CollectionAPI_GroupIntersection Class Reference
Interface for Group Intersection feature. More...
#include <CollectionAPI_GroupIntersection.h>
Inheritance diagram for CollectionAPI_GroupIntersection:
 CollectionAPI_GroupIntersection (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 CollectionAPI_GroupIntersection (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theGroupList)
virtual ~CollectionAPI_GroupIntersection ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > groupList () const
 Group list. More...
void setGroupList (const std::list< ModelHighAPI_Selection > &theGroupList)
 Set main objects. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mygroupList
◆ CollectionAPI_GroupIntersection() [1/2]
CollectionAPI_GroupIntersection::CollectionAPI_GroupIntersection ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ CollectionAPI_GroupIntersection() [2/2]
CollectionAPI_GroupIntersection::CollectionAPI_GroupIntersection ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theGroupList
◆ ~CollectionAPI_GroupIntersection()
CollectionAPI_GroupIntersection::~CollectionAPI_GroupIntersection ( )
◆ groupList()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > CollectionAPI_GroupIntersection::groupList ( ) const
Group list.
◆ setGroupList()
void CollectionAPI_GroupIntersection::setGroupList ( const std::list< ModelHighAPI_Selection > &  theGroupList)
Set main objects.
◆ dump()
void CollectionAPI_GroupIntersection::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
