SOCC_ViewWindow Class Reference
#include <SOCC_ViewWindow.h>
Inheritance diagram for SOCC_ViewWindow:
 SOCC_ViewWindow (SUIT_Desktop *, OCCViewer_Viewer *)
virtual ~SOCC_ViewWindow ()
- Public Member Functions inherited from OCCViewer_ViewWindow
 OCCViewer_ViewWindow (SUIT_Desktop *theDesktop, OCCViewer_Viewer *theModel)
virtual ~OCCViewer_ViewWindow ()
virtual OCCViewer_ViewWindow * getView (const int) const
virtual OCCViewer_ViewPort3d * getViewPort ()
virtual bool eventFilter (QObject *watched, QEvent *e)
 Customize event handling. More...
virtual void performRestoring (const viewAspect &, bool=false)
 Restore view parameters. More...
virtual void initLayout ()
 Internal initialization. More...
virtual bool enableDrawMode (bool)
 Enable / disable draw rect (rubber band) mode. More...
virtual void updateEnabledDrawMode ()
 Update state of enable draw mode state. More...
virtual void setCuttingPlane (bool on, const double x=0, const double y=0, const double z=0, const double dx=0, const double dy=0, const double dz=1)
 Set parameters of the cutting plane. More...
virtual void setCuttingPlane (bool on, const gp_Pln thePln)
virtual bool isCuttingPlane ()
 Check if any cutting plane is enabled. More...
virtual QString getVisualParameters ()
 Get visual parameters of this view window. More...
virtual void setVisualParameters (const QString &parameters)
 Restore visual parameters of the view window. More...
virtual void initSketchers ()
virtual OCCViewer_ViewSketcher * getSketcher (const int) const
virtual void activateSketching (int)
virtual int interactionStyle () const
 Get current interaction style. More...
virtual void setInteractionStyle (const int)
 Set current interaction style. More...
virtual int zoomingStyle () const
 Get current zooming style. More...
virtual void setZoomingStyle (const int)
 Set current zooming style. More...
virtual bool isPreselectionEnabled () const
 Indicates whether preselection is enabled. More...
virtual void enablePreselection (bool)
 Enables/disables preselection. More...
virtual bool isSelectionEnabled () const
 Indicates whether selection is enabled. More...
virtual void enableSelection (bool)
 Enables/disables selection. More...
virtual int projectionType () const
virtual void setProjectionType (int)
virtual SelectionStyle selectionStyle () const
virtual void setSelectionStyle (SelectionStyle)
virtual int stereoType () const
virtual void setStereoType (const int)
virtual int anaglyphFilter () const
virtual void setAnaglyphFilter (const int)
virtual void setStereographicFocus (const int, const double)
virtual int stereographicFocusType () const
virtual double stereographicFocusValue () const
virtual void setInterocularDistance (const int, const double)
virtual int interocularDistanceType () const
virtual double interocularDistanceValue () const
virtual bool isReverseStereo () const
virtual void setReverseStereo (const bool)
virtual bool isVSync () const
virtual void setVSync (const bool)
virtual bool isQuadBufferSupport () const
virtual void setQuadBufferSupport (const bool)
virtual bool isAutomaticZoom () const
virtual void setAutomaticZoom (const bool)
virtual void enableAutoRotation (const bool)
void setTransformEnabled (const OperationType, const bool)
bool transformEnabled (const OperationType) const
void set2dMode (Mode2dType)
Mode2dType get2dMode () const
void setMaximized (bool, bool=true)
bool isMaximized () const
void setReturnedTo3dView (bool=true)
void setSketcherStyle (bool enable)
bool isSketcherStyle () const
virtual QColor backgroundColor () const
virtual void setBackgroundColor (const QColor &)
virtual void showStaticTrihedron (bool)
virtual Qtx::BackgroundData background () const
virtual void setBackground (const Qtx::BackgroundData &)
virtual const viewAspectList & getViewAspects ()
virtual void appendViewAspect (const viewAspect &)
virtual void updateViewAspects (const viewAspectList &)
virtual void clearViewAspects ()
virtual SUIT_CameraProperties cameraProperties ()
bool isActionVisible (ActionId theId) const
void setActionVisible (ActionId theId, bool isVisible)
void resetState ()
 Reset the viewport to its initial state ( no transformations in process etc. ) More...
virtual QImage dumpView ()
 Dump view window contents to the pixmap. More...
virtual bool dumpViewToFormat (const QImage &, const QString &fileName, const QString &format)
- Public Member Functions inherited from SUIT_ViewWindow
 SUIT_ViewWindow (SUIT_Desktop *)
virtual ~SUIT_ViewWindow ()
virtual void setViewManager (SUIT_ViewManager *)
SUIT_ViewManager * getViewManager () const
bool event (QEvent *)
bool dumpViewToFormat (const QString &fileName, const QString &format)
bool onAccelAction (int)
bool closable () const
bool setClosable (const bool)
void setDestructiveClose (const bool)
int getId () const
QtxActionToolMgr * toolMgr () const
virtual void setDropDownButtons (bool)
 Set buttons mode to drop-down (on = true) or ligned (on = false) More...
bool dropDownButtons () const
 Get current buttons mode. More...
virtual bool isAutoRotationEnabled () const
virtual bool action (const int)
- Protected Member Functions inherited from OCCViewer_ViewWindow
virtual QString filter () const
bool isOpenGlStereoSupport () const
bool transformRequested () const
bool setTransformRequested (OperationType)
 Start delayed viewer operation. More...
bool transformInProcess () const
void setTransformInProcess (bool)
void vpMousePressEvent (QMouseEvent *theEvent)
 Handle mouse press event. More...
void vpMouseReleaseEvent (QMouseEvent *theEvent)
 Handle mouse release event. More...
void vpMouseMoveEvent (QMouseEvent *theEvent)
 Handle mouse move event. More...
void drawRect ()
 Draw rubber band rectangle. More...
void endDrawRect ()
 Clear rubber band rectangle on the end on the dragging operation. More...
void createActions ()
 Create actions. More...
void createToolBar ()
 Create toolbar. More...
virtual OperationType getButtonState (QMouseEvent *theEvent, int theInteractionStyle)
 Detect viewer operation according the the mouse button pressed and key modifiers used. More...
viewAspect getViewParams () const
 Get the visual parameters of the view window. More...
bool computeGravityCenter (double &theX, double &theY, double &theZ)
 Compute the gravity center. More...
void projAndPanToGravity (V3d_TypeOfOrientation CamOri)
virtual void onSketchingStarted ()
virtual void onSketchingFinished ()
virtual OCCViewer_ViewSketcher * createSketcher (int)
void saveCursor ()
- Protected Member Functions inherited from SUIT_ViewWindow
virtual void contextMenuEvent (QContextMenuEvent *)
virtual QAction * synchronizeAction ()
- Public Types inherited from OCCViewer_ViewWindow
enum  ActionId {
  DumpId , FitAllId , FitRectId , FitSelectionId ,
  ZoomId , PanId , GlobalPanId , ChangeRotationPointId ,
  RotationId , FrontId , BackId , TopId ,
  BottomId , LeftId , RightId , ClockWiseId ,
  AntiClockWiseId , ResetId , CloneId , ClippingId ,
  MemId , RestoreId , TrihedronShowId , AxialScaleId ,
  GraduatedAxesId , AmbientId , SwitchInteractionStyleId , SwitchZoomingStyleId ,
  SwitchPreselectionId , SwitchSelectionId , MaximizedId , SynchronizeId ,
  ReturnTo3dViewId , OrthographicId , PerspectiveId , StereoId ,
  RayTracingId , EnvTextureId , LightSourceId , RectangleSelectionStyleId ,
  PolygonSelectionStyleId , CircleSelectionStyleId , ViewCubeShowId , UserId
enum  OperationType {
  NOVIEWOP , PANVIEW , ZOOMVIEW , ROTATE ,
  PANGLOBAL , WINDOWFIT , FITALLVIEW , FITSELECTION ,
  RESETVIEW , FRONTVIEW , BACKVIEW , TOPVIEW ,
  BOTTOMVIEW , LEFTVIEW , RIGHTVIEW , CLOCKWISEVIEW ,
  ANTICLOCKWISEVIEW , PROJECTION
enum  RotationPointType { BBCENTER , SELECTED }
enum  SketchingType { NoSketching , Rect , Polygon }
enum  SelectionStyle { RectStyle , PolygonStyle , CyrcleStyle }
enum  Mode2dType { No2dMode , XYPlane , XZPlane , YZPlane }
enum  ProjectionType { Orthographic , Perspective , Stereo }
enum  StereoType {
  QuadBuffer , Anaglyph , RowInterlaced , ColumnInterlaced ,
  ChessBoard , SideBySide , OverUnder , SoftPageFlip ,
  NumberOfModes
enum  AnaglyphFilter { RedCyan , YellowBlue , GreenMagenta }
enum  FocusIODType { Absolute , Relative }
- Public Slots inherited from OCCViewer_ViewWindow
virtual void onFrontView ()
 Perform "front view" transformation. More...
virtual void onViewFitAll ()
 Perform 'fit all' operation. More...
virtual void onBackView ()
 Perform "back view" transformation. More...
virtual void onClipping (bool on)
 called if clipping operation is activated / deactivated. More...
virtual void onTopView ()
 Perform "top view" transformation. More...
virtual void onBottomView ()
 Perform "bottom view" transformation. More...
virtual void onLeftView ()
 Perform "left view" transformation. More...
virtual void onRightView ()
 Perform "right view" transformation. More...
virtual void onClockWiseView ()
 Rotate view 90 degrees clockwise. More...
virtual void onAntiClockWiseView ()
 Rotate view 90 degrees conterclockwise. More...
virtual void onProjectionType (QAction *theAction)
 Set the given projection mode. More...
virtual void onStereoType (bool activate)
 Sets Stereo projection mode. More...
virtual void onProjectionType ()
 Restore the view. More...
virtual void onResetView ()
 Perform "reset view" transformation. More...
virtual void onFitAll ()
 Perform "fit all" transformation. More...
virtual void onFitSelection ()
 Perform "fit selection" transformation. More...
virtual void activateZoom ()
 Start zooming operation. More...
virtual void activateWindowFit ()
 Starts fit operation. More...
virtual void activateRotation ()
 Start rotation operation. More...
virtual void activatePanning ()
 Start panning operation. More...
virtual void activateGlobalPanning ()
 Start global panning operation. More...
virtual void onSetRotationPoint (bool on)
 Called if 'change rotation point' operation is activated. More...
virtual void onCloneView ()
 Create one more window with same content. More...
virtual void onAxialScale ()
virtual void onGraduatedAxes ()
virtual void onAmbientToogle ()
virtual void onMemorizeView ()
 Store view parameters. More...
virtual void onRestoreView ()
virtual void onTrihedronShow (bool)
 Called when action "show/hide trihedron" is activated. More...
virtual void onViewCubeShow (bool)
 Called when action "show/hide view cube" is activated. More...
virtual void setRestoreFlag ()
 Set restore flag. More...
virtual void onSwitchInteractionStyle (bool on)
 Switches "keyboard free" interaction style on/off. More...
virtual void onSwitchZoomingStyle (bool on)
 Toogles advanced zooming style (relatively to the cursor position) on/off. More...
virtual void onSwitchPreselection (bool on)
 Toggles preselection (highlighting) on/off. More...
virtual void onSwitchSelection (bool on)
 Toggles selection on/off. More...
virtual void onSwitchSelectionStyle (QAction *theAction)
 Switches style of advanced multiple selection by Poligon/Circle. More...
virtual void onRayTracing ()
virtual void onEnvTexture ()
virtual void onLightSource ()
virtual void onPanning ()
virtual void activateSetRotationGravity ()
 Set the gravity center as a rotation point. More...
virtual void activateSetRotationSelected (double theX, double theY, double theZ)
 Set the point selected by the user as a rotation point. More...
virtual void activateStartPointSelection (TopAbs_ShapeEnum)
 Start the shape selection process. More...
virtual void updateGravityCoords ()
 Update gravity center in the "Set Rotation Point" dialog box. More...
virtual void showEvent (QShowEvent *)
 Handle show event. More...
virtual void hideEvent (QHideEvent *)
 Handle hide event. More...
virtual void onMaximizedView ()
virtual void returnTo3dView ()
- Public Slots inherited from SUIT_ViewWindow
virtual void onDumpView ()
void setVisible (bool)
- Signals inherited from OCCViewer_ViewWindow
void vpTransformationStarted (OCCViewer_ViewWindow::OperationType type)
void vpTransformationFinished (OCCViewer_ViewWindow::OperationType type)
void viewCloned (SUIT_ViewWindow *)
void Show (QShowEvent *)
void Hide (QHideEvent *)
void maximized (OCCViewer_ViewWindow *, bool)
void returnedTo3d ()
- Signals inherited from SUIT_ViewWindow
void tryClosing (SUIT_ViewWindow *)
void closing (SUIT_ViewWindow *)
void mousePressed (SUIT_ViewWindow *, QMouseEvent *)
void mouseReleased (SUIT_ViewWindow *, QMouseEvent *)
void mouseDoubleClicked (SUIT_ViewWindow *, QMouseEvent *)
void mouseMoving (SUIT_ViewWindow *, QMouseEvent *)
void wheeling (SUIT_ViewWindow *, QWheelEvent *)
void keyPressed (SUIT_ViewWindow *, QKeyEvent *)
void keyReleased (SUIT_ViewWindow *, QKeyEvent *)
void contextMenuRequested (QContextMenuEvent *e)
void viewModified (SUIT_ViewWindow *)
void vpStartRotate (int, int, qint64)
void vpRotate (int, int, qint64)
void vpEndRotate (int, int, qint64)
- Protected Slots inherited from OCCViewer_ViewWindow
void synchronize (SUIT_ViewWindow *)
- Protected Slots inherited from SUIT_ViewWindow
void updateSyncViews ()
void onSynchronizeView (bool)
virtual void synchronize (SUIT_ViewWindow *)
void emitViewModified ()
- Static Protected Member Functions inherited from SUIT_ViewWindow
static void synchronizeView (SUIT_ViewWindow *viewWindow, int id)
- Protected Attributes inherited from OCCViewer_ViewWindow
OCCViewer_ViewSketcher * mypSketcher
QList< OCCViewer_ViewSketcher * > mySketchers
int myCurSketch
OperationType myOperation
OCCViewer_Viewer * myModel
OCCViewer_ViewPort3d * myViewPort
OCCViewer_CubeAxesDlg * myCubeAxesDlg
RotationPointType myCurrPointType
RotationPointType myPrevPointType
gp_Pnt mySelectedPoint
bool myRotationPointSelection
int myRestoreFlag
int myStartX
int myStartY
qint64 myStartTime
int myCurrX
int myCurrY
qint64 myCurrTime
bool myEventStarted
bool myCursorIsHand
bool myDrawRect
bool myEnableDrawMode
bool myDrawRectEnabled
bool myPaintersRedrawing
bool IsSketcherStyle
bool myIsKeyFree
bool myAutomaticZoom
QCursor myCursor
double myCurScale
- Protected Attributes inherited from SUIT_ViewWindow
SUIT_Desktop * myDesktop
SUIT_ViewManager * myManager
◆ SOCC_ViewWindow()
SOCC_ViewWindow::SOCC_ViewWindow ( SUIT_Desktop *  theDesktop,
OCCViewer_Viewer *  theModel
Constructor
◆ ~SOCC_ViewWindow()
SOCC_ViewWindow::~SOCC_ViewWindow ( )
Destructor
◆ action()
