FeaturesAPI_PointCloudOnFace Class Reference
Interface for PointCloudOnFace feature. More...
#include <FeaturesAPI_PointCloudOnFace.h>
Inheritance diagram for FeaturesAPI_PointCloudOnFace:
 FeaturesAPI_PointCloudOnFace (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_PointCloudOnFace (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theFace, const ModelHighAPI_Integer &theNumber)
virtual ~FeaturesAPI_PointCloudOnFace ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelection > faceSelected () const
 face More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > nbPoints () const
 Number of points. More...
void setNumberOfPoints (const ModelHighAPI_Integer &theNumber)
 Modify CreationMethod, nb_points attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > myfaceSelected
std::shared_ptr< ModelAPI_AttributeInteger > mynbPoints
◆ FeaturesAPI_PointCloudOnFace() [1/2]
FeaturesAPI_PointCloudOnFace::FeaturesAPI_PointCloudOnFace ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_PointCloudOnFace() [2/2]
FeaturesAPI_PointCloudOnFace::FeaturesAPI_PointCloudOnFace ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theFace,
const ModelHighAPI_Integer &  theNumber
explicit
◆ ~FeaturesAPI_PointCloudOnFace()
FeaturesAPI_PointCloudOnFace::~FeaturesAPI_PointCloudOnFace ( )
◆ faceSelected()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_PointCloudOnFace::faceSelected ( ) const
face
◆ nbPoints()
virtual std::shared_ptr< ModelAPI_AttributeInteger > FeaturesAPI_PointCloudOnFace::nbPoints ( ) const
Number of points.
◆ setNumberOfPoints()
void FeaturesAPI_PointCloudOnFace::setNumberOfPoints ( const ModelHighAPI_Integer &  theNumber)
◆ dump()
void FeaturesAPI_PointCloudOnFace::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
