PartSet_FeatureFolderNode Class Referenceabstract
A base class for root folders. More...
#include <PartSet_TreeNodes.h>
Inheritance diagram for PartSet_FeatureFolderNode:
enum  VisibilityState { NoneState , Visible , SemiVisible , Hidden }
 PartSet_FeatureFolderNode (ModuleBase_ITreeNode *theParent=0)
virtual QTreeNodesList objectCreated (const QObjectPtrList &theObjects)
 Process creation of objects. More...
virtual QTreeNodesList objectsDeleted (const DocumentPtr &theDoc, const QString &theGroup)
 Process deletion of objects. More...
virtual ModuleBase_ITreeNode * findParent (const DocumentPtr &theDoc, QString theGroup)
 Returns a node which belongs to the given document and contains objects of the given group. More...
virtual QVariant data (int theColumn, int theRole) const
 Returns the node representation according to theRole. More...
virtual QColor activeItemColor () const
virtual std::string type () const =0
virtual Qt::ItemFlags flags (int theColumn) const
 Returns properties flag of the item. More...
ModuleBase_ITreeNode * parent () const
 Returns parent node of the current node. More...
QTreeNodesList children () const
 Returns list of the node children. More...
ModuleBase_ITreeNode * subNode (int theRow) const
 Returns a children node according to given row (index) More...
ModuleBase_ITreeNode * subNode (const ObjectPtr &theObj, bool allLevels=true) const
 Finds a node which contains the referenced object. More...
bool hasSubNode (ModuleBase_ITreeNode *theNode, bool allLevels=true) const
 Returns true if the given node is found within children. More...
int childrenCount () const
 Returns number of children. More...
int nodeRow (ModuleBase_ITreeNode *theNode) const
virtual ObjectPtr object () const
 Returns object referenced by the node (can be null) More...
virtual void update ()
 Updates all sub-nodes of the node (checks whole sub-tree) More...
virtual ModuleBase_IWorkshop * workshop () const
 Returns workshop object. Has to be reimplemented in a root node. More...
virtual DocumentPtr document () const
 Returns document object of the sub-tree. Has to be reimplemented in sub-tree root object. More...
virtual ModuleBase_ITreeNode * findRoot (const DocumentPtr &theDoc)
 Returns root node of a data tree of the given document. More...
virtual VisibilityState visibilityState () const
 Returns visibilitystate of the node in viewer 3d. More...
virtual ModuleBase_ITreeNode * createNode (const ObjectPtr &theObj)=0
virtual int numberOfFolders () const
virtual void deleteChildren ()
 deletes all children nodes (called in destructor.) More...
void sortChildren ()
ModuleBase_ITreeNode * myParent
 Parent of the node. More...
QTreeNodesList myChildren
 Children of the node. More...
◆ objectCreated()
QTreeNodesList PartSet_FeatureFolderNode::objectCreated ( const QObjectPtrList &  theObjects)
theObjectsa list of created objects
a list of nodes which corresponds to the created objects
Reimplemented from ModuleBase_ITreeNode.
Reimplemented in PartSet_PartRootNode.
◆ objectsDeleted()
QTreeNodesList PartSet_FeatureFolderNode::objectsDeleted ( const DocumentPtr &  theDoc,
const QString &  theGroup
theDoca document where objects were deleted
theGroupa name of group where objects were deleted
◆ findParent()
ModuleBase_ITreeNode * PartSet_FeatureFolderNode::findParent ( const DocumentPtr &  theDoc,
QString  theGroup
theDoca document
theGroupa name of objects group
a parent node if it is found
◆ data()
QVariant PartSet_TreeNode::data ( int  theColumn,
int  theRole
Reimplemented in PartSet_ObjectNode, PartSet_FolderNode, PartSet_PartRootNode, PartSet_ObjectFolderNode, and PartSet_StepNode.
◆ flags()
virtual Qt::ItemFlags ModuleBase_ITreeNode::flags ( int  theColumn) const
inlinevirtualinherited
Reimplemented in PartSet_ObjectNode, PartSet_FolderNode, and PartSet_PartRootNode.
◆ parent()
ModuleBase_ITreeNode * ModuleBase_ITreeNode::parent ( ) const
◆ children()
QTreeNodesList ModuleBase_ITreeNode::children ( ) const
◆ subNode() [1/2]
ModuleBase_ITreeNode * ModuleBase_ITreeNode::subNode ( int  theRow) const
◆ subNode() [2/2]
ModuleBase_ITreeNode * ModuleBase_ITreeNode::subNode ( const ObjectPtr &  theObj,
bool  allLevels = true
theObjan object to find
allLevelsif true then all sub-trees will be processed
◆ hasSubNode()
bool ModuleBase_ITreeNode::hasSubNode ( ModuleBase_ITreeNode *  theNode,
theNodea node to find
◆ childrenCount()
int ModuleBase_ITreeNode::childrenCount ( ) const
◆ object()
virtual ObjectPtr ModuleBase_ITreeNode::object ( ) const
Reimplemented in PartSet_ObjectNode, and PartSet_PartRootNode.
◆ update()
virtual void ModuleBase_ITreeNode::update ( )
Reimplemented in PartSet_ObjectNode, PartSet_FolderNode, PartSet_RootNode, PartSet_PartRootNode, and PartSet_ObjectFolderNode.
◆ workshop()
virtual ModuleBase_IWorkshop * ModuleBase_ITreeNode::workshop ( ) const
Reimplemented in PartSet_RootNode.
◆ document()
virtual DocumentPtr ModuleBase_ITreeNode::document ( ) const
Reimplemented in PartSet_RootNode, and PartSet_PartRootNode.
◆ findRoot()
virtual ModuleBase_ITreeNode * ModuleBase_ITreeNode::findRoot ( const DocumentPtr &  theDoc)
theDoca document
a tree node which is a root of the document structure
◆ visibilityState()
virtual VisibilityState ModuleBase_ITreeNode::visibilityState ( ) const
Reimplemented in PartSet_ObjectNode, and PartSet_StepNode.
◆ deleteChildren()
virtual void ModuleBase_ITreeNode::deleteChildren ( )
◆ myParent
ModuleBase_ITreeNode* ModuleBase_ITreeNode::myParent
Parent of the node.
◆ myChildren
QTreeNodesList ModuleBase_ITreeNode::myChildren
