FeaturesAPI_Copy.h
20#ifndef FeaturesAPI_Copy_H_
21#define FeaturesAPI_Copy_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Copy.h>
26
32
37{
38public:
40 FEATURESAPI_EXPORT
41 explicit FeaturesAPI_Copy(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 FEATURESAPI_EXPORT
45 explicit FeaturesAPI_Copy(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const std::list<ModelHighAPI_Selection>& theBaseObjects,
47 const int theNumber);
48
50 FEATURESAPI_EXPORT virtual ~FeaturesAPI_Copy();
51
52 INTERFACE_2(FeaturesPlugin_Copy::ID(),
57
58
59 FEATURESAPI_EXPORT void setObjects(const std::list<ModelHighAPI_Selection>& theBaseObjects);
60
62 FEATURESAPI_EXPORT void setNumber(const int theNumber);
63
65 FEATURESAPI_EXPORT virtual void dump(ModelHighAPI_Dumper& theDumper) const;
66};
67
69typedef std::shared_ptr<FeaturesAPI_Copy> CopyPtr;
70
73FEATURESAPI_EXPORT
74CopyPtr addCopy(const std::shared_ptr<ModelAPI_Document>& thePart,
75 const std::list<ModelHighAPI_Selection>& theObjects,
76 const int theNumber);
77
78#endif // FeaturesAPI_Copy_H_
Interface for Copy feature.
Definition: FeaturesAPI_Copy.h:37
Definition: FeaturesAPI_Copy.cpp:45
void setObjects(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify objects attribute of the feature.
Definition: FeaturesAPI_Copy.cpp:48
Dump wrapped feature.
Definition: FeaturesAPI_Copy.cpp:61
Modify number of copies attribute of the feature.
Definition: FeaturesAPI_Copy.cpp:54
virtual std::shared_ptr< ModelAPI_AttributeInteger > number() const
Number of copies.
Definition: FeaturesAPI_Copy.h:56
FeaturesAPI_Copy(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Copy.cpp:26
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > objects() const
Source objects.
Feature kind.
Definition: FeaturesPlugin_Copy.h:39
static const std::string NUMBER()
Integer attribute that contains the number of resulting copies needed.
Definition: FeaturesPlugin_Copy.h:59
static const std::string & OBJECTS()
Selection list attribute that contains all copied shapes selection.
Definition: FeaturesPlugin_Copy.h:53
API for the attribute that contains integer (int).
Definition: ModelAPI_AttributeInteger.h:34
Dump engine for the model.
CopyPtr addCopy(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theObjects, const int theNumber)
Create Copy feature.
Definition: FeaturesAPI_Copy.cpp:74
