PartSet_ObjectNode Class Reference
Implementation of a node for object representation. More...
#include <PartSet_TreeNodes.h>
Inheritance diagram for PartSet_ObjectNode:
enum  VisibilityState { NoneState , Visible , SemiVisible , Hidden }
 PartSet_ObjectNode (const ObjectPtr &theObj, ModuleBase_ITreeNode *theParent=0)
virtual std::string type () const
virtual QVariant data (int theColumn, int theRole) const
 Returns the node representation according to theRole. More...
virtual Qt::ItemFlags flags (int theColumn) const
 Returns properties flag of the item. More...
virtual ObjectPtr object () const
 Returns object referenced by the node (can be null) More...
void setObject (ObjectPtr theObj)
 Sets an object to the node theObj a new object. More...
virtual VisibilityState visibilityState () const
 Returns visibilitystate of the node in viewer 3d. More...
virtual void update ()
 Updates sub-nodes of the node. More...
virtual QTreeNodesList objectCreated (const QObjectPtrList &theObjects)
 Process creation of objects. More...
virtual QTreeNodesList objectsDeleted (const DocumentPtr &theDoc, const QString &theGroup)
 Process deletion of objects. More...
virtual int numberOfSubs () const
 Returns number of sub-objects of the current object. More...
virtual ObjectPtr subObject (int theId) const
virtual QColor activeItemColor () const
ModuleBase_ITreeNode * parent () const
 Returns parent node of the current node. More...
QTreeNodesList children () const
 Returns list of the node children. More...
ModuleBase_ITreeNode * subNode (int theRow) const
 Returns a children node according to given row (index) More...
ModuleBase_ITreeNode * subNode (const ObjectPtr &theObj, bool allLevels=true) const
 Finds a node which contains the referenced object. More...
bool hasSubNode (ModuleBase_ITreeNode *theNode, bool allLevels=true) const
 Returns true if the given node is found within children. More...
int childrenCount () const
 Returns number of children. More...
int nodeRow (ModuleBase_ITreeNode *theNode) const
virtual ModuleBase_IWorkshop * workshop () const
 Returns workshop object. Has to be reimplemented in a root node. More...
virtual DocumentPtr document () const
 Returns document object of the sub-tree. Has to be reimplemented in sub-tree root object. More...
virtual ModuleBase_ITreeNode * findParent (const DocumentPtr &theDoc, QString theGroup)
 Returns a node which belongs to the given document and contains objects of the given group. More...
virtual ModuleBase_ITreeNode * findRoot (const DocumentPtr &theDoc)
 Returns root node of a data tree of the given document. More...
static std::string typeId ()
virtual void deleteChildren ()
 deletes all children nodes (called in destructor.) More...
void sortChildren ()
ObjectPtr myObject
ModuleBase_ITreeNode * myParent
 Parent of the node. More...
QTreeNodesList myChildren
 Children of the node. More...
◆ type()
virtual std::string PartSet_ObjectNode::type ( ) const
Implements ModuleBase_ITreeNode.
◆ data()
QVariant PartSet_ObjectNode::data ( int  theColumn,
int  theRole
Reimplemented from PartSet_TreeNode.
Reimplemented in PartSet_ObjectFolderNode, and PartSet_StepNode.
◆ flags()
Qt::ItemFlags PartSet_ObjectNode::flags ( int  theColumn) const
Reimplemented from ModuleBase_ITreeNode.
◆ object()
virtual ObjectPtr PartSet_ObjectNode::object ( ) const
◆ setObject()
void PartSet_ObjectNode::setObject ( ObjectPtr  theObj)
◆ visibilityState()
PartSet_ObjectNode::VisibilityState PartSet_ObjectNode::visibilityState ( ) const
Reimplemented in PartSet_StepNode.
◆ update()
void PartSet_ObjectNode::update ( )
Reimplemented in PartSet_ObjectFolderNode.
◆ objectCreated()
QTreeNodesList PartSet_ObjectNode::objectCreated ( const QObjectPtrList &  theObjects)
theObjectsa list of created objects
a list of nodes which corresponds to the created objects
◆ objectsDeleted()
QTreeNodesList PartSet_ObjectNode::objectsDeleted ( const DocumentPtr &  theDoc,
const QString &  theGroup
theDoca document where objects were deleted
theGroupa name of group where objects were deleted
◆ numberOfSubs()
int PartSet_ObjectNode::numberOfSubs ( ) const
◆ activeItemColor()
QColor PartSet_ObjectNode::activeItemColor ( ) const
◆ parent()
ModuleBase_ITreeNode * ModuleBase_ITreeNode::parent ( ) const
◆ children()
QTreeNodesList ModuleBase_ITreeNode::children ( ) const
◆ subNode() [1/2]
ModuleBase_ITreeNode * ModuleBase_ITreeNode::subNode ( int  theRow) const
◆ subNode() [2/2]
ModuleBase_ITreeNode * ModuleBase_ITreeNode::subNode ( const ObjectPtr &  theObj,
bool  allLevels = true
theObjan object to find
allLevelsif true then all sub-trees will be processed
◆ hasSubNode()
bool ModuleBase_ITreeNode::hasSubNode ( ModuleBase_ITreeNode *  theNode,
theNodea node to find
◆ childrenCount()
int ModuleBase_ITreeNode::childrenCount ( ) const
◆ workshop()
virtual ModuleBase_IWorkshop * ModuleBase_ITreeNode::workshop ( ) const
inlinevirtualinherited
Reimplemented in PartSet_RootNode.
◆ document()
virtual DocumentPtr ModuleBase_ITreeNode::document ( ) const
Reimplemented in PartSet_RootNode, and PartSet_PartRootNode.
◆ findParent()
virtual ModuleBase_ITreeNode * ModuleBase_ITreeNode::findParent ( const DocumentPtr &  theDoc,
QString  theGroup
theDoca document
theGroupa name of objects group
a parent node if it is found
Reimplemented in PartSet_FolderNode, and PartSet_FeatureFolderNode.
◆ findRoot()
virtual ModuleBase_ITreeNode * ModuleBase_ITreeNode::findRoot ( const DocumentPtr &  theDoc)
theDoca document
a tree node which is a root of the document structure
◆ deleteChildren()
virtual void ModuleBase_ITreeNode::deleteChildren ( )
Reimplemented in PartSet_PartRootNode.
◆ myParent
ModuleBase_ITreeNode* ModuleBase_ITreeNode::myParent
Parent of the node.
◆ myChildren
QTreeNodesList ModuleBase_ITreeNode::myChildren
