ModelHighAPI_RefAttr.h
20#ifndef SRC_MODELHIGHAPI_MODELHIGHAPI_REFATTR_H_
21#define SRC_MODELHIGHAPI_MODELHIGHAPI_REFATTR_H_
23//--------------------------------------------------------------------------------------
24#include "ModelHighAPI.h"
26#include <memory>
27#include <string>
28//--------------------------------------------------------------------------------------
32class ModelAPI_Object;
35//--------------------------------------------------------------------------------------
41{
42public:
44 MODELHIGHAPI_EXPORT
47 MODELHIGHAPI_EXPORT
48 ModelHighAPI_RefAttr(const std::shared_ptr<ModelAPI_Attribute> & theValue);
50 MODELHIGHAPI_EXPORT
51 ModelHighAPI_RefAttr(const std::shared_ptr<ModelAPI_Object> & theValue);
53 MODELHIGHAPI_EXPORT
54 ModelHighAPI_RefAttr(const std::shared_ptr<ModelHighAPI_Interface> & theValue);
56 MODELHIGHAPI_EXPORT
57 virtual ~ModelHighAPI_RefAttr();
58
60 MODELHIGHAPI_EXPORT virtual
61 void fillAttribute(const std::shared_ptr<ModelAPI_AttributeRefAttr> & theAttribute) const;
62
64 MODELHIGHAPI_EXPORT virtual
65 void appendToList(const std::shared_ptr<ModelAPI_AttributeRefAttrList> & theAttribute) const;
66
68 MODELHIGHAPI_EXPORT
69 bool isEmpty() const;
70
72 MODELHIGHAPI_EXPORT
73 void fillMessage(const std::shared_ptr<ModelAPI_ObjectMovedMessage>& theMessage) const;
74
75 std::shared_ptr<ModelAPI_Attribute> attr() const { return myAttribute; }
76 std::shared_ptr<ModelAPI_Object> object() const { return myObject; }
77
78private:
79 enum VariantType { VT_ATTRIBUTE, VT_OBJECT } myVariantType;
80 std::shared_ptr<ModelAPI_Attribute> myAttribute;
81 std::shared_ptr<ModelAPI_Object> myObject;
82};
83
84//--------------------------------------------------------------------------------------
85//--------------------------------------------------------------------------------------
86#endif /* SRC_MODELHIGHAPI_MODELHIGHAPI_REFATTR_H_ */
Attribute that contains list of references to features (located in the same document) or references t...
Definition: ModelAPI_AttributeRefAttrList.h:34
Attribute that contains reference to an attribute of a feature or reference to a feature (switchable)
Definition: ModelAPI_AttributeRefAttr.h:33
Message sent when feature or attribute has been moved.
Definition: ModelAPI_Events.h:603
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
Class for filling ModelAPI_AttributeRefAttr.
Definition: ModelHighAPI_RefAttr.h:41
Default constructor.
Definition: ModelHighAPI_RefAttr.cpp:29
Check the object is empty.
Definition: ModelHighAPI_RefAttr.cpp:80
void fillMessage(const std::shared_ptr< ModelAPI_ObjectMovedMessage > &theMessage) const
Fill moved message by the attribute or object.
Definition: ModelHighAPI_RefAttr.cpp:86
Definition: ModelHighAPI_RefAttr.cpp:55
virtual void appendToList(const std::shared_ptr< ModelAPI_AttributeRefAttrList > &theAttribute) const
Append to list attribute.
Definition: ModelHighAPI_RefAttr.cpp:70
virtual void fillAttribute(const std::shared_ptr< ModelAPI_AttributeRefAttr > &theAttribute) const
Fill attribute values.
Definition: ModelHighAPI_RefAttr.cpp:60
