PartSet_PartRootNode Class Reference
Implementation of Root node of a Part document in data tree. More...
#include <PartSet_TreeNodes.h>
Inheritance diagram for PartSet_PartRootNode:
enum  VisibilityState { NoneState , Visible , SemiVisible , Hidden }
 PartSet_PartRootNode (const ObjectPtr &theObj, ModuleBase_ITreeNode *theParent)
virtual std::string type () const
virtual ObjectPtr object () const
 Returns object referenced by the node (can be null) More...
virtual DocumentPtr document () const
 Returns document object of the sub-tree. More...
virtual void update ()
 Updates sub-nodes of the node. More...
virtual QVariant data (int theColumn, int theRole) const
 Returns the node representation according to theRole. More...
virtual Qt::ItemFlags flags (int theColumn) const
 Returns properties flag of the item. More...
virtual QTreeNodesList objectCreated (const QObjectPtrList &theObjects)
 Process creation of objects. More...
virtual QTreeNodesList objectsDeleted (const DocumentPtr &theDoc, const QString &theGroup)
 Process deletion of objects. More...
virtual ModuleBase_ITreeNode * findParent (const DocumentPtr &theDoc, QString theGroup)
 Returns a node which belongs to the given document and contains objects of the given group. More...
virtual QColor activeItemColor () const
ModuleBase_ITreeNode * parent () const
 Returns parent node of the current node. More...
QTreeNodesList children () const
 Returns list of the node children. More...
ModuleBase_ITreeNode * subNode (int theRow) const
 Returns a children node according to given row (index) More...
ModuleBase_ITreeNode * subNode (const ObjectPtr &theObj, bool allLevels=true) const
 Finds a node which contains the referenced object. More...
bool hasSubNode (ModuleBase_ITreeNode *theNode, bool allLevels=true) const
 Returns true if the given node is found within children. More...
int childrenCount () const
 Returns number of children. More...
int nodeRow (ModuleBase_ITreeNode *theNode) const
virtual ModuleBase_IWorkshop * workshop () const
 Returns workshop object. Has to be reimplemented in a root node. More...
virtual ModuleBase_ITreeNode * findRoot (const DocumentPtr &theDoc)
 Returns root node of a data tree of the given document. More...
virtual VisibilityState visibilityState () const
 Returns visibilitystate of the node in viewer 3d. More...
static std::string typeId ()
virtual ModuleBase_ITreeNode * createNode (const ObjectPtr &theObj)
virtual int numberOfFolders () const
virtual void deleteChildren ()
 deletes all children nodes (called in destructor.) More...
void sortChildren ()
ModuleBase_ITreeNode * myParent
 Parent of the node. More...
QTreeNodesList myChildren
 Children of the node. More...
◆ type()
virtual std::string PartSet_PartRootNode::type ( ) const
Implements ModuleBase_ITreeNode.
◆ object()
virtual ObjectPtr PartSet_PartRootNode::object ( ) const
Reimplemented from ModuleBase_ITreeNode.
◆ document()
DocumentPtr PartSet_PartRootNode::document ( ) const
◆ update()
void PartSet_PartRootNode::update ( )
◆ data()
QVariant PartSet_PartRootNode::data ( int  theColumn,
int  theRole
Reimplemented from PartSet_TreeNode.
◆ flags()
Qt::ItemFlags PartSet_PartRootNode::flags ( int  theColumn) const
◆ objectCreated()
QTreeNodesList PartSet_PartRootNode::objectCreated ( const QObjectPtrList &  theObjects)
theObjectsa list of created objects
a list of nodes which corresponds to the created objects
Reimplemented from PartSet_FeatureFolderNode.
◆ objectsDeleted()
QTreeNodesList PartSet_PartRootNode::objectsDeleted ( const DocumentPtr &  theDoc,
const QString &  theGroup
theDoca document where objects were deleted
theGroupa name of group where objects were deleted
◆ createNode()
ModuleBase_ITreeNode * PartSet_PartRootNode::createNode ( const ObjectPtr &  theObj)
◆ numberOfFolders()
int PartSet_PartRootNode::numberOfFolders ( ) const
◆ deleteChildren()
void PartSet_PartRootNode::deleteChildren ( )
◆ findParent()
ModuleBase_ITreeNode * PartSet_FeatureFolderNode::findParent ( const DocumentPtr &  theDoc,
QString  theGroup
theDoca document
theGroupa name of objects group
a parent node if it is found
◆ parent()
ModuleBase_ITreeNode * ModuleBase_ITreeNode::parent ( ) const
◆ children()
QTreeNodesList ModuleBase_ITreeNode::children ( ) const
◆ subNode() [1/2]
ModuleBase_ITreeNode * ModuleBase_ITreeNode::subNode ( int  theRow) const
◆ subNode() [2/2]
ModuleBase_ITreeNode * ModuleBase_ITreeNode::subNode ( const ObjectPtr &  theObj,
bool  allLevels = true
theObjan object to find
allLevelsif true then all sub-trees will be processed
◆ hasSubNode()
bool ModuleBase_ITreeNode::hasSubNode ( ModuleBase_ITreeNode *  theNode,
theNodea node to find
◆ childrenCount()
int ModuleBase_ITreeNode::childrenCount ( ) const
◆ workshop()
virtual ModuleBase_IWorkshop * ModuleBase_ITreeNode::workshop ( ) const
inlinevirtualinherited
Reimplemented in PartSet_RootNode.
◆ findRoot()
virtual ModuleBase_ITreeNode * ModuleBase_ITreeNode::findRoot ( const DocumentPtr &  theDoc)
theDoca document
a tree node which is a root of the document structure
◆ visibilityState()
virtual VisibilityState ModuleBase_ITreeNode::visibilityState ( ) const
Reimplemented in PartSet_ObjectNode, and PartSet_StepNode.
◆ myParent
ModuleBase_ITreeNode* ModuleBase_ITreeNode::myParent
Parent of the node.
◆ myChildren
QTreeNodesList ModuleBase_ITreeNode::myChildren
