Interface for RemoveExtraEdges feature. More...
#include <FeaturesAPI_RemoveExtraEdges.h>
| FeaturesAPI_RemoveExtraEdges (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_RemoveExtraEdges (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBase, const bool theDoUniteFaces) | |
| virtual | ~FeaturesAPI_RemoveExtraEdges () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | base () const |
| Base. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | uniteFaces () const |
| Merge faces that lie on common surface. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | mybase |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myuniteFaces |
explicit |
explicit |
inlinevirtual |
Base.
inlinevirtual |
protectedinherited |
