BuildAPI_Solid Class Reference
Interface for Solid feature. More...
#include <BuildAPI_Solid.h>
Inheritance diagram for BuildAPI_Solid:
 BuildAPI_Solid (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 BuildAPI_Solid (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects)
virtual ~BuildAPI_Solid ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
◆ BuildAPI_Solid() [1/2]
BuildAPI_Solid::BuildAPI_Solid ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ BuildAPI_Solid() [2/2]
BuildAPI_Solid::BuildAPI_Solid ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects
explicit
◆ ~BuildAPI_Solid()
BuildAPI_Solid::~BuildAPI_Solid ( )
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > BuildAPI_Solid::baseObjects ( ) const
Base objects.
◆ setBase()
void BuildAPI_Solid::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ dump()
void BuildAPI_Solid::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
