FeaturesAPI_RemoveResults Class Reference
Interface for RemoveResults feature. More...
#include <FeaturesAPI_RemoveResults.h>
Inheritance diagram for FeaturesAPI_RemoveResults:
 FeaturesAPI_RemoveResults (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_RemoveResults (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theResults)
virtual ~FeaturesAPI_RemoveResults ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > removed () const
 Results to remove. More...
void setRemoved (const std::list< ModelHighAPI_Selection > &theResults)
 Modify removed results arguments. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > myremoved
◆ FeaturesAPI_RemoveResults() [1/2]
FeaturesAPI_RemoveResults::FeaturesAPI_RemoveResults ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_RemoveResults() [2/2]
FeaturesAPI_RemoveResults::FeaturesAPI_RemoveResults ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theResults
explicit
◆ ~FeaturesAPI_RemoveResults()
FeaturesAPI_RemoveResults::~FeaturesAPI_RemoveResults ( )
◆ removed()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_RemoveResults::removed ( ) const
Results to remove.
◆ setRemoved()
void FeaturesAPI_RemoveResults::setRemoved ( const std::list< ModelHighAPI_Selection > &  theResults)
◆ dump()
void FeaturesAPI_RemoveResults::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
