calcium_uses_port Class Referenceabstract
#include <calcium_uses_port.hxx>
Inheritance diagram for calcium_uses_port:
 calcium_uses_port ()
virtual ~calcium_uses_port ()
virtual void disconnect (bool)
virtual const char * get_repository_id ()=0
 This is used by the component to get the CORBA repository id of the uses port. More...
virtual void uses_port_changed (Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)=0
 This method is the uses port's callback to be aware of connections states. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
PortProperties_i * default_properties
◆ calcium_uses_port()
calcium_uses_port::calcium_uses_port ( )
◆ ~calcium_uses_port()
calcium_uses_port::~calcium_uses_port ( )
◆ disconnect()
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_repository_id()
virtual const char * uses_port::get_repository_id ( )
pure virtualinherited
It's an abstract method.
port's CORBA repository id.
Implemented in data_short_port_uses, GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >, GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_float, CORBA::Float >, Ports::Calcium_Ports::Calcium_Complex_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_double, CORBA::Double >, Ports::Calcium_Ports::Calcium_Double_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_long, CORBA::Long >, Ports::Calcium_Ports::Calcium_Intc_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_boolean, CORBA::Boolean >, Ports::Calcium_Ports::Calcium_Logical_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_long_long, CORBA::LongLong >, Ports::Calcium_Ports::Calcium_Long_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_float, CORBA::Float >, Ports::Calcium_Ports::Calcium_Real_Port, repositoryName, calcium_uses_port >, and GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * >, Ports::Calcium_Ports::Calcium_String_Port, repositoryName, calcium_uses_port >.
◆ uses_port_changed()
virtual void uses_port::uses_port_changed ( Engines::DSC::uses_port *  new_uses_port,
It's an abstract method. The uses port uses this method to manage the sequence of the DSC_Basic uses port.
new_uses_portnew uses port sequence.
messagemessage associated with this modification.
Implemented in GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >, GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_float, CORBA::Float >, Ports::Calcium_Ports::Calcium_Complex_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_double, CORBA::Double >, Ports::Calcium_Ports::Calcium_Double_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_long, CORBA::Long >, Ports::Calcium_Ports::Calcium_Intc_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_boolean, CORBA::Boolean >, Ports::Calcium_Ports::Calcium_Logical_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_long_long, CORBA::LongLong >, Ports::Calcium_Ports::Calcium_Long_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_float, CORBA::Float >, Ports::Calcium_Ports::Calcium_Real_Port, repositoryName, calcium_uses_port >, GenericUsesPort< seq_u_manipulation< Ports::Calcium_Ports::seq_string, char * >, Ports::Calcium_Ports::Calcium_String_Port, repositoryName, calcium_uses_port >, and data_short_port_uses.
◆ default_properties
PortProperties_i* base_port::default_properties
