ModelHighAPI_FeatureStore.h
20#ifndef ModelHighAPI_FeatureStore_H_
21#define ModelHighAPI_FeatureStore_H_
23#include "ModelHighAPI.h"
24
25#include <map>
26#include <list>
27#include <string>
28#include <memory>
30class ModelAPI_Object;
31class ModelAPI_Data;
32class GeomAPI_Shape;
34
35typedef std::shared_ptr<ModelAPI_Object> ObjectPtr;
36typedef std::shared_ptr<ModelAPI_Attribute> AttributePtr;
37
44 std::map<std::string, std::string> myAttrs;
46 std::list<std::map<std::string, std::string> > myRes;
47public:
48 // unused constructor for the map container needs
50 // constructor that initializes this object by feature to store
51 ModelHighAPI_FeatureStore(ObjectPtr theObject);
52 // compares the stored feature information with the given feature
53 std::string compare(ObjectPtr theObject);
54
55private:
57 void storeData(std::shared_ptr<ModelAPI_Data> theData,
58 std::map<std::string, std::string>& theAttrs);
61 std::string compareData(std::shared_ptr<ModelAPI_Data> theData,
62 std::map<std::string, std::string>& theAttrs);
65 std::string compareShape(const std::string &theOrig,
66 const std::string &theCurrent);
68 std::string dumpAttr(const AttributePtr& theAttr);
70 std::string dumpShape(std::shared_ptr<GeomAPI_Shape>& theShape);
71};
72
73#endif
General object of the application that allows to get/set attributes from the document and compute res...
Definition: ModelAPI_Data.h:73
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
Allows to compare the original and the dumped/executed feature.
Definition: ModelHighAPI_FeatureStore.h:42
