PrimitivesAPI_Tube Class Reference
Interface for primitive Tube feature. More...
#include <PrimitivesAPI_Tube.h>
Inheritance diagram for PrimitivesAPI_Tube:
 PrimitivesAPI_Tube (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 PrimitivesAPI_Tube (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theRMin, const ModelHighAPI_Double &theRMax, const ModelHighAPI_Double &theHeight)
virtual ~PrimitivesAPI_Tube ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmin () const
 Inner radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmax () const
 Outer radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > height () const
 Height. More...
void setRadius (const ModelHighAPI_Double &theRMin, const ModelHighAPI_Double &theRMax)
 Set radius. More...
void setHeight (const ModelHighAPI_Double &theHeight)
 Set height. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeDouble > myrmin
std::shared_ptr< ModelAPI_AttributeDouble > myrmax
std::shared_ptr< ModelAPI_AttributeDouble > myheight
◆ PrimitivesAPI_Tube() [1/2]
PrimitivesAPI_Tube::PrimitivesAPI_Tube ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ PrimitivesAPI_Tube() [2/2]
PrimitivesAPI_Tube::PrimitivesAPI_Tube ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Double &  theRMin,
const ModelHighAPI_Double &  theRMax,
const ModelHighAPI_Double &  theHeight
explicit
◆ ~PrimitivesAPI_Tube()
PrimitivesAPI_Tube::~PrimitivesAPI_Tube ( )
◆ rmin()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Tube::rmin ( ) const
Inner radius.
◆ rmax()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Tube::rmax ( ) const
Outer radius.
◆ height()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Tube::height ( ) const
Height.
◆ setRadius()
void PrimitivesAPI_Tube::setRadius ( const ModelHighAPI_Double &  theRMin,
Set radius.
◆ setHeight()
void PrimitivesAPI_Tube::setHeight ( const ModelHighAPI_Double &  theHeight)
Set height.
◆ dump()
void PrimitivesAPI_Tube::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
