PartSet_WidgetFeaturePointSelector.h
20#ifndef PartSet_WidgetFeaturePointSelector_H
21#define PartSet_WidgetFeaturePointSelector_H
23#include <ModelAPI_CompositeFeature.h>
24#include <ModuleBase_WidgetShapeSelector.h>
25#include <ModuleBase_ViewerPrs.h>
26
27#include "PartSet.h"
28#include "PartSet_MouseProcessor.h"
30#include <Quantity_Color.hxx>
31
32#include <QObject>
33
34#include <string>
35
41
42class GeomAPI_Pnt;
43class GeomAPI_Pnt2d;
45
46class QWidget;
47class QMouseEvent;
48
57{
58Q_OBJECT
59 public:
65 const Config_WidgetAPI* theData);
66
68
75 virtual bool isValidSelection(const std::shared_ptr<ModuleBase_ViewerPrs>& theValue);
76
79 void setSketcher(CompositeFeaturePtr theSketch) { mySketch = theSketch; }
80
82 CompositeFeaturePtr sketch() const { return mySketch; }
83
85 virtual void deactivate();
86
90 virtual void mouseMoved(ModuleBase_IViewWindow* theWindow, QMouseEvent* theEvent);
91
95 virtual void mouseReleased(ModuleBase_IViewWindow* theWindow, QMouseEvent* theEvent);
96
97
100 virtual bool setSelectionCustom(const ModuleBase_ViewerPrsPtr& thePrs);
101
103 virtual void setPreSelection(const ModuleBase_ViewerPrsPtr& thePreSelected,
105 QMouseEvent* theEvent);
106protected:
110 virtual QList<std::shared_ptr<ModuleBase_ViewerPrs>> getAttributeSelection() const;
111
113 virtual void activateCustom();
114
119 virtual void getGeomSelection(const std::shared_ptr<ModuleBase_ViewerPrs>& thePrs,
120 ObjectPtr& theObject, GeomShapePtr& theShape);
121
127 void restoreAttributeValue(const AttributePtr& theAttribute, const bool theValid);
128
129protected:
130 bool fillFeature();
131
133 CompositeFeaturePtr mySketch;
134 Quantity_Color myHighlightColor;
135 Quantity_Color mySelectionColor;
136
137 std::string mySelectedObjectAttribute;
138 std::string mySelectedPointAttribute;
139 std::string myPreviewObjectAttribute;
140 std::string myPreviewPointAttribute;
141
142 bool myHasPreview;
143 std::shared_ptr<ModelAPI_Object> myPreviewObject;
144 std::shared_ptr<GeomAPI_Pnt2d> myPreviewPoint;
146};
147
148#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
Definition: GeomAPI_Pnt.h:38
Interface to ViewWindow object which contains 3d scene.
Definition: ModuleBase_IViewWindow.h:34
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
Presentation.
Definition: ModuleBase_ViewerPrs.h:37
The methiod called when widget is activated.
Definition: ModuleBase_WidgetSelector.cpp:215
virtual void getGeomSelection(const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, ObjectPtr &theObject, GeomShapePtr &theShape)
Return an object and geom shape by the viewer presentation.
Definition: ModuleBase_WidgetSelector.cpp:65
virtual bool setSelectionCustom(const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
Fills the attribute with the value of the selected owner.
Definition: ModuleBase_WidgetSelector.cpp:242
The methiod called when widget is deactivated.
Definition: ModuleBase_WidgetSelector.cpp:254
Implementation of widget for shapes selection.
Definition: ModuleBase_WidgetShapeSelector.h:71
virtual QList< std::shared_ptr< ModuleBase_ViewerPrs > > getAttributeSelection() const
Return the attribute values wrapped in a list of viewer presentations.
Definition: ModuleBase_WidgetShapeSelector.cpp:149
virtual bool isValidSelection(const std::shared_ptr< ModuleBase_ViewerPrs > &theValue)
Checks all widget validator if the owner is valid.
Definition: ModuleBase_WidgetValidated.cpp:256
virtual void restoreAttributeValue(const AttributePtr &theAttribute, const bool theValid)
Creates a backup of the current values of the attribute It should be realized in the specific widget ...
Definition: ModuleBase_WidgetValidated.cpp:92
Customosation of ModuleBase_WidgetShapeSelector in order to provide working with sketch specific obje...
Definition: PartSet_ExternalObjectsMgr.h:43
Interface for mouse events processing.
Definition: PartSet_MouseProcessor.h:40
virtual void mouseMoved(ModuleBase_IViewWindow *theWindow, QMouseEvent *theEvent)
Processing the mouse move event in the viewer.
Definition: PartSet_MouseProcessor.h:45
virtual void setPreSelection(const std::shared_ptr< ModuleBase_ViewerPrs > &thePreSelected, ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent)
Fill preselection used in mouseReleased.
Definition: PartSet_MouseProcessor.h:64
virtual void mouseReleased(ModuleBase_IViewWindow *theWindow, QMouseEvent *theEvent)
Processing the mouse release event in the viewer.
Definition: PartSet_MouseProcessor.h:55
Customosation of PartSet_WidgetFeaturePointSelector in order to visualize sub-shape by mouse move ove...
Definition: PartSet_WidgetFeaturePointSelector.h:57
Retrurns installed sketcher.
Definition: PartSet_WidgetFeaturePointSelector.h:82
Set sketcher.
Definition: PartSet_WidgetFeaturePointSelector.h:79
PartSet_ExternalObjectsMgr * myExternalObjectMgr
reference to external objects manager
Definition: PartSet_WidgetFeaturePointSelector.h:145
Pointer to a sketch.
Definition: PartSet_WidgetFeaturePointSelector.h:133
