FeaturesAPI_FusionFaces Class Reference
Interface for FusionFaces feature. More...
#include <FeaturesAPI_FusionFaces.h>
Inheritance diagram for FeaturesAPI_FusionFaces:
 FeaturesAPI_FusionFaces (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_FusionFaces (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBase)
virtual ~FeaturesAPI_FusionFaces ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelection > base () const
 Base. More...
void setBase (const ModelHighAPI_Selection &theBase)
 Modify base object attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > mybase
◆ FeaturesAPI_FusionFaces() [1/2]
FeaturesAPI_FusionFaces::FeaturesAPI_FusionFaces ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_FusionFaces() [2/2]
FeaturesAPI_FusionFaces::FeaturesAPI_FusionFaces ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theBase
explicit
◆ ~FeaturesAPI_FusionFaces()
FeaturesAPI_FusionFaces::~FeaturesAPI_FusionFaces ( )
◆ base()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_FusionFaces::base ( ) const
Base.
◆ setBase()
void FeaturesAPI_FusionFaces::setBase ( const ModelHighAPI_Selection &  theBase)
◆ dump()
void FeaturesAPI_FusionFaces::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
