Interface for CompSolid feature. More...
#include <BuildAPI_CompSolid.h>
| BuildAPI_CompSolid (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| BuildAPI_CompSolid (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects) | |
| virtual | ~BuildAPI_CompSolid () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| Base objects. More... | |
| void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| Modify base attribute of the feature. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseObjects |
explicit |
explicit |
inlinevirtual |
Base objects.
| void BuildAPI_CompSolid::setBase | ( | const std::list< ModelHighAPI_Selection > & | theBaseObjects | ) |
protectedinherited |
