20#ifndef FeaturesAPI_BooleanFill_H_
21#define FeaturesAPI_BooleanFill_H_
23#include "FeaturesAPI.h"
25#include <FeaturesPlugin_BooleanFill.h>
29#include <ModelHighAPI_Double.h>
47 const std::list<ModelHighAPI_Selection>& theMainObjects,
48 const std::list<ModelHighAPI_Selection>& theToolObjects,
96 const
bool keepSubResults = false);
Interface for Boolean Fill feature.
Definition: FeaturesAPI_BooleanFill.h:38
Dump wrapped feature.
Definition: FeaturesAPI_BooleanFill.cpp:104
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy() const
Use Fuzzy parameter.
Definition: FeaturesAPI_BooleanFill.h:63
void setToolObjects(const std::list< ModelHighAPI_Selection > &theToolObjects)
Set tool objects.
Definition: FeaturesAPI_BooleanFill.cpp:79
void setUseFuzzy(bool theUseFuzzy)
Set use fuzzy parameter.
Definition: FeaturesAPI_BooleanFill.cpp:88
virtual ~FeaturesAPI_BooleanFill()
Definition: FeaturesAPI_BooleanFill.cpp:64
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_BooleanFill.cpp:70
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > toolObjects() const
Tool objects.
void setFuzzyValue(const ModelHighAPI_Double &theFuzzy)
Set fuzzy parameter.
Definition: FeaturesAPI_BooleanFill.cpp:96
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam() const
Fuzzy parameter.
FeaturesAPI_BooleanFill(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_BooleanFill.cpp:31
Feature kind.
Definition: FeaturesPlugin_BooleanFill.h:33
static const std::string & TOOL_LIST_ID()
Attribute name of tool objects.
Definition: FeaturesPlugin_Boolean.h:48
static const std::string & OBJECT_LIST_ID()
Attribute name of main objects.
Definition: FeaturesPlugin_Boolean.h:41
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Boolean.h:55
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Boolean.h:62
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
BooleanFillPtr addSplit(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theMainObjects, const std::list< ModelHighAPI_Selection > &theToolObjects, const ModelHighAPI_Double &fuzzyParam=ModelHighAPI_Double(-1), const bool keepSubResults=false)
Create Boolean Fill feature.
Definition: FeaturesAPI_BooleanFill.cpp:130
