FeaturesAPI_ImportResult Class Reference
Interface for ImportResult feature. More...
#include <FeaturesAPI_ImportResult.h>
Inheritance diagram for FeaturesAPI_ImportResult:
 FeaturesAPI_ImportResult (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_ImportResult (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects)
virtual ~FeaturesAPI_ImportResult ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > objects () const
 Source objects. More...
void setObjects (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify objects attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > myobjects
◆ FeaturesAPI_ImportResult() [1/2]
FeaturesAPI_ImportResult::FeaturesAPI_ImportResult ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_ImportResult() [2/2]
FeaturesAPI_ImportResult::FeaturesAPI_ImportResult ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects
explicit
◆ ~FeaturesAPI_ImportResult()
FeaturesAPI_ImportResult::~FeaturesAPI_ImportResult ( )
◆ objects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_ImportResult::objects ( ) const
Source objects.
◆ setObjects()
void FeaturesAPI_ImportResult::setObjects ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ dump()
void FeaturesAPI_ImportResult::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
