Ellipse in 2D. More...
#include <GeomAPI_Ellipse2d.h>
| GEOMAPI_EXPORT | GeomAPI_Ellipse2d (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Dir2d > &theXAxis, const double theMajorRadius, const double theMinorRadius) |
| Constructs ellipse by center, X-axis and given radii. More... | |
| GEOMAPI_EXPORT | GeomAPI_Ellipse2d (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theAxisPoint, const std::shared_ptr< GeomAPI_Pnt2d > &thePassingPoint) |
| Constructs ellipse by center and two points lying on the ellipse: first of them defines an axis of the ellipse and another is just placed on the ellipse. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > | center () const |
| Returns center of the ellipse. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > | firstFocus () const |
| Returns first focus of the ellipse. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > | secondFocus () const |
| Returns second focus of the ellipse. More... | |
| GEOMAPI_EXPORT double | minorRadius () const |
| Returns minor radius of the ellipse. More... | |
| GEOMAPI_EXPORT double | majorRadius () const |
| Returns major radius of the ellipse. More... | |
| GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > | project (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) const |
| Project point on ellipse. More... | |
| GEOMAPI_EXPORT const bool | parameter (const std::shared_ptr< GeomAPI_Pnt2d > thePoint, const double theTolerance, double &theParameter) const |
| Computes the parameter of a given point on an ellipse. More... | |
| GEOMAPI_EXPORT double | distance (const std::shared_ptr< GeomAPI_Lin2d > &theLine, std::shared_ptr< GeomAPI_Pnt2d > &thePointOnMe, std::shared_ptr< GeomAPI_Pnt2d > &thePointOnLine) |
| Calculate minimal distance between the ellipse and a line. More... | |
| GEOMAPI_EXPORT double | distance (const std::shared_ptr< GeomAPI_Circ2d > &theCircle, std::shared_ptr< GeomAPI_Pnt2d > &thePointOnMe, std::shared_ptr< GeomAPI_Pnt2d > &thePointOnCircle) |
| Calculate minimal distance between the ellipse and a circle. More... | |
| GEOMAPI_EXPORT double | distance (const std::shared_ptr< GeomAPI_Ellipse2d > &theEllipse, std::shared_ptr< GeomAPI_Pnt2d > &thePointOnMe, std::shared_ptr< GeomAPI_Pnt2d > &thePointOnEllipse) |
| Calculate minimal distance between two ellipses. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Ellipse in 2D.
| GeomAPI_Ellipse2d::GeomAPI_Ellipse2d | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter, |
| const std::shared_ptr< GeomAPI_Dir2d > & | theXAxis, | ||
| const double | theMajorRadius, | ||
| const double | theMinorRadius | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theAxisPoint, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | thePassingPoint | ||
| std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Ellipse2d::center | ( | ) | const |
| std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Ellipse2d::firstFocus | ( | ) | const |
| std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Ellipse2d::secondFocus | ( | ) | const |
| double GeomAPI_Ellipse2d::minorRadius | ( | ) | const |
| double GeomAPI_Ellipse2d::majorRadius | ( | ) | const |
| const std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Ellipse2d::project | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | thePoint | ) | const |
| const bool GeomAPI_Ellipse2d::parameter | ( | const std::shared_ptr< GeomAPI_Pnt2d > | thePoint, |
| const double | theTolerance, | ||
| double & | theParameter | ||
| ) | const |
The point must be located either on the circle itself or relatively to the latter at a distance less than the tolerance value. Return FALSE if the point is beyond the tolerance limit or if computation fails. Max Tolerance value is currently limited to 1.e-4
| [in] | thePoint | point of origin. |
| [in] | theTolerance | tolerance of computation. |
| [out] | theParameter | resulting parameter. |
| double GeomAPI_Ellipse2d::distance | ( | const std::shared_ptr< GeomAPI_Lin2d > & | theLine, |
| std::shared_ptr< GeomAPI_Pnt2d > & | thePointOnMe, | ||
| std::shared_ptr< GeomAPI_Pnt2d > & | thePointOnLine | ||
Return corresponding points on the ellipse and on the line.
| double GeomAPI_Ellipse2d::distance | ( | const std::shared_ptr< GeomAPI_Circ2d > & | theCircle, |
| std::shared_ptr< GeomAPI_Pnt2d > & | thePointOnCircle | ||
Return corresponding points on the ellipse and on the circle.
| double GeomAPI_Ellipse2d::distance | ( | const std::shared_ptr< GeomAPI_Ellipse2d > & | theEllipse, |
| std::shared_ptr< GeomAPI_Pnt2d > & | thePointOnEllipse | ||
Return corresponding points on the ellipses.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
