Interface for Group Addition feature. More...
#include <CollectionAPI_GroupAddition.h>
| CollectionAPI_GroupAddition (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| CollectionAPI_GroupAddition (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theGroupList) | |
| virtual | ~CollectionAPI_GroupAddition () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | groupList () const |
| Group list. More... | |
| void | setGroupList (const std::list< ModelHighAPI_Selection > &theGroupList) |
| Set main objects. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mygroupList |
explicit |
| CollectionAPI_GroupAddition::CollectionAPI_GroupAddition | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const std::list< ModelHighAPI_Selection > & | theGroupList | ||
inlinevirtual |
Group list.
| void CollectionAPI_GroupAddition::setGroupList | ( | const std::list< ModelHighAPI_Selection > & | theGroupList | ) |
Set main objects.
protectedinherited |
