Interface for Polyline feature. More...
#include <BuildAPI_Polyline.h>
| BuildAPI_Polyline (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| BuildAPI_Polyline (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool theIsClosed) | |
| virtual | ~BuildAPI_Polyline () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| Base objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | closed () const |
| Closed flag. More... | |
| void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| Modify base attribute of the feature. More... | |
| void | setClosed (const bool theIsClosed) |
| Set closed flag. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseObjects |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myclosed |
explicit |
explicit |
inlinevirtual |
Base objects.
inlinevirtual |
Closed flag.
| void BuildAPI_Polyline::setBase | ( | const std::list< ModelHighAPI_Selection > & | theBaseObjects | ) |
| void BuildAPI_Polyline::setClosed | ( | const bool | theIsClosed | ) |
Set closed flag.
protectedinherited |
