( )
References SUIT_ViewManager::getActiveView(), getApplication(), and ProcessVoidEvent().
◆ FitIObjects()
void SALOMEGUI_Swig::FitIObjects ( const std::list< std::string > &  entries)
◆ FitSelection()
void SALOMEGUI_Swig::FitSelection ( )
◆ getActiveStudyName()
const char * SALOMEGUI_Swig::getActiveStudyName ( )
active study's name or null string if there is no active study
References ProcessEvent().
◆ getComponentName()
const char * SALOMEGUI_Swig::getComponentName ( const char *  componentUserName)
componentUserNamecomponent title (user name)
component name or null string if component title is invalid
◆ getComponentUserName()
const char * SALOMEGUI_Swig::getComponentUserName ( const char *  componentName)
componentNamecomponent name
component title or null string if component name is invalid
◆ getSelected()
const char * SALOMEGUI_Swig::getSelected ( int  index)
indexselected object index
selected object entry (null string if index is invalid)
◆ getViewParameters()
const char * SALOMEGUI_Swig::getViewParameters ( )
◆ hasDesktop()
bool SALOMEGUI_Swig::hasDesktop ( )
true if GUI is available
◆ IsInCurrentView()
bool SALOMEGUI_Swig::IsInCurrentView ( const char *  theEntry)
VSR: For the current moment implemented for OCC and VTK viewers only.
true if the object with given entry is displayed in the current viewer
◆ RemoveIObject()
void SALOMEGUI_Swig::RemoveIObject ( const char *  theEntry)
References getApplication(), ProcessVoidEvent(), LightApp_SelectionMgr::selectedObjects(), and LightApp_SelectionMgr::setSelectedObjects().
◆ ResetView()
void SALOMEGUI_Swig::ResetView ( )
◆ SelectedCount()
int SALOMEGUI_Swig::SelectedCount ( )
number of selected items in the active study
◆ setCameraFocalPoint()
void SALOMEGUI_Swig::setCameraFocalPoint ( double  x,
double  y,
double  z
x- X coordinate of the focal point
y- Y coordinate of the focal point
z- Z coordinate of the focal point
References __CameraFocalPoint, and setViewParameter().
◆ setCameraPosition()
void SALOMEGUI_Swig::setCameraPosition ( double  x,
double  y,
double  z
x- X coordinate of the camera
y- Y coordinate of the camera
z- Z coordinate of the camera
References __CameraPosition, and setViewParameter().
◆ setCameraViewUp()
void SALOMEGUI_Swig::setCameraViewUp ( double  x,
double  y,
double  z
x- X component of the direction vector
y- Y component of the direction vector
z- Z component of the direction vector
References __CameraViewUp, and setViewParameter().
◆ setViewScale()
void SALOMEGUI_Swig::setViewScale ( double  parallelScale,
double  x,
double  y,
double  z
Set view scale.
parallelScale- scaling used for a parallel projection.
x- X scale
y- Y scale
z- Z scale
References __ViewScale, and setViewParameter().
◆ updateObjBrowser()
void SALOMEGUI_Swig::updateObjBrowser ( )
References getApplication(), and ProcessVoidEvent().
◆ UpdateView()
◆ ViewBack()
void SALOMEGUI_Swig::ViewBack ( )
References __ViewBack, and setView().
◆ ViewBottom()
void SALOMEGUI_Swig::ViewBottom ( )
References __ViewBottom, and setView().
◆ ViewFront()
void SALOMEGUI_Swig::ViewFront ( )
References __ViewFront, and setView().
◆ ViewLeft()
void SALOMEGUI_Swig::ViewLeft ( )
References __ViewLeft, and setView().
◆ ViewRight()
void SALOMEGUI_Swig::ViewRight ( )
References __ViewRight, and setView().
◆ ViewTop()
void SALOMEGUI_Swig::ViewTop ( )
References __ViewTop, and setView().
