Interface for Group Intersection feature. More...
#include <CollectionAPI_GroupSubstraction.h>
| CollectionAPI_GroupSubstraction (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| CollectionAPI_GroupSubstraction (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theObjectsList, const std::list< ModelHighAPI_Selection > &theToolsList) | |
| virtual | ~CollectionAPI_GroupSubstraction () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | objectsList () const |
| Objects list. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | toolsList () const |
| Tools list. More... | |
| void | setObjectsList (const std::list< ModelHighAPI_Selection > &theGroupList) |
| Set main objects. More... | |
| void | setToolsList (const std::list< ModelHighAPI_Selection > &theGroupList) |
| Set tools. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | myobjectsList |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mytoolsList |
explicit |
| CollectionAPI_GroupSubstraction::CollectionAPI_GroupSubstraction | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const std::list< ModelHighAPI_Selection > & | theObjectsList, | ||
| const std::list< ModelHighAPI_Selection > & | theToolsList | ||
inlinevirtual |
Objects list.
inlinevirtual |
Tools list.
| void CollectionAPI_GroupSubstraction::setObjectsList | ( | const std::list< ModelHighAPI_Selection > & | theGroupList | ) |
Set main objects.
| void CollectionAPI_GroupSubstraction::setToolsList | ( | const std::list< ModelHighAPI_Selection > & | theGroupList | ) |
Set tools.
protectedinherited |
