Interface for Loft feature. More...
#include <FeaturesAPI_Loft.h>
| FeaturesAPI_Loft (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Loft (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theFirstObject, const ModelHighAPI_Selection &theSecondObject) | |
| virtual | ~FeaturesAPI_Loft () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | fisrstObject () const |
| First object. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | secondObject () const |
| second objexct More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | myfisrstObject |
| std::shared_ptr< ModelAPI_AttributeSelection > | mysecondObject |
explicit |
explicit |
inlinevirtual |
First object.
inlinevirtual |
second objexct
protectedinherited |
