Interface for the Defeaturing feature. More...
#include <FeaturesAPI_Defeaturing.h>
| FeaturesAPI_Defeaturing (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Defeaturing (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theFacesToRemove) | |
| virtual | ~FeaturesAPI_Defeaturing () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| Base objects. More... | |
| void | setFaces (const std::list< ModelHighAPI_Selection > &theFacesToRemove) |
| Modify faces to be removed. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseObjects |
explicit |
explicit |
inlinevirtual |
Base objects.
| void FeaturesAPI_Defeaturing::setFaces | ( | const std::list< ModelHighAPI_Selection > & | theFacesToRemove | ) |
protectedinherited |
