calcium_string_port_uses Class Reference
#include <calcium_string_port_uses.hxx>
Inheritance diagram for calcium_string_port_uses:
typedef DataManipulator::Type DataType
typedef DataManipulator::CorbaInType CorbaInDataType
virtual ~calcium_string_port_uses ()
void disconnect (bool provideLastGivenValue)
virtual const char * get_repository_id ()
 This is used by the component to get the CORBA repository id of the uses port. More...
void put (CorbaInDataType data, TimeType time, TagType tag)
virtual void uses_port_changed (Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)
 This method is the uses port's callback to be aware of connections states. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
Engines::DSC::uses_port * _my_ports
PortProperties_i * default_properties
◆ CorbaInDataType
typedef DataManipulator::CorbaInType GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName, calcium_uses_port >::CorbaInDataType
◆ DataType
typedef DataManipulator::Type GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName, calcium_uses_port >::DataType
◆ ~calcium_string_port_uses()
calcium_string_port_uses::~calcium_string_port_uses ( void  )
◆ disconnect()
void CalciumGenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName >::disconnect ( bool  provideLastGivenValue)
Reimplemented from calcium_uses_port.
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_repository_id()
const char * GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName, calcium_uses_port >::get_repository_id
It's an abstract method.
port's CORBA repository id.
Implements uses_port.
◆ put()
void GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName, calcium_uses_port >::put ( CorbaInDataType  data,
TimeType  time,
TagType  tag
◆ uses_port_changed()
void GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName, calcium_uses_port >::uses_port_changed ( Engines::DSC::uses_port *  new_uses_port,
It's an abstract method. The uses port uses this method to manage the sequence of the DSC_Basic uses port.
new_uses_portnew uses port sequence.
messagemessage associated with this modification.
◆ _my_ports
Engines::DSC::uses_port* GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * > , Ports::Calcium_Ports::Calcium_String_Port , repositoryName, calcium_uses_port >::_my_ports
◆ default_properties
PortProperties_i* base_port::default_properties
