ModelAPI_Attribute.h
20#ifndef ModelAPI_Attribute_H_
21#define ModelAPI_Attribute_H_
23#include "ModelAPI.h"
24#include <string>
25#include <memory>
26
27class ModelAPI_Object;
28
34{
36 std::shared_ptr<ModelAPI_Object> myObject;
37 std::string myID;
38 protected:
39 // accessible from the attributes
44
45 public:
46
48 MODELAPI_EXPORT virtual std::string attributeType() = 0;
49
51 MODELAPI_EXPORT virtual ~ModelAPI_Attribute();
52
54 MODELAPI_EXPORT virtual void setObject(const std::shared_ptr<ModelAPI_Object>& theObject);
55
57 MODELAPI_EXPORT const std::shared_ptr<ModelAPI_Object>& owner() const;
58
60 MODELAPI_EXPORT virtual bool isInitialized();
61
63 MODELAPI_EXPORT void setInitialized();
64
68 MODELAPI_EXPORT bool blockSetInitialized(const bool theBlock);
69
73 MODELAPI_EXPORT void setIsArgument(const bool theFlag);
74
76 MODELAPI_EXPORT bool isArgument();
77
81 MODELAPI_EXPORT bool setImmutable(const bool theFlag);
82
84 MODELAPI_EXPORT bool isImmutable();
85
87 MODELAPI_EXPORT const std::string& id() const;
88
90 MODELAPI_EXPORT virtual void reset();
91
92 protected:
94 MODELAPI_EXPORT ModelAPI_Attribute();
95
97 MODELAPI_EXPORT virtual void setID(const std::string theID);
98
100 MODELAPI_EXPORT virtual void reinit();
101
102 friend class Model_Data;
103 friend class Model_Objects;
104};
105
107typedef std::shared_ptr<ModelAPI_Attribute> AttributePtr;
108
109#endif
bool myIsArgument
is this attribute used as an argument for execution
Definition: ModelAPI_Attribute.h:42
Sets the ID of the attribute in Data (called from Data)
Definition: ModelAPI_Attribute.cpp:95
virtual std::string attributeType()=0
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_Attribute.cpp:86
Resets attribute to default state.
Definition: ModelAPI_Attribute.cpp:102
bool myIsImmutable
is this attribute can be changed programmatically (e.g. by constraint)
Definition: ModelAPI_Attribute.h:43
Returns true if attribute was initialized by some value.
Definition: ModelAPI_Attribute.cpp:39
Blocks sending "attribute updated" if theBlock is true.
Definition: ModelAPI_Attribute.cpp:50
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: ModelAPI_Attribute.cpp:100
bool isArgument()
Returns true if attribute causes the result change.
Definition: ModelAPI_Attribute.cpp:64
bool myIsInitialized
is some value assigned to this attribute
Definition: ModelAPI_Attribute.h:40
bool isImmutable()
Returns true if can not be changed programmatically.
Definition: ModelAPI_Attribute.cpp:76
bool mySetInitializedBlocked
is initialized blocked
Definition: ModelAPI_Attribute.h:41
const std::shared_ptr< ModelAPI_Object > & owner() const
Returns the owner of this attribute.
Definition: ModelAPI_Attribute.cpp:33
virtual void setObject(const std::shared_ptr< ModelAPI_Object > &theObject)
Sets the owner of this attribute.
Definition: ModelAPI_Attribute.cpp:27
const std::string & id() const
ID of the attribute in Data.
Definition: ModelAPI_Attribute.cpp:81
Makes attribute initialized.
Definition: ModelAPI_Attribute.cpp:44
Immutable argument can not be changed programmatically (e.g.
Definition: ModelAPI_Attribute.cpp:69
To virtually destroy the fields of successors.
Definition: ModelAPI_Attribute.cpp:22
Set this attribute is argument for result (change of this attribute requires update of result).
Definition: ModelAPI_Attribute.cpp:59
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
Manager of objects of the document.
Definition: Model_Objects.h:46
