BuildAPI_Compound Class Reference
Interface for Compound feature. More...
#include <BuildAPI_Compound.h>
Inheritance diagram for BuildAPI_Compound:
 BuildAPI_Compound (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 BuildAPI_Compound (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects)
virtual ~BuildAPI_Compound ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
◆ BuildAPI_Compound() [1/2]
BuildAPI_Compound::BuildAPI_Compound ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ BuildAPI_Compound() [2/2]
BuildAPI_Compound::BuildAPI_Compound ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects
explicit
◆ ~BuildAPI_Compound()
BuildAPI_Compound::~BuildAPI_Compound ( )
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > BuildAPI_Compound::baseObjects ( ) const
Base objects.
◆ setBase()
void BuildAPI_Compound::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ dump()
void BuildAPI_Compound::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
